Date/Time: Mon, 06 May 2024 02:53:09 +0000
Zero Values in BidxAsk column Number bars at time of connect to data feed
View Count: 641
[2016-05-06 16:06:27] |
SK - Posts: 33 |
This issue has been occurring every time , when connects to data feed. I use InteractiveBrokers(IB) real account for my data feed. when I connect to the data feed after closing and reopening sierra there seems to zero values on previous 2 bars on my 5 min number bars chart. pls. see attached. This issue was there since I started to use the sierra few weeks ago. Not sure if this is IB or Sierra. Pls advise. Thanks |
2016-05-06_11-58-50.jpg / V - Attached On 2016-05-06 16:00:40 UTC - Size: 326.21 KB - 265 views |
[2016-05-06 16:14:48] |
Numbers Bars cannot be used with Interactive Brokers data. They are going to be completely inaccurate. You need to use the Sierra Chart exchange data feed: Sierra Chart Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-05-06 16:42:59] |
SK - Posts: 33 |
Do you have equity and futures options data feed as well?
[2016-05-06 16:50:29] |
No. But you can still receive that data from Interactive Brokers.
