Date/Time: Tue, 29 Sep 2026 08:04:12 +0000
can't connect to data
View Count: 892
| [2016-05-24 23:12:12] |
| User269684 - Posts: 8 |
still having trouble, here is a copy of the log. Software version: 1415 | 2016-05-24 16:09:27 Uses New Spreadsheets | 2016-05-24 16:09:27 Usage end date: 2016-08-06 | 2016-05-24 16:09:27 Enabled for: Advanced Features. | 2016-05-24 16:09:27 Enabled for: Advanced Features 2. | 2016-05-24 16:09:27 Enabled for: Sierra Chart Historical Data Service. | 2016-05-24 16:09:27 Allow Support for Sierra Chart Data Feeds is enabled. | 2016-05-24 16:09:27 Current selected Data/Trading service: GAIN Capital/OEC | 2016-05-24 16:09:27 Chart Update Interval: 500 | 2016-05-24 16:09:27 Time Zone: -07:00:00 (PST-08PDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2016-05-24 16:09:27 2016-05-24 19:09:26 Local computer time | 2016-05-24 16:09:27 2016-05-24 23:09:26 Local computer time in UTC | 2016-05-24 16:09:27 2016-05-24 16:09:26 Local computer time in SC Time Zone | 2016-05-24 16:09:27 2016-05-24 23:08:04 Server time in UTC | 2016-05-24 16:09:27 Local computer UTC time and Server UTC time difference: 6 seconds. | 2016-05-24 16:09:27 Program path: C:\SierraChart\ | 2016-05-24 16:09:27 Data Files path: C:\SierraChart\Data\ | 2016-05-24 16:09:27 OS Version Number: 6.1 | 2016-05-24 16:09:27 Locale Setting: C | 2016-05-24 16:09:27 GAIN Capital/OEC | Connecting to trading server prod.openecry.com. Port: 9400. | 2016-05-24 16:09:28 GainCapital FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206. | 2016-05-24 16:09:28 GainCapital FIX Trading socket (29) | Connected. | 2016-05-24 16:09:28 GainCapital FIX Trading socket (29) | Starting TLS 1.2 connection. | 2016-05-24 16:09:28 GainCapital FIX Trading socket (29) | SSL connection established. | 2016-05-24 16:09:29 GainCapital FIX Trading: Sending the Logon message. | 2016-05-24 16:09:29 GainCapital FIX Trading: Received a sequence number that is ahead of the next expected sequence number. Expected sequence number 1. New sequence number 222 | 2016-05-24 16:09:29 GainCapital FIX Trading | Connected to trading server. | 2016-05-24 16:09:29 GAIN Capital/OEC | Connecting to market data server prod.openecry.com:9301. | 2016-05-24 16:09:29 GainCapital FAST Data socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206. | 2016-05-24 16:09:29 GainCapital FIX Trading: Received a Logout message. Text = User temporarily locked out | 2016-05-24 16:09:29 GainCapital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2016-05-24 16:09:29 GainCapital FIX Trading socket (29) | SSL shutdown indicates not able to send 'close notify'. | 2016-05-24 16:09:29 GainCapital FIX Trading socket (29) | SSL has been shut down. | 2016-05-24 16:09:29 GainCapital FIX Trading socket (29) | SSL object has been freed. SSL state is now disconnected. | 2016-05-24 16:09:29 GainCapital FIX Trading socket (29) | Shutdown and closed. | 2016-05-24 16:09:29 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-05-24 16:09:29 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-05-24 16:09:29 GAIN Capital/OEC | Disconnected from the trading server. | 2016-05-24 16:09:29 GAIN Capital/OEC | Immediate disconnect from trading server detected. On next connect Logout will be sent first. | 2016-05-24 16:09:29 GainCapital FAST Data socket (30) | Shutdown and closed. | 2016-05-24 16:09:29 GainCapital FAST Data: Socket connection was closed without any logout messages sent or received. | 2016-05-24 16:09:29 GAIN Capital/OEC | Disconnected from the FAST market data server. | 2016-05-24 16:09:29 GAIN Capital/OEC | Disconnected. | 2016-05-24 16:09:29 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-05-24 16:09:29 GAIN Capital/OEC | Connecting to trading server prod.openecry.com. Port: 9400. | 2016-05-24 16:09:32 GainCapital FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206. | 2016-05-24 16:09:32 GainCapital FIX Trading socket (31) | Connected. | 2016-05-24 16:09:32 GainCapital FIX Trading socket (31) | Starting TLS 1.2 connection. | 2016-05-24 16:09:32 GainCapital FIX Trading socket (31) | SSL connection established. | 2016-05-24 16:09:32 GainCapital FIX Trading: Sending the Logon message. | 2016-05-24 16:09:32 GainCapital FIX Trading socket (31) | Closed. No error. | 2016-05-24 16:09:32 GainCapital FIX Trading socket (31) | SSL shutdown indicates not able to send 'close notify'. | 2016-05-24 16:09:32 GainCapital FIX Trading socket (31) | SSL has been shut down. | 2016-05-24 16:09:32 GainCapital FIX Trading socket (31) | SSL object has been freed. SSL state is now disconnected. | 2016-05-24 16:09:32 GainCapital FIX Trading socket (31) | Shutdown and closed. | 2016-05-24 16:09:32 GainCapital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2016-05-24 16:09:32 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-05-24 16:09:32 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-05-24 16:09:32 GAIN Capital/OEC | Disconnected from the trading server. | 2016-05-24 16:09:32 GAIN Capital/OEC | Disconnected. | 2016-05-24 16:09:32 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-05-24 