Date/Time: Fri, 17 May 2024 23:19:21 +0000
[Programming Help] - About Parabolic SAR coding
View Count: 713
[2016-06-02 10:23:25] |
User862333 - Posts: 3 |
Hello, I am having a small problem in configuring my Parabolic Setup. The current SAR high and low will update on each tick received, and reverse if current bar high (low) is higher than SAR high(low) when short(long). However, I would like to adjust the update base on close, which means: When Short, the SAR high will reverse to SAR low if the bar close is higher than SAR high; When Long, the SAR low will reverse to SAR high if the bar close is lower than SAR low. I am a newbie in cpp, and still scratching my head on reading those documents in Sierra. Would anyone can offer me this small help? Thanks a lot! |
