Date/Time: Tue, 29 Sep 2026 08:49:19 +0000
cqg
View Count: 1175
[2016-05-18 16:23:07]
User948258 - Posts: 4
i am having trouble setting up the cqg login, it gets hung up connecting, can you guys help?
[2016-05-18 16:32:05]
Provide a copy of the Message Log by following these instructions:
http://www.sierrachart.com/index.php?l=PostingInformation.php#MessageLog
[2016-05-18 16:40:39]
Selected Data/Trading service: CQG FIX Trading
Username for Data/Trading service:
Log:
Software version: 1297 | 2016-05-18 17:28:44
Uses New Spreadsheets | 2016-05-18 17:28:44
Usage end date: 2016-06-06 | 2016-05-18 17:28:44
Enabled for: Advanced Features. | 2016-05-18 17:28:44
Enabled for: Sierra Chart Historical Data Service. | 2016-05-18 17:28:44
Allow Support for Sierra Chart Data Feeds is enabled. | 2016-05-18 17:28:44
Current selected Data/Trading service: Rithmic Trading | 2016-05-18 17:28:44
Chart Update Interval: 500 | 2016-05-18 17:28:44
Time Zone: +02:00:00 (CET+01CEST+01,M3.5.0/02:00,M10.5.0/03:00) | 2016-05-18 17:28:44
2016-05-18 17:28:44 Local computer time | 2016-05-18 17:28:44
2016-05-18 15:28:44 Local computer time in UTC | 2016-05-18 17:28:44
2016-05-18 17:28:44 Local computer time in SC Time Zone | 2016-05-18 17:28:44
2016-05-18 15:28:44 Server time in UTC | 2016-05-18 17:28:44
Local computer UTC time and Server UTC time difference: 2 seconds. | 2016-05-18 17:28:44
Program path: C:\SierraChart\ | 2016-05-18 17:28:44
Data Files path: C:\SierraChart\Data\ | 2016-05-18 17:28:44
OS Version Number: 6.2 | 2016-05-18 17:28:44
Locale Information: C | 2016-05-18 17:28:44
CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6912. | 2016-05-18 17:41:00
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214 | 2016-05-18 17:41:00
socket (59) | Connected. | 2016-05-18 17:41:00
CQG FIX: Sending the Logon message. | 2016-05-18 17:41:00
CQG FIX: Received a Logout message. Text = Username or password is incorrect. | 2016-05-18 17:41:01
CQG FIX: Sending a Logout message. Text = Received Logout message. | 2016-05-18 17:41:01
socket (59) | Shutdown and closed. | 2016-05-18 17:41:01
CQG FIX: Logged out and disconnected. | 2016-05-18 17:41:01
CQG FIX: Disconnected. | 2016-05-18 17:41:01
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-05-18 17:41:01
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-05-18 17:41:01
CQG FIX: DisconnectFIX called. | 2016-05-18 17:41:01
CQG FIX Trading | Disconnected. | 2016-05-18 17:41:01
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-05-18 17:41:01
CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6912. | 2016-05-18 17:41:06
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214 | 2016-05-18 17:41:06
socket (60) | Connected. | 2016-05-18 17:41:06
CQG FIX: Sending the Logon message. | 2016-05-18 17:41:06
CQG FIX: Received a Logout message. Text = Username or password is incorrect. | 2016-05-18 17:41:06
CQG FIX: Sending a Logout message. Text = Received Logout message. | 2016-05-18 17:41:06
socket (60) | Shutdown and closed. | 2016-05-18 17:41:06
CQG FIX: Logged out and disconnected. | 2016-05-18 17:41:06
CQG FIX: Disconnected. | 2016-05-18 17:41:06
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-05-18 17:41:06
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-05-18 17:41:06
CQG FIX: DisconnectFIX called. | 2016-05-18 17:41:06
CQG FIX Trading | Disconnected. | 2016-05-18 17:41:06
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-05-18 17:41:06
CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6912. | 2016-05-18 17:41:11
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214 | 2016-05-18 17:41:11
socket (61) | Connected. | 2016-05-18 17:41:11