16:09:32 GAIN Capital/OEC | Connecting to trading server prod.openecry.com. Port: 9400. | 2016-05-24 16:09:35 GainCapital FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206. | 2016-05-24 16:09:35 GainCapital FIX Trading socket (32) | Connected. | 2016-05-24 16:09:35 GainCapital FIX Trading socket (32) | Starting TLS 1.2 connection. | 2016-05-24 16:09:35 GainCapital FIX Trading socket (32) | SSL connection established. | 2016-05-24 16:09:36 GainCapital FIX Trading: Sending the Logon message. | 2016-05-24 16:09:36 GainCapital FIX Trading: Received a sequence number that is ahead of the next expected sequence number. Expected sequence number 1. New sequence number 224 | 2016-05-24 16:09:36 GainCapital FIX Trading: Received a Logout message. Text = MsgSeqNum too low, expecting 3 but received 1 | 2016-05-24 16:09:36 GainCapital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2016-05-24 16:09:36 GainCapital FIX Trading socket (32) | SSL shutdown indicates not able to send 'close notify'. | 2016-05-24 16:09:36 GainCapital FIX Trading socket (32) | SSL has been shut down. | 2016-05-24 16:09:36 GainCapital FIX Trading socket (32) | SSL object has been freed. SSL state is now disconnected. | 2016-05-24 16:09:36 GainCapital FIX Trading socket (32) | Shutdown and closed. | 2016-05-24 16:09:36 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-05-24 16:09:36 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-05-24 16:09:36 GAIN Capital/OEC | Disconnected from the trading server. | 2016-05-24 16:09:36 GAIN Capital/OEC | Immediate disconnect from trading server detected. On next connect Logout will be sent first. | 2016-05-24 16:09:36 GAIN Capital/OEC | Disconnected. | 2016-05-24 16:09:36 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-05-24 16:09:36 GAIN Capital/OEC | Connecting to trading server prod.openecry.com. Port: 9400. | 2016-05-24 16:09:39 GainCapital FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206. | 2016-05-24 16:09:39 GainCapital FIX Trading socket (33) | Connected. | 2016-05-24 16:09:39 GainCapital FIX Trading socket (33) | Starting TLS 1.2 connection. | 2016-05-24 16:09:39 GainCapital FIX Trading socket (33) | SSL connection established. | 2016-05-24 16:09:39 GainCapital FIX Trading: Sending the Logon message. | 2016-05-24 16:09:39 GainCapital FIX Trading socket (33) | Closed. No error. | 2016-05-24 16:09:39 GainCapital FIX Trading socket (33) | SSL shutdown indicates not able to send 'close notify'. | 2016-05-24 16:09:39 GainCapital FIX Trading socket (33) | SSL has been shut down. | 2016-05-24 16:09:39 GainCapital FIX Trading socket (33) | SSL object has been freed. SSL state is now disconnected. | 2016-05-24 16:09:39 GainCapital FIX Trading socket (33) | Shutdown and closed. | 2016-05-24 16:09:39 GainCapital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2016-05-24 16:09:39 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-05-24 16:09:39 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-05-24 16:09:39 GAIN Capital/OEC | Disconnected from the trading server. | 2016-05-24 16:09:39 GAIN Capital/OEC | Disconnected. | 2016-05-24 16:09:39 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-05-24 16:09:39 GAIN Capital/OEC | Connecting to trading server prod.openecry.com. Port: 9400. | 2016-05-24 16:09:42 GainCapital FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206. | 2016-05-24 16:09:42 GainCapital FIX Trading socket (34) | Connected. | 2016-05-24 16:09:42 GainCapital FIX Trading socket (34) | Starting TLS 1.2 connection. | 2016-05-24 16:09:42 GainCapital FIX Trading socket (34) | SSL connection established. | 2016-05-24 16:09:43 GainCapital FIX Trading: Sending the Logon message. | 2016-05-24 16:09:43 GainCapital FIX Trading: Received a sequence number that is ahead of the next expected sequence number. Expected sequence number 1. New sequence number 225 | 2016-05-24 16:09:43 GainCapital FIX Trading | Connected to trading server. | 2016-05-24 16:09:43 GAIN Capital/OEC | Connecting to market data server prod.openecry.com:9301. | 2016-05-24 16:09:43 GainCapital FAST Data socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206. | 2016-05-24 16:09:43 GainCapital FIX Trading: Received a Logout message. Text = User temporarily locked out | 2016-05-24 16:09:43 GainCapital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2016-05-24 16:09:43 GainCapital FIX Trading socket (34) | SSL shutdown indicates not able to send 'close notify'. | 2016-05-24 16:09:43 GainCapital FIX Trading socket (34) | SSL has been shut down. | 2016-05-24 16:09:43 GainCapital FIX Trading socket (34) | SSL object has been freed. SSL state is now disconnected. | 2016-05-24 16:09:43 GainCapital FIX Trading socket (34) | Shutdown and closed. | 2016-05-24 16:09:43 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-05-24 16:09:43 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-05-24 16:09:43 GAIN Capital/OEC | Disconnected from the trading server. | 2016-05-24 16:09:43 GAIN Capital/OEC | Immediate disconnect from trading server detected. On next