Date/Time: Tue, 29 Sep 2026 08:04:08 +0000
DOM question
View Count: 1772
| [2016-04-28 16:44:22] |
| User529356 - Posts: 40 |
Hello ~ is it possible to activate the 'show depth' option on the menu bar of the trading DOM?
| [2016-04-28 17:09:55] |
To add the market depth columns on the Trade DOM, refer to: Chart Trading and the Chart DOM: Customizing Trade DOM and Chart DOM Columns Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-04-28 17:10:23
| [2016-04-29 18:34:52] |
Thankyou ~ I read through the sierra chart reference and it was helpful to an extent, though I am still struggling to figure out why the volume of orders displayed at each price level has disappeared and appeared on charts lately and sometimes the volume numbers are completely washed or just a block of color. Any feedback and/or thoughts in this regard would be much appreciated.
| [2016-04-29 21:34:16] |
When you see something that does not look right with the market depth data, open the market depth window with File >> Open Market Depth Window. After that post an image of the chart by following the instructions here: https://www.sierrachart.com/index.php?page=PostingInformation.php#Image Be sure to upload the chart with Overlays. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-05-05 17:23:01] |
Hello again, I was able to get the trade depth of market to work adequately for a while, though it has again seemingly randomly stopped functioning. I have attached a snapshot here. Note the market depth window is sitting at 0 bid and ask while the Trade DOM columns each only have one market size notation on each the bid and ask side of the market. (I do indeed have the ~ bid size/buy column and ask size/sell column selected via the 'customize trade dom columns' window.) http://www.sierrachart.com/image.php?Image=146246794570.png Date Time Of Last Edit: 2016-05-05 18:13:08
| [2016-05-05 17:50:17] |
:) http://www.sierrachart.com/image.php?Image=1462470589575.png
| [2016-05-05 18:13:37] |
What we see is that your account is not authorized for CME market depth data. Contact your broker and have them authorize your Rithmic account for CME market depth data. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-05-05 18:14:10
| [2016-05-16 16:55:11] |
Hello My friends! I have contacted my broker and Rithmic. They have authorized CME market data. It initially was helpful, though this morning on starting up my sierra chart platform, I recognized that all of my emini S&P chart doms were lacking market depth data. For what it is worth, my CL (crude oil) chart dom shows full depth. Only the Emini doms are lacking depth. I have attached another picture of the limited dom here for reference, though it is the same as past posts. I contacted both my broker and Rithmic this morning and they noted that CME market data is enabled on their end and recommended I reconnect with you. I look forward your thoughts. Much gratitude Keith http://www.sierrachart.com/image.php?Image=1463416275240.png |
| [2016-05-16 17:06:35] |
You need to tell them that you require market depth data for that symbol. Sierra Chart cannot control this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-05-20 15:13:30] |
Hello my friends:) Something allowed the market depth option to work seamlessly for the past couple days, though when starting sierra chart this morning, the limited 'top of the book' market depth returned on my ES chart DOMs. Also an interesting phenomenon showed up on my CL chart DOM. Various orders in the book along the order chain showed up in an inconsistent fashion. I have posted it here for reference in case it might be helpful in diagnosing exactly what is happening. Also Eric from Rithmic noted that I could pass on his address and he would be happy to help in any way to try and figure this out. <eric.aversa@rithmic.com> much gratitude http://www.sierrachart.com/image.php?Image=1463751173486.png |
| [2016-05-20 17:27:40] |
