Date/Time: Mon, 29 Apr 2024 00:38:59 +0000
Point and Figure 45%
View Count: 744
[2016-05-06 19:30:25] |
madra - Posts: 109 |
Chart Aapl 0.3x3 Daily I have set tick size .01 Currency value per tick .01 value increment per bar 30( box size) Is it safe to assume that when the slope of line is ONE that we are looking at a 45% angle EVEN IF IT DOES NOT APPEAR SO? http://www.sierrachart.com/image.php?Image=1462562485850.png Thank you, |
[2016-05-06 20:45:26] |
Yes this is a correct understanding.