CQG FIX: Sending the Logon message. | 2016-05-18 17:41:12
CQG FIX: Received a Logout message. Text = Username or password is incorrect. | 2016-05-18 17:41:12
CQG FIX: Sending a Logout message. Text = Received Logout message. | 2016-05-18 17:41:12
socket (61) | Shutdown and closed. | 2016-05-18 17:41:12
CQG FIX: Logged out and disconnected. | 2016-05-18 17:41:12
CQG FIX: Disconnected. | 2016-05-18 17:41:12
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-05-18 17:41:12
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-05-18 17:41:12
CQG FIX: DisconnectFIX called. | 2016-05-18 17:41:12
CQG FIX Trading | Disconnected. | 2016-05-18 17:41:12
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-05-18 17:41:12
CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6912. | 2016-05-18 17:41:17
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214 | 2016-05-18 17:41:17
socket (62) | Connected. | 2016-05-18 17:41:17
CQG FIX: Sending the Logon message. | 2016-05-18 17:41:17
CQG FIX: Received a Logout message. Text = Username or password is incorrect. | 2016-05-18 17:41:17
CQG FIX: Sending a Logout message. Text = Received Logout message. | 2016-05-18 17:41:17
socket (62) | Shutdown and closed. | 2016-05-18 17:41:17
CQG FIX: Logged out and disconnected. | 2016-05-18 17:41:17
CQG FIX: Disconnected. | 2016-05-18 17:41:17
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-05-18 17:41:17
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-05-18 17:41:17
CQG FIX: DisconnectFIX called. | 2016-05-18 17:41:17
CQG FIX Trading | Disconnected. | 2016-05-18 17:41:17
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-05-18 17:41:17
CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6912. | 2016-05-18 17:41:22
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214 | 2016-05-18 17:41:22
socket (63) | Connected. | 2016-05-18 17:41:22
CQG FIX: Sending the Logon message. | 2016-05-18 17:41:23
CQG FIX: Received a Logout message. Text = Username or password is incorrect. | 2016-05-18 17:41:23
CQG FIX: Sending a Logout message. Text = Received Logout message. | 2016-05-18 17:41:23
socket (63) | Shutdown and closed. | 2016-05-18 17:41:23
CQG FIX: Logged out and disconnected. | 2016-05-18 17:41:23
CQG FIX: Disconnected. | 2016-05-18 17:41:23
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-05-18 17:41:23
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-05-18 17:41:23
CQG FIX: DisconnectFIX called. | 2016-05-18 17:41:23
CQG FIX Trading | Disconnected. | 2016-05-18 17:41:23
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-05-18 17:41:23
CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6912. | 2016-05-18 17:41:28
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214 | 2016-05-18 17:41:28
socket (64) | Connected. | 2016-05-18 17:41:28
CQG FIX: Sending the Logon message. | 2016-05-18 17:41:28
CQG FIX: Received a Logout message. Text = Too many logon attempts. Please contact your FCM. | 2016-05-18 17:41:28
CQG FIX: Sending a Logout message. Text = Received Logout message. | 2016-05-18 17:41:28
socket (64) | Shutdown and closed. | 2016-05-18 17:41:28
CQG FIX: Logged out and disconnected. | 2016-05-18 17:41:28
CQG FIX: Disconnected. | 2016-05-18 17:41:28
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-05-18 17:41:28
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-05-18 17:41:28
CQG FIX: DisconnectFIX called. | 2016-05-18 17:41:28
CQG FIX Trading | Disconnected. | 2016-05-18 17:41:28
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-05-18 17:41:28
CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6912. | 2016-05-18 17:41:33
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214 | 2016-05-18 17:41:33
