Date/Time: Sun, 10 May 2026 05:13:48 +0000
Default session times
View Count: 2385
| [2013-07-12 18:23:08] |
| joshtrader - Posts: 543 |
In the chart settings, "Apply Intraday Session times" is turned off. Let's say I have AAPL open, with 9:30:00 - 15:59:59. When I type <slash> PFE <enter> to download the new symbol PFE (or if I just type "MSFT <enter>" if I already have a MSFT data file), the intraday session times change to 00:00:00 to 23:59:59. It would seem with the above option turned off, that the 9:30 to 15:59 time would remain the same. Am I misunderstanding this functionality? I do not want to have to create a new symbol and settings for each one of potentially hundreds of stocks I might want to open--when I have a symbol in the settings it works fine as expected. But I just want the times of a newly created, or an existing chart, to default to 9:30 - 15:59. Is it possible? Date Time Of Last Edit: 2013-07-12 18:25:54
| [2013-07-12 22:54:00] |
Refer to Global Symbol Settings: http://www.sierrachart.com/index.php?l=doc/doc_GlobalSymbolSettings.php You need to disable Apply Intraday Session Times to Intraday Chart. Or you can set up a few symbol patterns in Global Symbol Settings to match all the stocks. And set up session times on those. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-07-12 22:55:13
