Date/Time: Fri, 10 May 2024 07:14:39 +0000
Lost chart data bar
View Count: 562
[2016-05-05 15:53:33] |
William F - Posts: 6 |
I recently updated and I have lost a bar I can't find a way to restore. In my chartbooks the top row contains Sierra Chart 1307 date Chart name, etc The next row contains HC,IC,OC,CC.Sv.Dis,CS,SW,CTV,abc,cvw, etc Below that I have had a bar that showed the date and time at location of cursor on the chart and the OHLC value of the price bar the cursor was pointing to, etc. I have not been able to find a way o restore this bar. I thank you for your help. |
[2016-05-05 18:01:25] |
You now need to use the Compact Tool Values Window. For complete documentation, refer to: https://www.sierrachart.com/index.php?page=doc/doc_Tools.html#CompactToolValuesWindow Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