socket (65) | Connected. | 2016-05-18 17:41:33
CQG FIX: Sending the Logon message. | 2016-05-18 17:41:34
CQG FIX: Received a Logout message. Text = Too many logon attempts. Please contact your FCM. | 2016-05-18 17:41:34
CQG FIX: Sending a Logout message. Text = Received Logout message. | 2016-05-18 17:41:34
socket (65) | Shutdown and closed. | 2016-05-18 17:41:34
CQG FIX: Logged out and disconnected. | 2016-05-18 17:41:34
CQG FIX: Disconnected. | 2016-05-18 17:41:34
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-05-18 17:41:34
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-05-18 17:41:34
CQG FIX: DisconnectFIX called. | 2016-05-18 17:41:34
CQG FIX Trading | Disconnected. | 2016-05-18 17:41:34
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-05-18 17:41:34
CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6912. | 2016-05-18 17:41:39
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214 | 2016-05-18 17:41:39
socket (66) | Connected. | 2016-05-18 17:41:39
CQG FIX: Sending the Logon message. | 2016-05-18 17:41:39
CQG FIX: Received a Logout message. Text = Too many logon attempts. Please contact your FCM. | 2016-05-18 17:41:39
CQG FIX: Sending a Logout message. Text = Received Logout message. | 2016-05-18 17:41:39
socket (66) | Shutdown and closed. | 2016-05-18 17:41:39
CQG FIX: Logged out and disconnected. | 2016-05-18 17:41:39
CQG FIX: Disconnected. | 2016-05-18 17:41:39
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-05-18 17:41:39
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-05-18 17:41:39
CQG FIX: DisconnectFIX called. | 2016-05-18 17:41:39
CQG FIX Trading | Disconnected. | 2016-05-18 17:41:39
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-05-18 17:41:39
CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6912. | 2016-05-18 17:41:44
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214 | 2016-05-18 17:41:44
socket (67) | Connected. | 2016-05-18 17:41:44
CQG FIX: Sending the Logon message. | 2016-05-18 17:41:45
CQG FIX: Received a Logout message. Text = Too many logon attempts. Please contact your FCM. | 2016-05-18 17:41:45
CQG FIX: Sending a Logout message. Text = Received Logout message. | 2016-05-18 17:41:45
socket (67) | Shutdown and closed. | 2016-05-18 17:41:45
CQG FIX: Logged out and disconnected. | 2016-05-18 17:41:45
CQG FIX: Disconnected. | 2016-05-18 17:41:45
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-05-18 17:41:45
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-05-18 17:41:45
CQG FIX: DisconnectFIX called. | 2016-05-18 17:41:45
CQG FIX Trading | Disconnected. | 2016-05-18 17:41:45
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-05-18 17:41:45
CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6912. | 2016-05-18 17:41:50
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214 | 2016-05-18 17:41:50
socket (68) | Connected. | 2016-05-18 17:41:50
CQG FIX: Sending the Logon message. | 2016-05-18 17:41:50
CQG FIX: Received a Logout message. Text = Too many logon attempts. Please contact your FCM. | 2016-05-18 17:41:50
CQG FIX: Sending a Logout message. Text = Received Logout message. | 2016-05-18 17:41:50
socket (68) | Shutdown and closed. | 2016-05-18 17:41:50
CQG FIX: Logged out and disconnected. | 2016-05-18 17:41:50
CQG FIX: Disconnected. | 2016-05-18 17:41:50
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-05-18 17:41:50
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-05-18 17:41:50
CQG FIX: DisconnectFIX called. | 2016-05-18 17:41:50
CQG FIX Trading | Disconnected. | 2016-05-18 17:41:50
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-05-18 17:41:50
CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6912. | 2016-05-18 17:41:55
