Date/Time: Thu, 16 May 2024 08:30:12 +0000
Daily OHLC - Extend Until Future Intersection
View Count: 1752
[2016-05-14 06:35:19] |
User93757 - Posts: 61 |
Hi, Do you have a study which can show the Daily OHLC line that can extend until future intersection? Really just after extending a line until future intersection, specifically the HIGH and LOW of the DAY/or WEEK... Ty, |
[2016-05-15 20:29:58] |
jsoviero - Posts: 84 |
I like this request. Currently I do this manually using the Horizontal Lines Study for daily weekly and monthly OHLC. Please consider adding this feature ASAP. TY
[2016-05-16 05:57:57] |
Or perhaps add it to TPO and Volume Profile Studies, in which Period High/Lows will be an option with the End of window, end of period, none and until future intersection as sub options,,, Similar to the POC or Singles.. That would work for me, not sure about everyone else... |
[2016-08-22 13:58:15] |
+ 1 - Having the feature of adding High Low Open Close to a chart with an "until future intersection would be very useful. Please support this request. I would use it for the both the Pit session and the overnight Globex session on my intraday charts.
[2017-01-06 06:40:30] |
whats1thingnow - Posts: 407 |
+1
[2017-01-06 20:45:24] |
Have a look at these two studies which support this: https://www.sierrachart.com/index.php?page=doc/TechnicalStudiesReference.html#s239 https://www.sierrachart.com/index.php?page=doc/TechnicalStudiesReference.html#s384 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-07-25 00:11:43] |
User693573 - Posts: 8 |
that does not work, extended day high / low liene until future intersection +1 |
[2020-04-23 09:16:23] |
User535489 - Posts: 2 |
Hi, I tried this study - "Period OHLC - Variable period" and is drawing lines forward for example if you define this parameter "Number of forward bars to project" it projects OHLC for the number of bars to the future. BR V. |
Period_OHLC.JPG / V - Attached On 2020-04-23 09:11:25 UTC - Size: 195.84 KB - 274 views Attachment Deleted. |
