Date/Time: Tue, 29 Sep 2026 08:49:20 +0000
Sierra Charts on two computers for different trading accounts not working
View Count: 974
[2016-05-09 03:15:12]
John M - Posts: 186
I have a SC installed on two separate computers, one is configured to use the SC data feed and trade on Interactive Brokers, the other is configured to use CTS data and trading.
When I try to run them simultaneously, only one is allowed to connect and I get :
SC Data - All Services | Using username 0 | 2016-05-08 21:55:50
SC Data - All Services | Connecting to the server scdf1.sierracharts.com. Port 10047 | 2016-05-08 21:55:50
Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131. | 2016-05-08 21:55:50
Socket (696) | Connected. | 2016-05-08 21:55:50
SC Data - All Services | Connected to server. | 2016-05-08 21:55:50
SC Data - All Services | Sending Encoding Request to server | 2016-05-08 21:55:50
SC Data - All Services | Setting DTC Encoding to Binary VLS | 2016-05-08 21:55:50
SC Data - All Services | Sending logon request message. | 2016-05-08 21:55:50
SC Data - All Services | Received logon response. | 2016-05-08 21:55:50
SC Data - All Services | Server Name: SC Real-Time Server. | 2016-05-08 21:55:50
SC Data - All Services | Server protocol version: 7. Client protocol version: 7 | 2016-05-08 21:55:50
SC Data - All Services | Logon error received from server: Limited to one connection per username for the requested data source. | 2016-05-08 21:55:50
Socket (696) | Shutdown and closed. | 2016-05-08 21:55:50
SC Data - All Services | Disconnected from the server. | 2016-05-08 21:55:50
SC Data - All Services | Data feed disconnected. Will reconnect. | 2016-05-08 21:55:50
SC Data - All Services | Using username 0 | 2016-05-08 21:55:51
SC Data - All Services | Connecting to the server scdf1.sierracharts.com. Port 10048 | 2016-05-08 21:55:51
Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131. | 2016-05-08 21:55:51
Socket (697) | Connected. | 2016-05-08 21:55:51
SC Data - All Services | Connected to server. | 2016-05-08 21:55:51
SC Data - All Services | Sending Encoding Request to server | 2016-05-08 21:55:51
SC Data - All Services | Setting DTC Encoding to Binary VLS | 2016-05-08 21:55:51
SC Data - All Services | Sending logon request message. | 2016-05-08 21:55:51
SC Data - All Services | Received logon response. | 2016-05-08 21:55:51
SC Data - All Services | Server Name: SC Real-Time Server. | 2016-05-08 21:55:51
SC Data - All Services | Server protocol version: 7. Client protocol version: 7 | 2016-05-08 21:55:51
SC Data - All Services | Logon error received from server: Limited to one connection per username for the requested data source. | 2016-05-08 21:55:51
Socket (697) | Shutdown and closed. | 2016-05-08 21:55:51
SC Data - All Services | Disconnected from the server. | 2016-05-08 21:55:51
SC Data - All Services | Data feed disconnected. Will reconnect. | 2016-05-08 21:55:51
SC Data - All Services | Using username 0 | 2016-05-08 21:55:52
SC Data - All Services | Connecting to the server scdf2.sierracharts.com. Port 10046 | 2016-05-08 21:55:52
Socket (0) | Resolved address ds7.sierracharts.com to IP 8.18.161.133. | 2016-05-08 21:55:52
Socket (698) | Connected. | 2016-05-08 21:55:52
SC Data - All Services | Connected to server. | 2016-05-08 21:55:52
SC Data - All Services | Sending Encoding Request to server | 2016-05-08 21:55:52
SC Data - All Services | Setting DTC Encoding to Binary VLS | 2016-05-08 21:55:52
SC Data - All Services | Sending logon request message. | 2016-05-08 21:55:52
SC Data - All Services | Received logon response. | 2016-05-08 21:55:52
SC Data - All Services | Server Name: SC Real-Time Server. | 2016-05-08 21:55:52
SC Data - All Services | Server protocol version: 7. Client protocol version: 7 | 2016-05-08 21:55:52
SC Data - All Services | Logon error received from server: Limited to one connection per username for the requested data source. | 2016-05-08 21:55:52
Socket (698) | Shutdown and closed. | 2016-05-08 21:55:52
SC Data - All Services | Disconnected from the server. | 2016-05-08 21:55:52
SC Data - All Services | Data feed disconnected. Will reconnect. | 2016-05-08 21:55:52
File >> Disconnect selected. | 2016-05-08 21:55:53
Socket (7) | Shutdown and closed. | 2016-05-08 21:55:53
IT does the same thing if I try to run them on the same computer.
I have a level 5 subscription so I should be able to run 3 instances of SC, correct?
What am I doing wrong ?
Each of these instances will connect successfully if the other is not activated. I don't understand the conflict.
[2016-05-09 04:30:02]
In the instance connected to CTS uncheck Global Settings >> Data/Trade Service Settings >> Allow Support for Sierra Chart Data Feeds.
For additional information refer to:
https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#Connections
[2016-05-09 21:01:25]
John M - Posts: 186
Thank you, that worked.
If I want to set up the 3rd instance of SC which would also be looking at the SC Data feed and trading on Interactive Brokers for a different account do I maintain the support for SC Data Chart Feeds as checked or will I get the conflict again ?
[2016-05-09 21:09:10]
In this particular case you need to go to this page and activate a second real-time connection:
https://www.sierrachart.com/usercp.php?page=MarketDataFeedFeatures&UserID=104947
You do need to enable this option:
Unless you will be using the Interactive Brokers data feed. In that case you do not need the second real-time connection.
