Date/Time: Tue, 29 Sep 2026 08:49:45 +0000
Cannot connect to data feed ...
View Count: 1453
[2016-05-09 17:58:58]
User303019 - Posts: 2
I took the demo through Amp futures, I can get into Sierra charts but it will not connect to the CQG demo feed, this is what my log reads:
Software version: 1400 | 2016-05-09 13:55:07
Uses New Spreadsheets | 2016-05-09 13:55:07
Usage end date: 2016-05-20 | 2016-05-09 13:55:07
Enabled for: Advanced Features. | 2016-05-09 13:55:07
Enabled for: Advanced Features 2. | 2016-05-09 13:55:07
Enabled for: Sierra Chart Historical Data Service. | 2016-05-09 13:55:07
Allow Support for Sierra Chart Data Feeds is enabled. | 2016-05-09 13:55:07
Current selected Data/Trading service: CQG FIX Trading | 2016-05-09 13:55:07
Chart Update Interval: 500 | 2016-05-09 13:55:07
Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2016-05-09 13:55:07
2016-05-09 13:55:11 Local computer time | 2016-05-09 13:55:07
2016-05-09 17:55:11 Local computer time in UTC | 2016-05-09 13:55:07
2016-05-09 13:55:11 Local computer time in SC Time Zone | 2016-05-09 13:55:07
2016-05-09 17:55:11 Server time in UTC | 2016-05-09 13:55:07
Local computer UTC time and Server UTC time difference: 0 seconds. | 2016-05-09 13:55:07
Program path: C:\SierraChart\ | 2016-05-09 13:55:07
Data Files path: C:\SierraChart\Data\ | 2016-05-09 13:55:07
OS Version Number: 6.2 | 2016-05-09 13:55:07
Locale Setting: C | 2016-05-09 13:55:07
Checking for new symbol settings for cqg | 2016-05-09 13:55:07
HTTPS connection to www.sierrachart.com:443 (0) | Resolved address sierrachart.com to IP 5.9.8.236. | 2016-05-09 13:55:07
HTTPS connection to www.sierrachart.com:443 (3) | Connected. | 2016-05-09 13:55:07
HTTPS connection to www.sierrachart.com:443 (3) | Starting TLS 1.2 connection. | 2016-05-09 13:55:07
HTTPS connection to www.sierrachart.com:443 (3) | SSL connection established. | 2016-05-09 13:55:07
Symbol settings are up-to-date for cqg | 2016-05-09 13:55:12
CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6912. | 2016-05-09 13:55:16
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214. | 2016-05-09 13:55:17
socket (4) | Connected. | 2016-05-09 13:55:17
CQG FIX: Sending the Logon message. | 2016-05-09 13:55:17
CQG FIX: Received a Logout message. Text = UserName does not exist. Contact Customer Support for assistance. | 2016-05-09 13:55:17
CQG FIX: Sending a Logout message. Text = Received Logout message. | 2016-05-09 13:55:17
socket (4) | Shutdown and closed. | 2016-05-09 13:55:17
CQG FIX: Disconnected. | 2016-05-09 13:55:17
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-05-09 13:55:17
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-05-09 13:55:17
CQG FIX Trading | Disconnected. | 2016-05-09 13:55:17
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-05-09 13:55:17
HTTPS connection to www.sierrachart.com:443 (3) | SSL connection closed by remote side. | 2016-05-09 13:55:17
HTTPS connection to www.sierrachart.com:443 (3) | Connection gracefully closed by remote side. | 2016-05-09 13:55:17
HTTPS connection to www.sierrachart.com:443 (3) | SSL object has been freed. SSL state is now disconnected. | 2016-05-09 13:55:17
HTTPS connection to www.sierrachart.com:443 (3) | Shutdown and closed. | 2016-05-09 13:55:17
CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6912. | 2016-05-09 13:55:20
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214. | 2016-05-09 13:55:20
socket (5) | Connected. | 2016-05-09 13:55:20
CQG FIX: Sending the Logon message. | 2016-05-09 13:55:20
CQG FIX: Received a Logout message. Text = UserName does not exist. Contact Customer Support for assistance. | 2016-05-09 13:55:20
CQG FIX: Sending a Logout message. Text = Received Logout message. | 2016-05-09 13:55:20
socket (5) | Shutdown and closed. | 2016-05-09 13:55:20
CQG FIX: Disconnected. | 2016-05-09 13:55:20
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-05-09 13:55:20
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-05-09 13:55:20
CQG FIX Trading | Disconnected. | 2016-05-09 13:55:20
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-05-09 13:55:20
CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6912. | 2016-05-09 13:55:23
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214. | 2016-05-09 13:55:23
socket (6) | Connected. | 2016-05-09 13:55:24
File >> Disconnect selected. | 2016-05-09 13:55:24
CQG FIX: DisconnectFIX called. | 2016-05-09 13:55:24
socket (6) | Shutdown and closed. | 2016-05-09 13:55:24
CQG FIX: Disconnected. | 2016-05-09 13:55:24
CQG FIX Trading | Disconnected. | 2016-05-09 13:55:24
[2016-05-09 19:28:47]
Update Sierra Chart following the instructions here:
https://www.sierrachart.com/index.php?page=doc/download.php#FastUpdate
After the update is installed, set Global Settings >> Data/Trade Service Settings >> Service to "CQG Web API". In that same window set Connection Details >> Server to "Demo".
Try connecting again and you should be able to connect.
[2016-05-09 19:57:01]
Works .... Thank you!
