Date/Time: Mon, 20 May 2024 16:21:31 +0000
Multiple symbols
View Count: 521
[2016-06-09 00:43:57] |
User656410 - Posts: 12 |
Hello, I have one chart-book file which has multiple emini Nasdaq time-frame charts. I would like to open the same charts, but with the S&P. Do I open another chart-book file? Because I don't want them up at the same time, I would assume so. Where is the best location to open the new chart-book file? Thanks |
[2016-06-09 04:44:47] |
You can use another Chartbook. Refer to: https://www.sierrachart.com/index.php?page=doc/doc_Chartbooks.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
