Date/Time: Thu, 02 May 2024 00:29:11 +0000
Market Depth Historical Graph
View Count: 3015
[2016-05-26 06:29:41] |
Zdislav - Posts: 73 |
Hello SC Support. I would like to ask, which data feed I should use to experience full potential of this study? As you posted, SC Data Feed will not provide historical (recorded) DOM data. So will the study provide saving DOM data feature localy? Or does other data feeds provide historical DOM data as a standard or extra feature? Thank you. Z. |
[2016-05-26 06:41:10] |
Upcoming versions of Sierra Chart will support storing market depth data. There is no particular data feed that you need to use. Only a data feed that provides market depth data. There is no data feed also that provides historical market depth data. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-05-26 10:40:08] |
Good news! Thank you very much. Z. |
[2016-06-06 21:21:26] |
onnb - Posts: 661 |
1. Any idea when this will be available? 2. I'm assuming this data will be available for replay studies can access it when loading charts using the ACSIL dom api? |
[2016-06-07 03:00:26] |
1. In about two weeks. 2. Yes. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
