Date/Time: Mon, 29 Apr 2024 04:05:53 +0000
Chart times bug on symbol change
View Count: 1698
[2013-07-12 13:00:47] |
joshtrader - Posts: 439 |
Assume two symbols, A and B, each with different session times defined in Global Symbol Settings. 1) With a 10 minute chart of A up and correct session times for symbol A, change to a daily chart (type "1d <enter>"). 2) Change to symbol B (type "B <enter>") 3) Change symbol B to a 10 minute chart (type "10m <enter>") At this point the chart showing symbol B will have symbol A's session times. So it seems that when going from a historical chart of one symbol to an intraday chart of that symbol, the correct session times are not implied, but instead the prior intraday symbol's times are being used. Date Time Of Last Edit: 2013-07-12 13:01:25
[2013-07-15 23:41:12] |
You need to make sure that Global Settings >> Symbol Settings >> Apply Intraday Session Times to Intraday Chart is enabled.
