Date/Time: Mon, 20 May 2024 15:58:09 +0000
Change study color on slope
View Count: 1344
[2016-06-08 18:46:10] |
User533143 - Posts: 14 |
is there a way to color study on slope like the color bar on slope selection, I'd like to have Keltner channel lines change color on slope.
[2016-06-08 19:06:36] |
User41683 - Posts: 37 |
See the screenshots.
Keltner.jpg / V - Attached On 2016-06-08 19:05:42 UTC - Size: 331.37 KB - 385 views Color_slope.jpg / V - Attached On 2016-06-08 19:05:55 UTC - Size: 175.47 KB - 412 views |
[2016-06-09 05:49:37] |
The easiest way is to use the Auto Coloring setting: https://www.sierrachart.com/index.php?page=doc/doc_ChartStudies.html#AutoColoring This can be also done with the Color Bar Based on Alert Condition study which is fully documented here: https://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s245 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-06-09 16:47:27
[2016-06-09 11:48:31] |
I like the colored cloud formed by using 'Filling the area between two subgraphs ' but the price bars disappear; even though I check the independent boxes. What am I doing wrong ?
[2016-06-09 11:56:05] |
RESOLVED- I moved the subgraph reference study to main graph-and price candles re appeared--thanks.
