Date/Time: Tue, 29 Sep 2026 08:03:59 +0000
Display Chart Values at the cursor w/o Crosshair?
View Count: 3877
| [2016-05-20 03:33:57] |
| User14953 - Posts: 268 |
Hi, Can version.1400 display Chart Values like Date Time YOHLCV at the cursor location while using tools other than the Chart Values/Crosshair? eg SC version.87 displayed during Trend Line, Horizontal Line, Vertical Line, Fan, Type Text, Fib, Chart Calculator... Instructions to Use Compact Tool Values Window Equivalent to Old Status Bar New Control Bar to replace ToolBar and Status Bar | Post: 66601 |
| [2016-05-20 17:57:19] |
Yes. This can be done by selecting Global Settings >> Tool Settings >> Chart Values. Select Always On When Using Other Tools in the list box. Here are complete details: http://www.sierrachart.com/index.php?page=doc/doc_Tools.html#ChartValuesToolSettings There are various options that may also be helpful as well to do what you need. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
