Date/Time: Mon, 20 May 2024 19:50:20 +0000
Change bar color
View Count: 2066
[2016-06-08 14:18:43] |
User533143 - Posts: 14 |
hi-the default bar chart has the same color for open and close dots. Can I change each dot color ( eg= green dot open and red dot close of bar ) Thank You.
[2016-06-08 17:18:46] |
The color of the Open and Close marks for chart bars can be changed: https://www.sierrachart.com/index.php?page=doc/doc_GraphicsSettings.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