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214 | 2016-05-18 17:41:55
socket (69) | Connected. | 2016-05-18 17:41:55
CQG FIX: Sending the Logon message. | 2016-05-18 17:41:56
CQG FIX: Received a Logout message. Text = Too many logon attempts. Please contact your FCM. | 2016-05-18 17:41:56
CQG FIX: Sending a Logout message. Text = Received Logout message. | 2016-05-18 17:41:56
socket (69) | Shutdown and closed. | 2016-05-18 17:41:56
CQG FIX: Logged out and disconnected. | 2016-05-18 17:41:56
CQG FIX: Disconnected. | 2016-05-18 17:41:56
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-05-18 17:41:56
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-05-18 17:41:56
CQG FIX: DisconnectFIX called. | 2016-05-18 17:41:56
CQG FIX Trading | Disconnected. | 2016-05-18 17:41:56
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-05-18 17:41:56
CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6912. | 2016-05-18 17:42:01
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214 | 2016-05-18 17:42:01
socket (70) | Connected. | 2016-05-18 17:42:01
CQG FIX: Sending the Logon message. | 2016-05-18 17:42:01
CQG FIX: Received a Logout message. Text = Too many logon attempts. Please contact your FCM. | 2016-05-18 17:42:01
CQG FIX: Sending a Logout message. Text = Received Logout message. | 2016-05-18 17:42:01
socket (70) | Shutdown and closed. | 2016-05-18 17:42:01
CQG FIX: Logged out and disconnected. | 2016-05-18 17:42:01
CQG FIX: Disconnected. | 2016-05-18 17:42:01
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-05-18 17:42:01
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-05-18 17:42:01
CQG FIX: DisconnectFIX called. | 2016-05-18 17:42:01
CQG FIX Trading | Disconnected. | 2016-05-18 17:42:01
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-05-18 17:42:01
CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6912. | 2016-05-18 17:42:06
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214 | 2016-05-18 17:42:06
socket (71) | Connected. | 2016-05-18 17:42:06
CQG FIX: Sending the Logon message. | 2016-05-18 17:42:07
CQG FIX: Received a Logout message. Text = Too many logon attempts. Please contact your FCM. | 2016-05-18 17:42:07
CQG FIX: Sending a Logout message. Text = Received Logout message. | 2016-05-18 17:42:07
socket (71) | Shutdown and closed. | 2016-05-18 17:42:07
CQG FIX: Logged out and disconnected. | 2016-05-18 17:42:07
CQG FIX: Disconnected. | 2016-05-18 17:42:07
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-05-18 17:42:07
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-05-18 17:42:07
CQG FIX: DisconnectFIX called. | 2016-05-18 17:42:07
CQG FIX Trading | Disconnected. | 2016-05-18 17:42:07
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-05-18 17:42:07
CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6912. | 2016-05-18 17:42:12
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214 | 2016-05-18 17:42:12
socket (72) | Connected. | 2016-05-18 17:42:12
CQG FIX: Sending the Logon message. | 2016-05-18 17:42:12
CQG FIX: Received a Logout message. Text = Too many logon attempts. Please contact your FCM. | 2016-05-18 17:42:12
CQG FIX: Sending a Logout message. Text = Received Logout message. | 2016-05-18 17:42:12
socket (72) | Shutdown and closed. | 2016-05-18 17:42:12
CQG FIX: Logged out and disconnected. | 2016-05-18 17:42:12
CQG FIX: Disconnected. | 2016-05-18 17:42:12
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-05-18 17:42:12
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-05-18 17:42:12
CQG FIX: DisconnectFIX called. | 2016-05-18 17:42:12
CQG FIX Trading | Disconnected. | 2016-05-18 17:42:12
