Date/Time: Sat, 27 Apr 2024 07:11:09 +0000
BookMap
View Count: 23136
[2016-06-17 07:07:08] |
Post this through a separate Support Request. We will not accept this in a User Discussion thread. Also how you describe it is how it should be working but we will check again.
[2016-06-20 01:19:23] |
User15952 - Posts: 132 |
Market Depth Historical Graph |
[2017-02-14 19:39:18] |
JVonD - Posts: 9 |
Totally awesome! Thanks a bunch amirN! Is there anyway to make it record more of the book. Image Example Attached - crude |
17-02-14_12-30-26.png / V - Attached On 2017-02-14 19:37:30 UTC - Size: 72.3 KB - 1794 views |
[2017-02-14 21:12:18] |
We recommend using the Market Depth Historical Graph feature: https://www.sierrachart.com/index.php?page=doc/MarketDepthHistoricalGraph.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-02-15 13:48:46] |
amirN - Posts: 159 |
I am afraid it can only display 10 levels on the Bid and 10 on the Ask. I am not going to upload my later improvements as SC has a version out (the above post). Regards Amir |
[2017-04-13 12:29:29] |
User30743 - Posts: 364 |
hi amir, would u be willing to provide .cpp file of this book map?
