Date/Time: Sun, 28 Apr 2024 13:21:30 +0000
NEED HELP
View Count: 2582
[2013-03-29 12:43:27] |
User57072 - Posts: 49 |
HAS THERE BEEN ANY ISSUES WITH PRINTING ? I AM UNABLE TO PRINT THE CHARTS.
[2013-03-29 18:23:58] |
Sierra Chart does properly print charts following the specifications of the Windows API for printing. If there is a problem with this, it is going to be with the printer driver, not with Sierra Chart, Even if you can print from other programs. We are able to print fine and it's unusual for us to hear about printing problems, although occasionally we do. In these cases we know the source of the problem is with the driver unable to print the data that we have given the operating system which then in turn gives it to the driver. Our recommendation, is to remove the existing printer driver for the printer you are using and install a new one through the Microsoft Printer Control Panel. Just use the standard one provided by Microsoft. To confirm that Sierra Chart is printing correctly, print to the Microsoft XPS Document Writer: http://windows.microsoft.com/en-nz/windows7/print-to-the-microsoft-xps-document-writer After this, open the XPS document that has been created and you will see that Sierra Chart is properly printing. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-03-29 18:29:12
