Date/Time: Fri, 03 May 2024 10:38:31 +0000
TICK and ADDN Data
View Count: 1712
[2013-07-12 16:54:14] |
fittjsb - Posts: 8 |
Hi - Is the NYSE Tick and the ADDN in Real Time through TDAmeritrade or is is Delayed? If it is Delayed, how long is it Delayed for? Thanks, Jeff |
[2013-07-12 17:14:46] |
Sierra Chart - Max - Posts: 5599 |
The Market Statistics are included with Sierra Chart packages 3 and higher. For more information, please see: http://www.sierrachart.com/index.php?l=doc/helpdetails66.html Sierra Chart Support |
[2013-07-12 17:21:25] |
Thanks for the response Max, but that does not answer my question. Right now I have the Tick and the ADDN on Sierra Charts and my provider is TDAmeritrade. The two symbols work and everything I was just wandering if they are Delayed at All or are they Real Time? Thanks, Jeff |
[2013-07-12 18:21:26] |
If you are using the symbols $TICK $NVLF $NSHF, then you are getting the data that is described in the help topic 66 linked above.
[2013-07-12 20:12:52] |
Thanks Max - I will pull it up and read through it again. Not sure why you could not just tell me simple Yes or No if Delayed or Not?? Thanks, Jeff |
[2013-07-12 20:18:58] |
Max - I just read it again and it says nothing about TDAmeritrade, only Sierra Chart, Barchart, Interactive Brokers, and IQ Feed? Thanks, Jeff |
[2013-07-12 23:28:07] |
The data is real-time. The documentation does not make reference to TD Ameritrade because that is not relevant to the market statistics data feed being provided by us. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