connect Logout will be sent first. | 2016-05-24 16:09:43 GainCapital FAST Data socket (35) | Shutdown and closed. | 2016-05-24 16:09:43 GainCapital FAST Data: Socket connection was closed without any logout messages sent or received. | 2016-05-24 16:09:43 GAIN Capital/OEC | Disconnected from the FAST market data server. | 2016-05-24 16:09:43 GAIN Capital/OEC | Disconnected. | 2016-05-24 16:09:43 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-05-24 16:09:43 GAIN Capital/OEC | Connecting to trading server prod.openecry.com. Port: 9400. | 2016-05-24 16:09:46 GainCapital FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206. | 2016-05-24 16:09:46 GainCapital FIX Trading socket (36) | Connected. | 2016-05-24 16:09:46 GainCapital FIX Trading socket (36) | Starting TLS 1.2 connection. | 2016-05-24 16:09:46 GainCapital FIX Trading socket (36) | SSL connection established. | 2016-05-24 16:09:46 GainCapital FIX Trading: Sending the Logon message. | 2016-05-24 16:09:46 GainCapital FIX Trading socket (36) | Closed. No error. | 2016-05-24 16:09:46 GainCapital FIX Trading socket (36) | SSL shutdown indicates not able to send 'close notify'. | 2016-05-24 16:09:46 GainCapital FIX Trading socket (36) | SSL has been shut down. | 2016-05-24 16:09:46 GainCapital FIX Trading socket (36) | SSL object has been freed. SSL state is now disconnected. | 2016-05-24 16:09:46 GainCapital FIX Trading socket (36) | Shutdown and closed. | 2016-05-24 16:09:46 GainCapital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2016-05-24 16:09:46 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-05-24 16:09:46 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-05-24 16:09:46 GAIN Capital/OEC | Disconnected from the trading server. | 2016-05-24 16:09:46 GAIN Capital/OEC | Disconnected. | 2016-05-24 16:09:46 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-05-24 16:09:46 GAIN Capital/OEC | Connecting to trading server prod.openecry.com. Port: 9400. | 2016-05-24 16:09:50 GainCapital FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206. | 2016-05-24 16:09:50 GainCapital FIX Trading socket (37) | Connected. | 2016-05-24 16:09:50 GainCapital FIX Trading socket (37) | Starting TLS 1.2 connection. | 2016-05-24 16:09:50 GainCapital FIX Trading socket (37) | SSL connection established. | 2016-05-24 16:09:50 GainCapital FIX Trading: Sending the Logon message. | 2016-05-24 16:09:50 GainCapital FIX Trading: Received a sequence number that is ahead of the next expected sequence number. Expected sequence number 1. New sequence number 227 | 2016-05-24 16:09:50 GainCapital FIX Trading: Received a Logout message. Text = MsgSeqNum too low, expecting 3 but received 1 | 2016-05-24 16:09:50 GainCapital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2016-05-24 16:09:50 GainCapital FIX Trading socket (37) | SSL shutdown indicates not able to send 'close notify'. | 2016-05-24 16:09:50 GainCapital FIX Trading socket (37) | SSL has been shut down. | 2016-05-24 16:09:50 GainCapital FIX Trading socket (37) | SSL object has been freed. SSL state is now disconnected. | 2016-05-24 16:09:50 GainCapital FIX Trading socket (37) | Shutdown and closed. | 2016-05-24 16:09:50 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-05-24 16:09:50 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-05-24 16:09:50 GAIN Capital/OEC | Disconnected from the trading server. | 2016-05-24 16:09:50 GAIN Capital/OEC | Immediate disconnect from trading server detected. On next connect Logout will be sent first. | 2016-05-24 16:09:50 GAIN Capital/OEC | Disconnected. | 2016-05-24 16:09:50 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-05-24 16:09:50 GAIN Capital/OEC | Connecting to trading server prod.openecry.com. Port: 9400. | 2016-05-24 16:09:53 GainCapital FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206. | 2016-05-24 16:09:53 GainCapital FIX Trading socket (38) | Connected. | 2016-05-24 16:09:54 GainCapital FIX Trading socket (38) | Starting TLS 1.2 connection. | 2016-05-24 16:09:54 GainCapital FIX Trading socket (38) | SSL connection established. | 2016-05-24 16:09:54 GainCapital FIX Trading: Sending the Logon message. | 2016-05-24 16:09:54 GainCapital FIX Trading socket (38) | Closed. No error. | 2016-05-24 16:09:54 GainCapital FIX Trading socket (38) | SSL shutdown indicates not able to send 'close notify'. | 2016-05-24 16:09:54 GainCapital FIX Trading socket (38) | SSL has been shut down. | 2016-05-24 16:09:54 GainCapital FIX Trading socket (38) | SSL object has been freed. SSL state is now disconnected. | 2016-05-24 16:09:54 GainCapital FIX Trading socket (38) | Shutdown and closed. | 2016-05-24 16:09:54 GainCapital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2016-05-24 16:09:54 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-05-24 16:09:54 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-05-24 16:09:54 GAIN Capital/OEC | Disconnected from the trading server. | 2016-05-24 16:09:54 GAIN Capital/OEC | Disconnected. | 2016-05-24 16:09:54 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-05-24 16:09:54 GAIN