Date/Time: Mon, 06 May 2024 16:23:07 +0000
Write Bar Data To File study - for studies
View Count: 808
[2016-05-04 02:16:07] |
rhovega - Posts: 279 |
I would like to have a study that does what Write Bar Data To File study does, but for studies (i.e. output not only price/volume data but also subgraphs loaded on the chart). After some futile attempts to modify Write Bar Data To File, I find this unfortunately is beyond my current coding skills. Before I ask a professional coder for a quote, would like to ask you if this is something you would consider doing for a fee. Is it? I have also noticed that there use to be a study called Write Signals to Text File up to version 515 or so. That study may be what I am looking for. Would you be willing to share the source code for that old study? Thank you |
[2016-05-05 19:24:14] |
We will try to add this capability soon. It will be added to the Edit menu.
