Date/Time: Mon, 20 May 2024 12:58:46 +0000
Else statement
View Count: 1011
[2016-06-07 19:33:54] |
User170575 - Posts: 221 |
Hi, Is there a way to do an If or Else statement that will result in a different message per else statement in the alert manager? Example: =v>v[-1]*3 alert manager would say "V3" else =v>v[-1]*2 alert manager would say "V2" else =v>v[-1]*1 alert manager would say "V1" OR is there a way to adjust the sequence of the alerts and if first is hit it will skip through the remaining without triggering the alert manager? I hope this makes sense. Thanks for the help, Cy |
[2016-06-08 05:45:30] |
Refer to: https://www.sierrachart.com/index.php?page=doc/doc_StudyChartAlertsAndScanning.php#CustomizingMessagesInAlertsLog This is all that is available. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