Capital/OEC | Connecting to trading server prod.openecry.com. Port: 9400. | 2016-05-24 16:09:57 GainCapital FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206. | 2016-05-24 16:09:57 GainCapital FIX Trading socket (39) | Connected. | 2016-05-24 16:09:57 GainCapital FIX Trading socket (39) | Starting TLS 1.2 connection. | 2016-05-24 16:09:57 GainCapital FIX Trading socket (39) | SSL connection established. | 2016-05-24 16:09:57 GainCapital FIX Trading: Sending the Logon message. | 2016-05-24 16:09:57 GainCapital FIX Trading: Received a sequence number that is ahead of the next expected sequence number. Expected sequence number 1. New sequence number 228 | 2016-05-24 16:09:57 GainCapital FIX Trading | Connected to trading server. | 2016-05-24 16:09:57 GAIN Capital/OEC | Connecting to market data server prod.openecry.com:9301. | 2016-05-24 16:09:57 GainCapital FAST Data socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206. | 2016-05-24 16:09:57 GainCapital FIX Trading: Received a Logout message. Text = User temporarily locked out | 2016-05-24 16:09:57 GainCapital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2016-05-24 16:09:57 GainCapital FIX Trading socket (39) | SSL shutdown indicates not able to send 'close notify'. | 2016-05-24 16:09:57 GainCapital FIX Trading socket (39) | SSL has been shut down. | 2016-05-24 16:09:57 GainCapital FIX Trading socket (39) | SSL object has been freed. SSL state is now disconnected. | 2016-05-24 16:09:57 GainCapital FIX Trading socket (39) | Shutdown and closed. | 2016-05-24 16:09:57 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-05-24 16:09:57 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-05-24 16:09:57 GAIN Capital/OEC | Disconnected from the trading server. | 2016-05-24 16:09:57 GAIN Capital/OEC | Immediate disconnect from trading server detected. On next connect Logout will be sent first. | 2016-05-24 16:09:57 GainCapital FAST Data socket (40) | Shutdown and closed. | 2016-05-24 16:09:58 GainCapital FAST Data: Socket connection was closed without any logout messages sent or received. | 2016-05-24 16:09:58 GAIN Capital/OEC | Disconnected from the FAST market data server. | 2016-05-24 16:09:58 GAIN Capital/OEC | Disconnected. | 2016-05-24 16:09:58 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-05-24 16:09:58 GAIN Capital/OEC | Connecting to trading server prod.openecry.com. Port: 9400. | 2016-05-24 16:10:00 GainCapital FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206. | 2016-05-24 16:10:00 GainCapital FIX Trading socket (41) | Connected. | 2016-05-24 16:10:01 GainCapital FIX Trading socket (41) | Starting TLS 1.2 connection. | 2016-05-24 16:10:01 GainCapital FIX Trading socket (41) | SSL connection established. | 2016-05-24 16:10:01 GainCapital FIX Trading: Sending the Logon message. | 2016-05-24 16:10:01 GainCapital FIX Trading socket (41) | Closed. No error. | 2016-05-24 16:10:01 GainCapital FIX Trading socket (41) | SSL shutdown indicates not able to send 'close notify'. | 2016-05-24 16:10:01 GainCapital FIX Trading socket (41) | SSL has been shut down. | 2016-05-24 16:10:01 GainCapital FIX Trading socket (41) | SSL object has been freed. SSL state is now disconnected. | 2016-05-24 16:10:01 GainCapital FIX Trading socket (41) | Shutdown and closed. | 2016-05-24 16:10:01 GainCapital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2016-05-24 16:10:01 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-05-24 16:10:01 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-05-24 16:10:01 GAIN Capital/OEC | Disconnected from the trading server. | 2016-05-24 16:10:01 GAIN Capital/OEC | Disconnected. | 2016-05-24 16:10:01 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-05-24 16:10:01 GAIN Capital/OEC | Connecting to trading server prod.openecry.com. Port: 9400. | 2016-05-24 16:10:04 GainCapital FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206. | 2016-05-24 16:10:04 GainCapital FIX Trading socket (42) | Connected. | 2016-05-24 16:10:04 GainCapital FIX Trading socket (42) | Starting TLS 1.2 connection. | 2016-05-24 16:10:04 GainCapital FIX Trading socket (42) | SSL connection established. | 2016-05-24 16:10:04 GainCapital FIX Trading: Sending the Logon message. | 2016-05-24 16:10:04 GainCapital FIX Trading: Received a sequence number that is ahead of the next expected sequence number. Expected sequence number 1. New sequence number 230 | 2016-05-24 16:10:04 GainCapital FIX Trading: Received a Logout message. Text = MsgSeqNum too low, expecting 3 but received 1 | 2016-05-24 16:10:04 GainCapital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2016-05-24 16:10:04 GainCapital FIX Trading socket (42) | SSL shutdown indicates not able to send 'close notify'. | 2016-05-24 16:10:04 GainCapital FIX Trading socket (42) | SSL has been shut down. | 2016-05-24 16:10:04 GainCapital FIX Trading socket (42) | SSL object has been freed. SSL state is now disconnected. | 2016-05-24 16:10:04 GainCapital FIX Trading socket (42) | Shutdown and closed. | 2016-05-24 16:10:04 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-05-24 