Provide a copy of the Message Log by following these instructions: http://www.sierrachart.com/index.php?l=PostingInformation.php#MessageLog Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-05-20 17:45:31] |
Hey friends:) Sorry it took this time to respond. I was out for the morning. So upon return I see that the dom in my ES carts is back to normal. After resetting the CL DOM it looks to be operating normally as well. I am thoroughly confused and would love to get a better understanding of what variable causes this. Any thoughts you have would be greatly and genuinely appreciated. Incase it helps, I have attached the log here as requested. Enjoy this day Keith Software version: 1411 | 2016-05-20 06:14:07 Uses New Spreadsheets | 2016-05-20 06:14:07 Usage end date: 2016-10-13 | 2016-05-20 06:14:07 Enabled for: Advanced Features. | 2016-05-20 06:14:07 Enabled for: Advanced Features 2. | 2016-05-20 06:14:07 Enabled for: Sierra Chart Historical Data Service. | 2016-05-20 06:14:07 Allow Support for Sierra Chart Data Feeds is enabled. | 2016-05-20 06:14:07 Current selected Data/Trading service: Rithmic Trading | 2016-05-20 06:14:07 Chart Update Interval: 300 | 2016-05-20 06:14:07 Data/Trade Service Settings automatically set. | 2016-05-20 06:14:07 Time Zone: -07:00:00 (PST-08PDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2016-05-20 06:14:07 2016-05-20 06:14:11 Local computer time | 2016-05-20 06:14:07 2016-05-20 13:14:11 Local computer time in UTC | 2016-05-20 06:14:07 2016-05-20 06:14:11 Local computer time in SC Time Zone | 2016-05-20 06:14:07 2016-05-20 13:14:11 Server time in UTC | 2016-05-20 06:14:07 Local computer UTC time and Server UTC time difference: 0 seconds. | 2016-05-20 06:14:07 Program path: C:\SierraChart\ | 2016-05-20 06:14:07 Data Files path: C:\SierraChart\Data\ | 2016-05-20 06:14:07 OS Version Number: 6.2 | 2016-05-20 06:14:07 Locale Setting: C | 2016-05-20 06:14:07 Created the DTC Protocol server. | 2016-05-20 06:14:07 DTC Protocol Server listening on port 11099. | 2016-05-20 06:14:07 Created the DTC Protocol historical data server. | 2016-05-20 06:14:07 HD Server Manager | Listening on port 11098 | 2016-05-20 06:14:07 Checking for new symbol settings for rim | 2016-05-20 06:14:07 HTTPS connection to www.sierrachart.com:443 (0) | Resolved address sierrachart.com to IP 5.9.8.236. | 2016-05-20 06:14:07 HTTPS connection to www.sierrachart.com:443 (3) | Connected. | 2016-05-20 06:14:07 HTTPS connection to www.sierrachart.com:443 (3) | Starting TLS 1.2 connection. | 2016-05-20 06:14:07 HTTPS connection to www.sierrachart.com:443 (3) | SSL connection established. | 2016-05-20 06:14:12 Symbol settings are up-to-date for rim | 2016-05-20 06:14:13 Files to Open on Start up | Opening file: TPO chart.cht | 2016-05-20 06:14:14 ESM6-CME [CB] #1 | Performing historical Daily data download for symbol ESM16 starting at last date in file. | 2016-05-20 06:14:14 ESM6-CME [CB] #1 | Waiting for historical downloads to complete with the IDs: 1, | 2016-05-20 06:14:14 Files to Open on Start up | Opening file: TICK&NISS.cht | 2016-05-20 06:14:14 ESM6-CME [CB] 1 Min #1 | Waiting for historical downloads to complete with the IDs: 1, | 2016-05-20 06:14:14 TICK-NYSE [CB] 1 Min #2 | No contract months found for symbol. Unable to build continuous futures contract chart. | 2016-05-20 06:14:14 TICK-NYSE [CB] 1 Min #2 | There are no continuous futures contract symbols. Loading data normally. | 2016-05-20 06:14:14 NISS-NYSE [CBV] 1 Min #3 | No contract months found for symbol. Unable to build continuous futures contract chart. | 2016-05-20 06:14:14 NISS-NYSE [CBV] 1 Min #3 | There are no continuous futures contract symbols. Loading data normally. | 2016-05-20 06:14:14 Files to Open on Start up | Opening file: primary 5m.cht | 2016-05-20 06:14:14 ESM6-CME [CB] 5 Min #1 | Waiting for historical downloads to complete with the IDs: 1, | 2016-05-20 06:14:14 TICK-NYSE [CB] 5 Min #2 | No contract months found for symbol. Unable to build continuous futures contract chart. | 2016-05-20 06:14:14 TICK-NYSE [CB] 5 Min #2 | There are no