Date/Time: Tue, 17 Nov 2026 00:14:28 +0000
Help getting started.
View Count: 923
| [2016-05-27 19:57:12] |
| User511691 - Posts: 25 |
Hello, I just purchased 1 month of use for your software. I was referred to you by my broker (ADMIS) for instructions to connect your software to Rithmic and to get a username/password (which I think is logical). I have already downloaded your software from your page and also have completed all the necessary steps with my broker to start trading. Please let me know (or guide me) as to what steps to take to connect the software to Rithmic and start live trading. Thank you. Regards, Jose Date Time Of Last Edit: 2016-05-27 20:25:29
| [2016-05-27 20:31:53] |
Your Sierra Chart account is fine. So at this point in time you just need to follow through the Rithmic set up instructions here: http://www.sierrachart.com/index.php?page=doc/Rithmic.php#SetupInstructions You will need your broker provided Rithmic username and password. To perform live trading, refer to: http://www.sierrachart.com/index.php?page=doc/doc_Trading.html#DifferenceBetweenSimAndNonSim Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