16:10:04 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-05-24 16:10:04 GAIN Capital/OEC | Disconnected from the trading server. | 2016-05-24 16:10:04 GAIN Capital/OEC | Immediate disconnect from trading server detected. On next connect Logout will be sent first. | 2016-05-24 16:10:04 GAIN Capital/OEC | Disconnected. | 2016-05-24 16:10:04 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-05-24 16:10:04 GAIN Capital/OEC | Connecting to trading server prod.openecry.com. Port: 9400. | 2016-05-24 16:10:07 GainCapital FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206. | 2016-05-24 16:10:07 GainCapital FIX Trading socket (43) | Connected. | 2016-05-24 16:10:08 GainCapital FIX Trading socket (43) | Starting TLS 1.2 connection. | 2016-05-24 16:10:08 GainCapital FIX Trading socket (43) | SSL connection established. | 2016-05-24 16:10:08 GainCapital FIX Trading: Sending the Logon message. | 2016-05-24 16:10:08 GainCapital FIX Trading socket (43) | Closed. No error. | 2016-05-24 16:10:08 GainCapital FIX Trading socket (43) | SSL shutdown indicates not able to send 'close notify'. | 2016-05-24 16:10:08 GainCapital FIX Trading socket (43) | SSL has been shut down. | 2016-05-24 16:10:08 GainCapital FIX Trading socket (43) | SSL object has been freed. SSL state is now disconnected. | 2016-05-24 16:10:08 GainCapital FIX Trading socket (43) | Shutdown and closed. | 2016-05-24 16:10:08 GainCapital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2016-05-24 16:10:08 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-05-24 16:10:08 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-05-24 16:10:08 GAIN Capital/OEC | Disconnected from the trading server. | 2016-05-24 16:10:08 GAIN Capital/OEC | Disconnected. | 2016-05-24 16:10:08 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-05-24 16:10:08 GAIN Capital/OEC | Connecting to trading server prod.openecry.com. Port: 9400. | 2016-05-24 16:10:11 GainCapital FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206. | 2016-05-24 16:10:11 GainCapital FIX Trading socket (45) | Connected. | 2016-05-24 16:10:11 GainCapital FIX Trading socket (45) | Starting TLS 1.2 connection. | 2016-05-24 16:10:11 GainCapital FIX Trading socket (45) | SSL connection established. | 2016-05-24 16:10:11 GainCapital FIX Trading: Sending the Logon message. | 2016-05-24 16:10:11 GainCapital FIX Trading: Received a sequence number that is ahead of the next expected sequence number. Expected sequence number 1. New sequence number 231 | 2016-05-24 16:10:11 GainCapital FIX Trading | Connected to trading server. | 2016-05-24 16:10:11 GAIN Capital/OEC | Connecting to market data server prod.openecry.com:9301. | 2016-05-24 16:10:11 GainCapital FAST Data socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206. | 2016-05-24 16:10:11 GainCapital FIX Trading: Received a Logout message. Text = User temporarily locked out | 2016-05-24 16:10:12 GainCapital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2016-05-24 16:10:12 GainCapital FIX Trading socket (45) | SSL shutdown indicates not able to send 'close notify'. | 2016-05-24 16:10:12 GainCapital FIX Trading socket (45) | SSL has been shut down. | 2016-05-24 16:10:12 GainCapital FIX Trading socket (45) | SSL object has been freed. SSL state is now disconnected. | 2016-05-24 16:10:12 GainCapital FIX Trading socket (45) | Shutdown and closed. | 2016-05-24 16:10:12 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-05-24 16:10:12 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-05-24 16:10:12 GAIN Capital/OEC | Disconnected from the trading server. | 2016-05-24 16:10:12 GAIN Capital/OEC | Immediate disconnect from trading server detected. On next connect Logout will be sent first. | 2016-05-24 16:10:12 GainCapital FAST Data socket (46) | Shutdown and closed. | 2016-05-24 16:10:12 GainCapital FAST Data: Socket connection was closed without any logout messages sent or received. | 2016-05-24 16:10:12 GAIN Capital/OEC | Disconnected from the FAST market data server. | 2016-05-24 16:10:12 GAIN Capital/OEC | Disconnected. | 2016-05-24 16:10:12 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-05-24 16:10:12 GAIN Capital/OEC | Connecting to trading server prod.openecry.com. Port: 9400. | 2016-05-24 16:10:14 GainCapital FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206. | 2016-05-24 16:10:14 GainCapital FIX Trading socket (47) | Connected. | 2016-05-24 16:10:15 GainCapital FIX Trading socket (47) | Starting TLS 1.2 connection. | 2016-05-24 16:10:15 GainCapital FIX Trading socket (47) | SSL connection established. | 2016-05-24 16:10:15 GainCapital FIX Trading: Sending the Logon message. | 2016-05-24 16:10:15 GainCapital FIX Trading socket (47) | Closed. No error. | 2016-05-24 16:10:15 GainCapital FIX Trading socket (47) | SSL shutdown indicates not able to send 'close notify'. | 2016-05-24 16:10:15 GainCapital FIX Trading socket (47) | SSL has been shut down. | 2016-05-24 16:10:15 GainCapital FIX Trading socket (47) | SSL object has been freed. SSL state is now disconnected. | 2016-05-24 