Date/Time: Thu, 02 May 2024 07:32:13 +0000
Footprint History
View Count: 1555
[2013-07-12 08:33:58] |
Yes you can access historical bid volume and ask volume tick data for this. You need to follow through the instructions on this page for this: https://www.sierrachart.com/index.php?l=doc/doc_TickbyTickDataConfiguration.php We see you are using IQ Feed , so you need to be certain that you are downloading 1 Tick historical data and you need to be aware of the 8 day limitation: https://www.sierrachart.com/index.php?l=doc/DTNIQFeed.html#TickLimitMarketHours Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-07-12 08:34:49
