Date/Time: Thu, 09 May 2024 16:30:33 +0000
chart region of Line study not adhering
View Count: 546
[2016-05-05 13:48:22] |
@sstfrederik - Posts: 403 |
I used the source for the Line study form studies7 and created a new study. No changes were made to the source, I set sc.GraphRegion = 1; I find that when I want to add this study this line will always display itself in a new region, and not in the region 1 as it was set in the source. I would like the Graphregion to be fixed for this study so that it will overlay on another study in the same region by default. Is there a way this can be forced instead of the user needing to check chart region? thanks. |
[2016-05-05 17:51:17] |
To do what you want place sc.GraphRegion = 1; under and outside of the sc. SetDefaults code block.
[2016-05-05 18:23:25] |
thanks. that worked.