16:10:15 GainCapital FIX Trading socket (47) | Shutdown and closed. | 2016-05-24 16:10:15 GainCapital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2016-05-24 16:10:15 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-05-24 16:10:15 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-05-24 16:10:15 GAIN Capital/OEC | Disconnected from the trading server. | 2016-05-24 16:10:15 GAIN Capital/OEC | Disconnected. | 2016-05-24 16:10:16 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-05-24 16:10:16 GAIN Capital/OEC | Connecting to trading server prod.openecry.com. Port: 9400. | 2016-05-24 16:10:18 GainCapital FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206. | 2016-05-24 16:10:18 GainCapital FIX Trading socket (48) | Connected. | 2016-05-24 16:10:19 GainCapital FIX Trading socket (48) | Starting TLS 1.2 connection. | 2016-05-24 16:10:19 GainCapital FIX Trading socket (48) | SSL connection established. | 2016-05-24 16:10:19 GainCapital FIX Trading: Sending the Logon message. | 2016-05-24 16:10:19 GainCapital FIX Trading: Received a sequence number that is ahead of the next expected sequence number. Expected sequence number 1. New sequence number 233 | 2016-05-24 16:10:19 GainCapital FIX Trading: Received a Logout message. Text = MsgSeqNum too low, expecting 3 but received 1 | 2016-05-24 16:10:19 GainCapital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2016-05-24 16:10:19 GainCapital FIX Trading socket (48) | SSL shutdown indicates not able to send 'close notify'. | 2016-05-24 16:10:19 GainCapital FIX Trading socket (48) | SSL has been shut down. | 2016-05-24 16:10:19 GainCapital FIX Trading socket (48) | SSL object has been freed. SSL state is now disconnected. | 2016-05-24 16:10:19 GainCapital FIX Trading socket (48) | Shutdown and closed. | 2016-05-24 16:10:19 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-05-24 16:10:19 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-05-24 16:10:19 GAIN Capital/OEC | Disconnected from the trading server. | 2016-05-24 16:10:19 GAIN Capital/OEC | Immediate disconnect from trading server detected. On next connect Logout will be sent first. | 2016-05-24 16:10:19 GAIN Capital/OEC | Disconnected. | 2016-05-24 16:10:19 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-05-24 16:10:19 GAIN Capital/OEC | Connecting to trading server prod.openecry.com. Port: 9400. | 2016-05-24 16:10:22 GainCapital FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206. | 2016-05-24 16:10:22 GainCapital FIX Trading socket (49) | Connected. | 2016-05-24 16:10:22 GainCapital FIX Trading socket (49) | Starting TLS 1.2 connection. | 2016-05-24 16:10:22 GainCapital FIX Trading socket (49) | SSL connection established. | 2016-05-24 16:10:22 GainCapital FIX Trading: Sending the Logon message. | 2016-05-24 16:10:22 GainCapital FIX Trading socket (49) | Closed. No error. | 2016-05-24 16:10:22 GainCapital FIX Trading socket (49) | SSL shutdown indicates not able to send 'close notify'. | 2016-05-24 16:10:22 GainCapital FIX Trading socket (49) | SSL has been shut down. | 2016-05-24 16:10:22 GainCapital FIX Trading socket (49) | SSL object has been freed. SSL state is now disconnected. | 2016-05-24 16:10:22 GainCapital FIX Trading socket (49) | Shutdown and closed. | 2016-05-24 16:10:22 GainCapital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2016-05-24 16:10:22 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-05-24 16:10:22 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-05-24 16:10:22 GAIN Capital/OEC | Disconnected from the trading server. | 2016-05-24 16:10:22 GAIN Capital/OEC | Disconnected. | 2016-05-24 16:10:23 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-05-24 16:10:23 GAIN Capital/OEC | Connecting to trading server prod.openecry.com. Port: 9400. | 2016-05-24 16:10:25 GainCapital FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206. | 2016-05-24 16:10:25 GainCapital FIX Trading socket (50) | Connected. | 2016-05-24 16:10:26 GainCapital FIX Trading socket (50) | Starting TLS 1.2 connection. | 2016-05-24 16:10:26 GainCapital FIX Trading socket (50) | SSL connection established. | 2016-05-24 16:10:26 GainCapital FIX Trading: Sending the Logon message. | 2016-05-24 16:10:26 GainCapital FIX Trading: Received a sequence number that is ahead of the next expected sequence number. Expected sequence number 1. New sequence number 234 | 2016-05-24 16:10:26 GainCapital FIX Trading | Connected to trading server. | 2016-05-24 16:10:26 GAIN Capital/OEC | Connecting to market data server prod.openecry.com:9301. | 2016-05-24 16:10:26 GainCapital FAST Data socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206. | 2016-05-24 16:10:26 GainCapital FIX Trading: Received a Logout message. Text = User temporarily locked out | 2016-05-24 16:10:26 GainCapital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2016-05-24 16:10:26 GainCapital FIX Trading socket (50) | SSL shutdown indicates not able to send 'close notify'. | 2016-05-24 16:10:26 GainCapital FIX Trading socket (50) | SSL has been shut down. | 2016-05-24 16:10:26 GainCapital