Date/Time: Fri, 03 May 2024 21:40:25 +0000
create alert with fib retracement
View Count: 1626
[2013-07-12 09:21:24] |
User27812 - Posts: 15 |
Hello support, What condition formula can I use to create an alert when price hits 61.8% retracement? I want an email alert when this happens. Any help will be appreciated. Thanks Gurdeet |
[2013-07-12 22:50:04] |
There is not direct support for this. What you need to do is set a simple price alert on the chart itself. Here is the documentation for this: http://www.sierrachart.com/index.php?l=doc/doc_AlertCondAndScan.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
