Date/Time: Mon, 20 May 2024 18:06:45 +0000
Errors in creating Weekly chart of ES day session only
View Count: 764
[2016-06-01 23:39:27] |
User27189 - Posts: 26 |
When I try to create a weekly bar chart based on ES intraday data, day session only as per the instructions in Table of Contents "Charting": "If you want to create a weekly chart with an Intraday Chart, then set the Days - Minutes - Seconds control to 7-0-0.", I'm getting bars that start on Tuesday of the week instead of Mondays. What might be the problem??
[2016-06-02 01:40:54] |
Make sure you follow step 8 here: https://www.sierrachart.com/index.php?page=doc/doc_SessionTimes.php#DaySessionOnlyWeekly Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