continuous futures contract symbols. Loading data normally. | 2016-05-20 06:14:14 NISS-NYSE [CB] 5 Min #4 | No contract months found for symbol. Unable to build continuous futures contract chart. | 2016-05-20 06:14:14 NISS-NYSE [CB] 5 Min #4 | There are no continuous futures contract symbols. Loading data normally. | 2016-05-20 06:14:14 Files to Open on Start up | Opening file: primary 60m.cht | 2016-05-20 06:14:14 ESM6-CME [CB] 60 Min #1 | Waiting for historical downloads to complete with the IDs: 1, | 2016-05-20 06:14:14 ESM6-CME [CB] 30 Min #3 | Waiting for historical downloads to complete with the IDs: 1, | 2016-05-20 06:14:14 Files to Open on Start up | Opening file: clean RTH ES.cht | 2016-05-20 06:14:14 Files to Open on Start up | Opening file: clean ES reference.cht | 2016-05-20 06:14:14 ESM6-CME [CB] 60 Min #1 | Waiting for historical downloads to complete with the IDs: 1, | 2016-05-20 06:14:14 Files to Open on Start up | Opening file: YHLC.cht | 2016-05-20 06:14:14 ESM6-CME [CB] 60 Min #1 | Waiting for historical downloads to complete with the IDs: 1, | 2016-05-20 06:14:14 ESM6-CME [CB] 60 Min #2 | Waiting for historical downloads to complete with the IDs: 1, | 2016-05-20 06:14:14 Files to Open on Start up | Opening file: RTH daily chart.cht | 2016-05-20 06:14:14 ESM6-CME [CB] 1 Day #1 | Limiting the number of years to download historical data for to 5 years for the continuous futures chart. Reason: Single-digit year in symbol. | 2016-05-20 06:14:14 ESM6-CME [CB] 1 Day #1 | Waiting for historical downloads to complete with the IDs: 1, | 2016-05-20 06:14:14 Files to Open on Start up | Opening file: daily POCs long term.cht | 2016-05-20 06:14:14 ESM6-CME [CB] 60 Min #1 | Waiting for historical downloads to complete with the IDs: 1, | 2016-05-20 06:14:14 Files to Open on Start up | Opening file: ES with composite profile.cht | 2016-05-20 06:14:14 Files to Open on Start up | Opening file: long term ref.cht | 2016-05-20 06:14:14 Files to Open on Start up | Opening file: Nikkei index.cht | 2016-05-20 06:14:14 NKDM6-CME [CB] 60 Min #1 | Performing historical Daily data download for symbol NYM16 starting at last date in file. | 2016-05-20 06:14:14 NKDM6-CME [CB] 60 Min #1 | Waiting for historical downloads to complete with the IDs: 2, | 2016-05-20 06:14:14 Files to Open on Start up | Opening file: LIGHT SWEET CRUDE futures chart.cht | 2016-05-20 06:14:14 CLN6-NYMEX [CB] 60 Min #2 | Performing historical Daily data download for symbol CLN16 starting at last date in file. | 2016-05-20 06:14:14 CLN6-NYMEX [CB] 60 Min #2 | Waiting for historical downloads to complete with the IDs: 3, | 2016-05-20 06:14:14 Files to Open on Start up | Opening file: soybean futures.cht | 2016-05-20 06:14:14 ZSN6-CBOT [CB] 60 Min #1 | Performing historical Daily data download for symbol ZSN16 starting at last date in file. | 2016-05-20 06:14:14 ZSN6-CBOT [CB] 60 Min #1 | Waiting for historical downloads to complete with the IDs: 4, | 2016-05-20 06:14:14 HD Request # 2 | Downloading Historical Daily chart data for ESM16. Starting date: 2016-05-18. Service: rim | 2016-05-20 06:14:14 HD Request # 2 | Requesting historical Daily data for ESM16 starting at 2016-05-17 | 2016-05-20 06:14:14 HTTPS connection to www.sierrachart.com:443 (3) | SSL connection closed by remote side. | 2016-05-20 06:14:14 HTTPS connection to www.sierrachart.com:443 (3) | Connection gracefully closed by remote side. | 2016-05-20 06:14:14 HTTPS connection to www.sierrachart.com:443 (3) | SSL object has been freed. SSL state is now disconnected. | 2016-05-20 06:14:14 HTTPS connection to www.sierrachart.com:443 (3) | Shutdown and closed. | 2016-05-20 06:14:14 HTTP connection to ds01.ddfplus.com:80 (0) | Resolved address ds01.ddfplus.com to IP 8.18.161.123. | 2016-05-20 06:14:14 Intraday data recording state for symbol ESM6-CME is set to download 'Pending'. | 2016-05-20 06:14:18 HD Request # 3 | Downloading Intraday chart data for ESM6-CME to the file ESM6-CME.scid. Service: rim | 2016-05-20 06:14:18 