Date/Time: Wed, 08 May 2024 15:39:49 +0000
EURGBP Futures contract data?
View Count: 1717
[2016-05-17 14:39:13] |
bootsy - Posts: 63 |
Hi there, Trying to track down EURGBP futures data and cannot see any in the SC/Interactive Brokers market list. Am pretty sure (not certain) that this is a market. Do you know what the symbol code is? Thanks, Bootsyjam |
[2016-05-17 16:59:26] |
It is GBP-######-GLOBEX and is listed in File >> Find Symbol >> Futures.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-05-17 16:59:45
[2016-05-18 07:47:49] |
Hi there, Thanks for the reply. I already use the GBP symbol and it's GBP/USD in the same way that EUR is EUR/USD. Very confused by all this! Regards, Bootsyjam |
[2016-05-18 08:23:22] |
We apologize, we did not pay close enough attention. What is the symbol for this in Trader Workstation? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-05-18 09:04:11] |
Hi there, If you go to this page https://www.interactivebrokers.com/en/index.php?f=2222&ns=T&exch=globex&showcategories=FUTGRP and scroll down to European Monetary Union Euro, then these are all the different ones (EURAUD/EURCHF etc). It appears from my reading of it that RP is the symbol for EURGBP? Regards, Bootsyjam |
[2016-05-18 14:22:25] |
chisel - Posts: 23 |
bootsy, Yes, RP is the correct symbol for EUR/GBP futures. In SC, the symbol for June futures is: RP-201606-GLOBEX |
[2016-05-18 14:28:42] |
Hi there, I don't have RP listed when going into chart settings. It goes R, RB then onto SB in the Find Symbol list in Sierra charts?!
[2016-05-18 14:33:17] |
It isn't necessary to click on "find" in the chart settings. Enter RP-201606-GLOBEX in the symbol area to the left of "Find" click apply and then wait for the data to download and create the chart. |
[2016-05-18 17:50:07] |
We are adding this symbol now. Just give us about 10 minutes.
[2016-05-18 18:27:31] |
The symbol has now been added. It is: RP-######-GLOBEX-GBP-125000 Update the Symbol Settings as explained here to see it: http://www.sierrachart.com/index.php?page=doc/doc_GlobalSymbolSettings.php#UpdateSettings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-12-15 13:48:49] |
JanS - Posts: 46 |
Could you please add this futures contract for CQG also? I've updated the symbol settings but it's not listed. The symbol should be F.US.EB?## for CQG. |