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-05-18 17:42:12
CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6912. | 2016-05-18 17:42:17
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214 | 2016-05-18 17:42:17
socket (73) | Connected. | 2016-05-18 17:42:18
CQG FIX: Sending the Logon message. | 2016-05-18 17:42:18
CQG FIX: Received a Logout message. Text = Too many logon attempts. Please contact your FCM. | 2016-05-18 17:42:18
CQG FIX: Sending a Logout message. Text = Received Logout message. | 2016-05-18 17:42:18
socket (73) | Shutdown and closed. | 2016-05-18 17:42:18
CQG FIX: Logged out and disconnected. | 2016-05-18 17:42:18
CQG FIX: Disconnected. | 2016-05-18 17:42:18
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-05-18 17:42:18
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-05-18 17:42:18
CQG FIX: DisconnectFIX called. | 2016-05-18 17:42:18
CQG FIX Trading | Disconnected. | 2016-05-18 17:42:18
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-05-18 17:42:18
CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6912. | 2016-05-18 17:42:23
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214 | 2016-05-18 17:42:23
socket (74) | Connected. | 2016-05-18 17:42:23
CQG FIX: Sending the Logon message. | 2016-05-18 17:42:23
CQG FIX: Received a Logout message. Text = Too many logon attempts. Please contact your FCM. | 2016-05-18 17:42:23
CQG FIX: Sending a Logout message. Text = Received Logout message. | 2016-05-18 17:42:23
socket (74) | Shutdown and closed. | 2016-05-18 17:42:23
CQG FIX: Logged out and disconnected. | 2016-05-18 17:42:23
CQG FIX: Disconnected. | 2016-05-18 17:42:23
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-05-18 17:42:23
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-05-18 17:42:23
CQG FIX: DisconnectFIX called. | 2016-05-18 17:42:23
CQG FIX Trading | Disconnected. | 2016-05-18 17:42:23
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-05-18 17:42:23
CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6912. | 2016-05-18 17:42:28
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214 | 2016-05-18 17:42:28
socket (75) | Connected. | 2016-05-18 17:42:29
CQG FIX: Sending the Logon message. | 2016-05-18 17:42:29
CQG FIX: Received a Logout message. Text = Too many logon attempts. Please contact your FCM. | 2016-05-18 17:42:29
CQG FIX: Sending a Logout message. Text = Received Logout message. | 2016-05-18 17:42:29
socket (75) | Shutdown and closed. | 2016-05-18 17:42:29
CQG FIX: Logged out and disconnected. | 2016-05-18 17:42:29
CQG FIX: Disconnected. | 2016-05-18 17:42:29
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-05-18 17:42:29
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-05-18 17:42:29
CQG FIX: DisconnectFIX called. | 2016-05-18 17:42:29
CQG FIX Trading | Disconnected. | 2016-05-18 17:42:29
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-05-18 17:42:29
CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6912. | 2016-05-18 17:42:34
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214 | 2016-05-18 17:42:34
socket (76) | Connected. | 2016-05-18 17:42:34
CQG FIX: Sending the Logon message. | 2016-05-18 17:42:34
CQG FIX: Received a Logout message. Text = Too many logon attempts. Please contact your FCM. | 2016-05-18 17:42:34
CQG FIX: Sending a Logout message. Text = Received Logout message. | 2016-05-18 17:42:34
socket (76) | Shutdown and closed. | 2016-05-18 17:42:34
CQG FIX: Logged out and disconnected. | 2016-05-18 17:42:34
CQG FIX: Disconnected. | 2016-05-18 17:42:34
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-05-18 17:42:34
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-05-18 17:42:34
CQG FIX: DisconnectFIX called. | 2016-05-18 17:42:34