FIX Trading socket (50) | SSL object has been freed. SSL state is now disconnected. | 2016-05-24 16:10:26 GainCapital FIX Trading socket (50) | Shutdown and closed. | 2016-05-24 16:10:26 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-05-24 16:10:26 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-05-24 16:10:26 GAIN Capital/OEC | Disconnected from the trading server. | 2016-05-24 16:10:26 GAIN Capital/OEC | Immediate disconnect from trading server detected. On next connect Logout will be sent first. | 2016-05-24 16:10:26 GainCapital FAST Data socket (51) | Shutdown and closed. | 2016-05-24 16:10:26 GainCapital FAST Data: Socket connection was closed without any logout messages sent or received. | 2016-05-24 16:10:26 GAIN Capital/OEC | Disconnected from the FAST market data server. | 2016-05-24 16:10:26 GAIN Capital/OEC | Disconnected. | 2016-05-24 16:10:26 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-05-24 16:10:26 GAIN Capital/OEC | Connecting to trading server prod.openecry.com. Port: 9400. | 2016-05-24 16:10:29 GainCapital FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206. | 2016-05-24 16:10:29 GainCapital FIX Trading socket (52) | Connected. | 2016-05-24 16:10:29 GainCapital FIX Trading socket (52) | Starting TLS 1.2 connection. | 2016-05-24 16:10:29 GainCapital FIX Trading socket (52) | SSL connection established. | 2016-05-24 16:10:29 GainCapital FIX Trading: Sending the Logon message. | 2016-05-24 16:10:29 GainCapital FIX Trading socket (52) | Closed. No error. | 2016-05-24 16:10:29 GainCapital FIX Trading socket (52) | SSL shutdown indicates not able to send 'close notify'. | 2016-05-24 16:10:29 GainCapital FIX Trading socket (52) | SSL has been shut down. | 2016-05-24 16:10:29 GainCapital FIX Trading socket (52) | SSL object has been freed. SSL state is now disconnected. | 2016-05-24 16:10:29 GainCapital FIX Trading socket (52) | Shutdown and closed. | 2016-05-24 16:10:29 GainCapital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2016-05-24 16:10:29 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-05-24 16:10:29 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-05-24 16:10:29 GAIN Capital/OEC | Disconnected from the trading server. | 2016-05-24 16:10:29 GAIN Capital/OEC | Disconnected. | 2016-05-24 16:10:29 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-05-24 16:10:29 GAIN Capital/OEC | Connecting to trading server prod.openecry.com. Port: 9400. | 2016-05-24 16:10:32 GainCapital FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206. | 2016-05-24 16:10:32 GainCapital FIX Trading socket (53) | Connected. | 2016-05-24 16:10:33 GainCapital FIX Trading socket (53) | Starting TLS 1.2 connection. | 2016-05-24 16:10:33 GainCapital FIX Trading socket (53) | SSL connection established. | 2016-05-24 16:10:33 GainCapital FIX Trading: Sending the Logon message. | 2016-05-24 16:10:33 GainCapital FIX Trading: Received a sequence number that is ahead of the next expected sequence number. Expected sequence number 1. New sequence number 236 | 2016-05-24 16:10:33 GainCapital FIX Trading: Received a Logout message. Text = MsgSeqNum too low, expecting 3 but received 1 | 2016-05-24 16:10:33 GainCapital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2016-05-24 16:10:33 GainCapital FIX Trading socket (53) | SSL shutdown indicates not able to send 'close notify'. | 2016-05-24 16:10:33 GainCapital FIX Trading socket (53) | SSL has been shut down. | 2016-05-24 16:10:33 GainCapital FIX Trading socket (53) | SSL object has been freed. SSL state is now disconnected. | 2016-05-24 16:10:33 GainCapital FIX Trading socket (53) | Shutdown and closed. | 2016-05-24 16:10:33 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-05-24 16:10:33 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-05-24 16:10:33 GAIN Capital/OEC | Disconnected from the trading server. | 2016-05-24 16:10:33 GAIN Capital/OEC | Immediate disconnect from trading server detected. On next connect Logout will be sent first. | 2016-05-24 16:10:33 GAIN Capital/OEC | Disconnected. | 2016-05-24 16:10:33 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-05-24 16:10:33 GAIN Capital/OEC | Connecting to trading server prod.openecry.com. Port: 9400. | 2016-05-24 16:10:36 GainCapital FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206. | 2016-05-24 16:10:36 GainCapital FIX Trading socket (54) | Connected. | 2016-05-24 16:10:36 GainCapital FIX Trading socket (54) | Starting TLS 1.2 connection. | 2016-05-24 16:10:36 GainCapital FIX Trading socket (54) | SSL connection established. | 2016-05-24 16:10:36 GainCapital FIX Trading: Sending the Logon message. | 2016-05-24 16:10:36 GainCapital FIX Trading socket (54) | Closed. No error. | 2016-05-24 16:10:36 GainCapital FIX Trading socket (54) | SSL shutdown indicates not able to send 'close notify'. | 2016-05-24 16:10:36 GainCapital FIX Trading socket (54) | SSL has been shut down. | 2016-05-24 16:10:36 GainCapital FIX Trading socket (54) | SSL object has been freed. SSL state is now disconnected. | 2016-05-24 16:10:36 GainCapital FIX Trading