Date/Time: Mon, 20 May 2024 15:42:26 +0000
FXCM order update (Rejected)
View Count: 1928
[2016-06-06 12:32:23] |
Ziklag - Posts: 73 |
FXCM order update (Rejected). Info: 19915;DAS 19915: ZDas Exception ORA-20210: Order 62347741 could not be executed. Instrument ITA40 is under trading restriction: only position close is allowed. Internal Order ID: 377. Service Order ID: (none). Symbol: ITA40 | 2016-06-06 13:33:07 * Version 1399 |
[2016-06-06 14:08:13] |
FXCM order update (Rejected). Info: 19915;DAS 19915: ZDas Exception ORA-20210: Order 62347741 could not be executed. Instrument ITA40 is under trading restriction: only position close is allowed. Internal Order ID: 377. Service Order ID: (none). Symbol: ITA40 | 2016-06-06 13:33:07 * FXCM order update (Rejected). Info: 19915;DAS 19915: ZDas Exception ORA-20210: Order 62353328 could not be executed. Instrument ITA40 is under trading restriction: only position close is allowed. Internal Order ID: 380. Service Order ID: (none). Symbol: ITA40 | 2016-06-06 16:39:45 * FXCM order update (Rejected). Info: 19915;DAS 19915: ZDas Exception ORA-20210: Order 62353332 could not be executed. Instrument ITA40 is under trading restriction: only position close is allowed. Internal Order ID: 383. Service Order ID: (none). Symbol: ITA40 | 2016-06-06 16:39:48 * FXCM order update (Rejected). Info: 19915;DAS 19915: ZDas Exception ORA-20210: Order 62353343 could not be executed. Instrument ITA40 is under trading restriction: only position close is allowed. Internal Order ID: 386. Service Order ID: (none). Symbol: ITA40 | 2016-06-06 16:40:06 * |
[2016-06-06 16:41:41] |
This message is from FXCM: Info: 19915;DAS 19915: ZDas Exception ORA-20210: Order 62353343 could not be executed. Instrument ITA40 is under trading restriction: only position close is allowed.
Contact FXCM for more help. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-06-07 02:14:41] |
Before it happened I had upgraded via Help >> Download Current Version; I don't know if "current version" is the problem, too, why does Version still read 1399 after the upgrade?
[2016-06-07 02:37:22] |
The installation did not complete successfully if you are still running version 1399. Try updating again. This error is not related to the version of Sierra Chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-06-07 10:34:08] |
CC api Message body Hello Peter, This question should be directed to SierraChart. You can reach them through here: http://www.sierrachart.com/index.php?page=doc/support.html We are still looking for possible FXCM-side errors regarding the first issue. As SierraChart is using FXCM public API, we cannot support their platform directly. Did you contact SierraChart about this problem yet ? To answer your question from different chain: We have not received reports of this error from anyone else. Best Regards, Pawel |
[2016-06-07 10:35:09] |
FXCM order update (Rejected). Info: 19915;DAS 19915: ZDas Exception ORA-20126: Market is closed. Any trading functionality is not available. Internal Order ID: 398. Service Order ID: (none). Symbol: ITA40 | 2016-06-07 10:00:40 * FXCM order update (Rejected). Info: 19915;DAS 19915: ZDas Exception ORA-20210: Order 62376367 could not be executed. Instrument ITA40 is under trading restriction: only position close is allowed. Internal Order ID: 401. Service Order ID: (none). Symbol: ITA40 | 2016-06-07 10:01:24 * FXCM order update (Rejected). Info: 19915;DAS 19915: ZDas Exception ORA-20210: Order 62376369 could not be executed. Instrument ITA40 is under trading restriction: only position close is allowed. Internal Order ID: 404. Service Order ID: (none). Symbol: ITA40 | 2016-06-07 10:01:38 * FXCM order update (Rejected). Info: 19915;DAS 19915: ZDas Exception ORA-20210: Order 62376528 could not be executed. Instrument ITA40 is under trading restriction: only position close is allowed. Internal Order ID: 407. Service Order ID: (none). Symbol: ITA40 | 2016-06-07 10:04:05 * FXCM order update (Rejected). Info: 19915;DAS 19915: ZDas Exception ORA-20210: Order 62376536 could not be executed. Instrument ITA40 is under trading restriction: only position close is allowed. Internal Order ID: 410. Service Order ID: (none). Symbol: ITA40 | 2016-06-07 10:04:34 * |
[2016-06-07 10:37:26] |
Via Help >> "Download Current Version" this morning I upgraded to Version 1425 before, hours later, this, happened.
[2016-06-07 10:57:57] |
We are contacting FXCM about this now and see what they say.
[2016-06-08 05:48:38] |
FXCM says they are following up with you about this.