CQG FIX Trading | Disconnected. | 2016-05-18 17:42:34
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-05-18 17:42:34
CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6912. | 2016-05-18 17:42:39
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214 | 2016-05-18 17:42:39
socket (77) | Connected. | 2016-05-18 17:42:40
CQG FIX: Sending the Logon message. | 2016-05-18 17:42:40
CQG FIX: Received a Logout message. Text = Too many logon attempts. Please contact your FCM. | 2016-05-18 17:42:40
CQG FIX: Sending a Logout message. Text = Received Logout message. | 2016-05-18 17:42:40
socket (77) | Shutdown and closed. | 2016-05-18 17:42:40
CQG FIX: Logged out and disconnected. | 2016-05-18 17:42:40
CQG FIX: Disconnected. | 2016-05-18 17:42:40
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-05-18 17:42:40
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-05-18 17:42:40
CQG FIX: DisconnectFIX called. | 2016-05-18 17:42:40
CQG FIX Trading | Disconnected. | 2016-05-18 17:42:40
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-05-18 17:42:40
CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6912. | 2016-05-18 17:42:45
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214 | 2016-05-18 17:42:45
socket (79) | Connected. | 2016-05-18 17:42:45
CQG FIX: Sending the Logon message. | 2016-05-18 17:42:45
CQG FIX: Received a Logout message. Text = Too many logon attempts. Please contact your FCM. | 2016-05-18 17:42:45
CQG FIX: Sending a Logout message. Text = Received Logout message. | 2016-05-18 17:42:45
socket (79) | Shutdown and closed. | 2016-05-18 17:42:45
CQG FIX: Logged out and disconnected. | 2016-05-18 17:42:45
CQG FIX: Disconnected. | 2016-05-18 17:42:45
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-05-18 17:42:45
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-05-18 17:42:45
CQG FIX: DisconnectFIX called. | 2016-05-18 17:42:45
CQG FIX Trading | Disconnected. | 2016-05-18 17:42:45
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-05-18 17:42:45
Date Time Of Last Edit: 2016-05-18 16:53:34
[2016-05-18 16:59:57]
Follow the instructions here to update Sierra Chart to the current version:
https://www.sierrachart.com/index.php?page=doc/download.php#FastUpdate
This is the reason for the connection problem:
Select Global Settings >> Data/Trade Service Settings. Make sure Connection Details >> Username and Password are set correctly. You need to contact your broker for those.
[2016-05-18 17:08:33]
now get this
Log:
Software version: 1415 | 2016-05-18 19:02:49
Uses New Spreadsheets | 2016-05-18 19:02:49
Usage end date: 2016-06-06 | 2016-05-18 19:02:49
Enabled for: Advanced Features. | 2016-05-18 19:02:49
Enabled for: Sierra Chart Historical Data Service. | 2016-05-18 19:02:49
Allow Support for Sierra Chart Data Feeds is enabled. | 2016-05-18 19:02:49
Current selected Data/Trading service: CQG FIX Trading | 2016-05-18 19:02:49
Chart Update Interval: 500 | 2016-05-18 19:02:49
Time Zone: +02:00:00 (CET+01CEST+01,M3.5.0/02:00,M10.5.0/03:00) | 2016-05-18 19:02:49
2016-05-18 19:03:00 Local computer time | 2016-05-18 19:02:49
2016-05-18 17:03:00 Local computer time in UTC | 2016-05-18 19:02:49
2016-05-18 19:03:00 Local computer time in SC Time Zone | 2016-05-18 19:02:49
2016-05-18 17:02:58 Server time in UTC | 2016-05-18 19:02:49
Local computer UTC time and Server UTC time difference: 2 seconds. | 2016-05-18 19:02:49
Program path: C:\SierraChart\ | 2016-05-18 19:02:49
Data Files path: C:\SierraChart\Data\ | 2016-05-18 19:02:49
OS Version Number: 6.2 | 2016-05-18 19:02:49
Locale Setting: C | 2016-05-18 19:02:49
Checking for new symbol settings for cqg | 2016-05-18 19:02:49
