Date/Time: Mon, 20 May 2024 19:17:53 +0000
Floating chart
View Count: 594
[2016-06-08 21:31:19] |
User631578 - Posts: 3 |
Is it possible to have a floating chart on top of another? Thank you, Rick Reynolds |
[2016-06-08 22:07:53] |
Yes you can. Follow the instructions on this page: http://www.sierrachart.com/index.php?page=doc/doc_DetachingandAttachingChartWindows.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