socket (54) | Shutdown and closed. | 2016-05-24 16:10:36 GainCapital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2016-05-24 16:10:36 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-05-24 16:10:36 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-05-24 16:10:36 GAIN Capital/OEC | Disconnected from the trading server. | 2016-05-24 16:10:36 GAIN Capital/OEC | Disconnected. | 2016-05-24 16:10:36 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-05-24 16:10:36 GAIN Capital/OEC | Connecting to trading server prod.openecry.com. Port: 9400. | 2016-05-24 16:10:40 GainCapital FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206. | 2016-05-24 16:10:40 GainCapital FIX Trading socket (55) | Connected. | 2016-05-24 16:10:40 GainCapital FIX Trading socket (55) | Starting TLS 1.2 connection. | 2016-05-24 16:10:40 GainCapital FIX Trading socket (55) | SSL connection established. | 2016-05-24 16:10:40 GainCapital FIX Trading: Sending the Logon message. | 2016-05-24 16:10:40 GainCapital FIX Trading: Received a sequence number that is ahead of the next expected sequence number. Expected sequence number 1. New sequence number 237 | 2016-05-24 16:10:40 GainCapital FIX Trading | Connected to trading server. | 2016-05-24 16:10:40 GAIN Capital/OEC | Connecting to market data server prod.openecry.com:9301. | 2016-05-24 16:10:40 GainCapital FAST Data socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206. | 2016-05-24 16:10:40 GainCapital FIX Trading: Received a Logout message. Text = User temporarily locked out | 2016-05-24 16:10:40 GainCapital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2016-05-24 16:10:40 GainCapital FIX Trading socket (55) | SSL shutdown indicates not able to send 'close notify'. | 2016-05-24 16:10:40 GainCapital FIX Trading socket (55) | SSL has been shut down. | 2016-05-24 16:10:40 GainCapital FIX Trading socket (55) | SSL object has been freed. SSL state is now disconnected. | 2016-05-24 16:10:40 GainCapital FIX Trading socket (55) | Shutdown and closed. | 2016-05-24 16:10:40 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-05-24 16:10:40 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-05-24 16:10:40 GAIN Capital/OEC | Disconnected from the trading server. | 2016-05-24 16:10:40 GAIN Capital/OEC | Immediate disconnect from trading server detected. On next connect Logout will be sent first. | 2016-05-24 16:10:40 GainCapital FAST Data socket (56) | Shutdown and closed. | 2016-05-24 16:10:40 GainCapital FAST Data: Socket connection was closed without any logout messages sent or received. | 2016-05-24 16:10:40 GAIN Capital/OEC | Disconnected from the FAST market data server. | 2016-05-24 16:10:40 GAIN Capital/OEC | Disconnected. | 2016-05-24 16:10:40 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-05-24 16:10:40 GAIN Capital/OEC | Connecting to trading server prod.openecry.com. Port: 9400. | 2016-05-24 16:10:43 GainCapital FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206. | 2016-05-24 16:10:43 GainCapital FIX Trading socket (57) | Connected. | 2016-05-24 16:10:43 GainCapital FIX Trading socket (57) | Starting TLS 1.2 connection. | 2016-05-24 16:10:43 GainCapital FIX Trading socket (57) | SSL connection established. | 2016-05-24 16:10:44 GainCapital FIX Trading: Sending the Logon message. | 2016-05-24 16:10:44 GainCapital FIX Trading socket (57) | Closed. No error. | 2016-05-24 16:10:44 GainCapital FIX Trading socket (57) | SSL shutdown indicates not able to send 'close notify'. | 2016-05-24 16:10:44 GainCapital FIX Trading socket (57) | SSL has been shut down. | 2016-05-24 16:10:44 GainCapital FIX Trading socket (57) | SSL object has been freed. SSL state is now disconnected. | 2016-05-24 16:10:44 GainCapital FIX Trading socket (57) | Shutdown and closed. | 2016-05-24 16:10:44 GainCapital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2016-05-24 16:10:44 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-05-24 16:10:44 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-05-24 16:10:44 GAIN Capital/OEC | Disconnected from the trading server. | 2016-05-24 16:10:44 GAIN Capital/OEC | Disconnected. | 2016-05-24 16:10:44 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-05-24 16:10:44 |
| [2016-05-25 03:29:54] |
You really are going to have to rely upon Gain Capital for support for this. It is not something we can help with. These are the relevant messages: GainCapital FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206. | 2016-05-24 16:10:43 GainCapital FIX Trading socket (57) | Connected. | 2016-05-24 16:10:43 GainCapital FIX Trading socket (57) | Starting TLS 1.2 connection. | 2016-05-24 16:10:43 GainCapital FIX Trading socket (57) | SSL connection established. | 2016-05-24 16:10:44 GainCapital FIX Trading: Sending the Logon message. | 2016-05-24 16:10:44 GainCapital FIX Trading socket (57) | Closed. No error. | 2016-05-24 16:10:44 Here is the related documentation for this: http://www.sierrachart.com/index.php?page=doc/GAINCapitalOECTrader.php#ConnectionProblem Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