HTTPS connection to www.sierrachart.com:443 (0) | Resolved address sierrachart.com to IP 5.9.8.236. | 2016-05-18 19:02:49
HTTPS connection to www.sierrachart.com:443 (3) | Connected. | 2016-05-18 19:02:49
HTTPS connection to www.sierrachart.com:443 (3) | Starting TLS 1.2 connection. | 2016-05-18 19:02:49
HTTPS connection to www.sierrachart.com:443 (3) | SSL connection established. | 2016-05-18 19:02:49
Requesting symbol settings for cqg. Overwrite = on. | 2016-05-18 19:02:49
Symbol settings received. | 2016-05-18 19:02:49
Processed received symbol settings | 2016-05-18 19:02:49
Files to Open on Start up | Opening file: 0_WB_Vros_home1.cht | 2016-05-18 19:03:03
CQG FIX Trading | Using primary service for historical data for 6EZ5-CME | 2016-05-18 19:03:03
6EZ5-CME [CB] #3 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2016-05-18 19:03:03
6EZ5-CME [CB] #3 | There are no continuous futures contract symbols. Loading data normally. | 2016-05-18 19:03:03
6EM6-CME [C] Daily #2 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2016-05-18 19:03:03
6EM6-CME [C] Daily #2 | There are no continuous futures contract symbols. Loading data normally. | 2016-05-18 19:03:03
6EZ5-CME [C] 5 Min #16 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2016-05-18 19:03:03
6EZ5-CME [C] 5 Min #16 | There are no continuous futures contract symbols. Loading data normally. | 2016-05-18 19:03:03
CQG FIX Trading | Using primary service for historical data for 6EM6-CME | 2016-05-18 19:03:03
6EM6-CME [C] 30 Min #1 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2016-05-18 19:03:03
6EM6-CME [C] 30 Min #1 | There are no continuous futures contract symbols. Loading data normally. | 2016-05-18 19:03:03
FGBL-201506-Eurex [C] Daily #4 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2016-05-18 19:03:03
FGBL-201506-Eurex [C] Daily #4 | There are no continuous futures contract symbols. Loading data normally. | 2016-05-18 19:03:03
HD Request # 2 | Downloading Historical Daily chart data for 6EM6-CME. Starting date: 2016-05-17. Service: cqg | 2016-05-18 19:03:04
HD Request # 2 | Requesting historical Daily data for 6EM6-CME starting at 2016-05-16 | 2016-05-18 19:03:04
HTTP connection to ds01.ddfplus.com:80 (0) | Resolved address ds01.ddfplus.com to IP 8.18.161.123. | 2016-05-18 19:03:04
HTTP connection to ds01.ddfplus.com:80 (4) | Connected. | 2016-05-18 19:03:04
HD Request # 2 | Error downloading historical Daily data for 6EM6-CME. Error executing query: Invalid symbol
| 2016-05-18 19:03:05
HD Request # 2 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for 6EM6-CME | 2016-05-18 19:03:05
HD Request # 2 | Daily download COMPLETE for 6EM6-CME. Completion time: 1s. Unique request ID: 1 | 2016-05-18 19:03:05
Removed historical data download ID 1 | 2016-05-18 19:03:05
HD Request # 3 | Downloading Historical Daily chart data for FGBL-201506-Eurex. Starting date: 2015-03-04. Service: cqg | 2016-05-18 19:03:05
HD Request # 3 | Requesting historical Daily data for FGBL-201506-Eurex starting at 2015-03-03 | 2016-05-18 19:03:05
6EM6-CME [C] Daily #2 | Reloading chart. | 2016-05-18 19:03:05
6EM6-CME [C] Daily #2 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2016-05-18 19:03:05
6EM6-CME [C] Daily #2 | There are no continuous futures contract symbols. Loading data normally. | 2016-05-18 19:03:05
HD Request # 3 | Error downloading historical Daily data for FGBL-201506-Eurex. Error executing query: Invalid symbol
| 2016-05-18 19:03:05
HD Request # 3 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for FGBL-201506-Eurex | 2016-05-18 19:03:05
HD Request # 3 | Daily download COMPLETE for FGBL-201506-Eurex. Completion time: 0s. Unique request ID: 2 | 2016-05-18 19:03:05
