Date/Time: Fri, 10 May 2024 02:10:23 +0000
Trade DoM does not accept orders via ladder
View Count: 699
[2016-05-05 11:53:09] |
Cavalry3162 - Posts: 523 |
Hello SC, i've opened some trade dom windows on my second computer and am unable to submit any orders with them when i click on the buy/sell columns in the ladder.. i can right click and select "sell limit" and it will submit, but clicking inside the columns does not lead to anything. the same dom coplumns work on my first computer. so i am not clicking on a "non order column" is there a hidden setting anywhere? do i miss something? |
[2016-05-05 17:43:31] |
Refer to the Chart DOM Settings: https://www.sierrachart.com/index.php?page=doc/doc_GlobalTradeSettings.html#ChartDOMSettings Apparently Pointer left click operations are set to "Ignore Input" . Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-05-05 17:43:55
[2016-05-05 18:24:25] |
hmm, i havent set those myself.. weird.. is this a default? (i doubt it, but you never know) however, i did not know about this setting and it is really great that i discovered it (with your help). i love it. thanks, Andreas |
