Date/Time: Mon, 20 May 2024 19:33:26 +0000
Clearing all alerts at once
View Count: 1170
[2016-06-09 06:43:07] |
EuropeanTrader - Posts: 290 |
Hi, by looking through the documentation I can't find a simple solution to clear all alerts at once. Can you please direct me to a solution? The alerts I am talking about is when I mouse right click a chart / Add symbol alert and press Enter. I have many of these and some don't serve a purpose any longer after awhile but they may still trigger in next days. Is there a way? Thank you! |
[2016-06-09 19:22:38] |
You cannot remove these all at once but you can see them in the Alerts Manager and remove them one by one: https://www.sierrachart.com/index.php?page=doc/doc_AlertsManager.html#SymbolAlerts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-06-10 04:32:45] |
Hi, I see. I have 100+ of them, some are already disabled I see. One-click delete would be very helpful. Thanks for letting me know though! |