Removed historical data download ID 2 | 2016-05-18 19:03:05
FGBL-201506-Eurex [C] Daily #4 | Reloading chart. | 2016-05-18 19:03:05
FGBL-201506-Eurex [C] Daily #4 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2016-05-18 19:03:05
FGBL-201506-Eurex [C] Daily #4 | There are no continuous futures contract symbols. Loading data normally. | 2016-05-18 19:03:05
CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6912. | 2016-05-18 19:03:06
HTTPS connection to www.sierrachart.com:443 (3) | SSL connection closed by remote side. | 2016-05-18 19:03:06
HTTPS connection to www.sierrachart.com:443 (3) | Connection gracefully closed by remote side. | 2016-05-18 19:03:06
HTTPS connection to www.sierrachart.com:443 (3) | SSL object has been freed. SSL state is now disconnected. | 2016-05-18 19:03:06
HTTPS connection to www.sierrachart.com:443 (3) | Shutdown and closed. | 2016-05-18 19:03:06
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214. | 2016-05-18 19:03:06
socket (5) | Connected. | 2016-05-18 19:03:06
CQG FIX: Sending the Logon message. | 2016-05-18 19:03:06
CQG FIX Trading | Connected to trading server. | 2016-05-18 19:03:06
CQG FIX Trading | Connecting to market data server api.cqg.com | 2016-05-18 19:03:06
CQG WebAPI | Connecting to websocket server. | 2016-05-18 19:03:06
CQG FIX - FCM name: Phillip | 2016-05-18 19:03:07
CQG WebAPI websocket (0) | Resolved address api.geo.cqg.com to IP 216.219.76.101. | 2016-05-18 19:03:07
CQG WebAPI websocket (6) | Connected. | 2016-05-18 19:03:07
CQG WebAPI websocket (6) | Starting SSL 3/2 connection. | 2016-05-18 19:03:07
CQG WebAPI websocket (6) | SSL connection established. | 2016-05-18 19:03:07
CQG WebAPI | Opening websocket. | 2016-05-18 19:03:07
CQG WebAPI | Sending websocket handshake. | 2016-05-18 19:03:07
CQG WebAPI | Received websocket handshake acknowledgment. | 2016-05-18 19:03:07
CQG WebAPI | Web socket state is now open. | 2016-05-18 19:03:07
CQG FIX Trading | Websocket connected. | 2016-05-18 19:03:07
CQG FIX Trading | Sending market data logon message. | 2016-05-18 19:03:07
CQG FIX Trading | Market data logon unsuccessful. Server message: Trader is not enabled to use SierraChartData. Please contact your FCM. | 2016-05-18 19:03:07 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-05-18 19:03:07
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-05-18 19:03:07
CQG FIX: DisconnectFIX called. | 2016-05-18 19:03:07
CQG FIX: Sending a Logout message. | 2016-05-18 19:03:07
CQG WebAPI websocket (6) | SSL shutdown indicates not able to send 'close notify'. | 2016-05-18 19:03:07
CQG WebAPI websocket (6) | SSL has been shut down. | 2016-05-18 19:03:07
CQG WebAPI websocket (6) | SSL object has been freed. SSL state is now disconnected. | 2016-05-18 19:03:07
CQG WebAPI websocket (6) | Shutdown and closed. | 2016-05-18 19:03:07
CQG WebAPI | Websocket closed. | 2016-05-18 19:03:07
CQG FIX Trading | Websocket closed. | 2016-05-18 19:03:07
CQG FIX Trading | Disconnected. | 2016-05-18 19:03:07
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-05-18 19:03:07
CQG FIX: Received a Logout message. Text = NormalLogoutInitiatedByCounterparty | 2016-05-18 19:03:07
socket (5) | Shutdown and closed. | 2016-05-18 19:03:07
CQG FIX: Disconnected. | 2016-05-18 19:03:07
(Removed unnecessary log data)
Date Time Of Last Edit: 2016-05-18 17:21:23
[2016-05-18 17:19:57]
Contact your broker and let them know you are receiving this:
CQG FIX Trading | Market data logon unsuccessful. Server message: Trader is not enabled to use SierraChartData. Please contact your FCM. | 2016-05-18 19:03:15 *
They will need to contact CQG for help if necessary.
