Date/Time: Tue, 29 Sep 2026 08:04:05 +0000
Data Feeds and products to Trade
View Count: 1527
[2016-05-20 07:18:32]
User240686 - Posts: 86
I am currently on Package 3 with AMP.
If I want to trade CFD and Forex on Sierra platform and have package 5 what is required. Can I log into Sierra once and access all this or would i need a Forex account with say FXCM and a Futures account with AMP...
what the best and easiest way to accommodate this and is it best to get the platform directly from sierra
[2016-05-20 07:39:11]
We recommend that you use LMAX and that is supported through AMP . We are confirming this now.
So you just need to have AMP set you up with an LMAX account and we assign your account number to our LMAX order routing connection and you can start trading. It is very easy.
Date Time Of Last Edit: 2016-05-20 07:39:30
[2016-05-20 07:56:23]
ok so when you say confirming. its not set up yet
[2016-05-20 07:57:54]
LMAX is for Forex NOT CFD....
So my original question still stands.
What options are available to me?
Thanks you
[2016-05-20 08:11:36]
LMAX does have many CFD contracts as well.
Refer to:
https://www.lmax.com/doc/LMAX-Instruments.csv
[2016-05-20 08:27:02]
ok...i contacted AMP and they said not. so I am caught between you saying its supported and them telling me its not...and they tell me its not for sierra?
[2016-05-20 08:47:02]
We are checking on this and we will get back to you.
[2016-05-20 18:31:13]
We have not yet heard from AMP. So maybe LMAX is not available through them at this time.
However, you could always open up an account with LMAX and use it. Just follow through the instructions here:
http://www.sierrachart.com/index.php?page=doc/LMAX.php
Date Time Of Last Edit: 2016-05-20 18:32:04
