Date/Time: Sun, 05 May 2024 13:36:45 +0000
Data and Trading Communications (DTC) Protocol question
View Count: 817
[2016-05-05 16:20:26] |
User98649 - Posts: 14 |
If a user has the Sierra Chart Real-Time Exchange Data Feed, is it possible to write a program (C++, Python or Java) that can listen to the data feed and parse the data outside of SC platform because the data feed uses the DTC protocol? or is the data feed only accessible within the SC platform?
[2016-05-05 17:23:10] |
You can use the data feed externally. But it needs to be accessed from the Sierra Chart DTC Server. Refer to: https://www.sierrachart.com/index.php?page=doc/doc_DTCServer.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-05-05 18:35:22] |
Are there any code examples showing how to access the data feed externally?
[2016-05-05 18:48:36] |
No.