HD Request # 3 | Download start Date-Time: 2016-05-19 21:38:28.000 | 2016-05-20 06:14:18 HD Request # 3 | Using server: ds4.sierracharts.com port 10149 | 2016-05-20 06:14:18 Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26. | 2016-05-20 06:14:18 Intraday data recording state for symbol TICK-NYSE is set to download 'Pending'. | 2016-05-20 06:14:18 HTTP connection to ds01.ddfplus.com:80 (4) | Connected. | 2016-05-20 06:14:18 Intraday data recording state for symbol NISS-NYSE is set to download 'Pending'. | 2016-05-20 06:14:18 Socket (5) | Connected. | 2016-05-20 06:14:18 HD Request # 3 | Sending historical data logon request message. | 2016-05-20 06:14:18 HD Request # 2 | Receiving historical Daily data for ESM16 starting at 2016-05-18 | 2016-05-20 06:14:18 HD Request # 2 | Writing historical Daily data to the file ESM16.dly | 2016-05-20 06:14:18 HD Request # 2 | Received 4 records from 2016-05-18 00:00:00 to 2016-05-20 00:00:00 (3.0 days) and wrote 3 records for ESM16 | 2016-05-20 06:14:18 HD Request # 2 | Daily download COMPLETE for ESM16. Completion time: 0s. Unique request ID: 1 | 2016-05-20 06:14:18 Removed historical data download ID 1 | 2016-05-20 06:14:18 HD Request # 4 | Downloading Historical Daily chart data for NYM16. Starting date: 2016-05-18. Service: rim | 2016-05-20 06:14:18 HD Request # 4 | Requesting historical Daily data for NYM16 starting at 2016-05-17 | 2016-05-20 06:14:18 ESM6-CME [CB] 60 Min #1 | Download is complete for all contract months in chart. Proceeding with data load. | 2016-05-20 06:14:18 ESM6-CME [CB] 60 Min #1 | Reloading chart. | 2016-05-20 06:14:18 ESM6-CME [CB] 30 Min #3 | Download is complete for all contract months in chart. Proceeding with data load. | 2016-05-20 06:14:18 ESM6-CME [CB] 30 Min #3 | Reloading chart. | 2016-05-20 06:14:18 ESM6-CME [CB] 60 Min #1 | Download is complete for all contract months in chart. Proceeding with data load. | 2016-05-20 06:14:18 ESM6-CME [CB] 60 Min #1 | Reloading chart. | 2016-05-20 06:14:18 ESM6-CME [CB] 60 Min #1 | Download is complete for all contract months in chart. Proceeding with data load. | 2016-05-20 06:14:18 ESM6-CME [CB] 60 Min #1 | Reloading chart. | 2016-05-20 06:14:18 HD Request # 3 | Requesting Intraday data. Start Date-Time: 2016-05-19 21:38:28. Record interval: 0. Symbol: ESM6-CME | 2016-05-20 06:14:18 Socket (5) | Shutdown and closed. | 2016-05-20 06:14:18 The network socket for historical data has been closed. | 2016-05-20 06:14:18 HD Request # 4 | Receiving historical Daily data for NYM16 starting at 2016-05-18 | 2016-05-20 06:14:18 HD Request # 4 | Writing historical Daily data to the file NYM16.dly | 2016-05-20 06:14:18 HD Request # 4 | Received 4 records from 2016-05-18 00:00:00 to 2016-05-20 00:00:00 (3.0 days) and wrote 3 records for NYM16 | 2016-05-20 06:14:18 HD Request # 4 | Daily download COMPLETE for NYM16. Completion time: 1s. Unique request ID: 2 | 2016-05-20 06:14:18 Removed historical data download ID 2 | 2016-05-20 06:14:18 HD Request # 3 | Historical data for ESM6-CME is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2016-05-20 06:14:18 HD Request # 3 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESM6-CME | 2016-05-20 06:14:18 HD Request # 3 | Intraday download COMPLETE for ESM6-CME. Completion time: 1s. Unique request ID: 5 | 2016-05-20 06:14:18 Removed historical data download ID 5 | 2016-05-20 06:14:18 HD Request # 5 | Downloading Historical Daily chart data for CLN16. Starting date: 2016-05-18. Service: rim | 2016-05-20 06:14:18 HD Request # 5 | Requesting historical Daily data for CLN16 starting at 2016-05-17 | 2016-05-20 06:14:18 HD Request # 6 | Downloading Intraday chart data for TICK-NYSE to the file TICK-NYSE.scid. Service: statscalc | 2016-05-20 06:14:18 HD Request # 6 | Download start Date-Time: 2016-05-19 13:05:00.000 | 2016-05-20 06:14:18 HD Request # 6 | Using server: ds5.sierracharts.com port 10149 | 2016-05-20 06:14:18 HD Request # 5 | Receiving historical Daily data for CLN16 starting at 2016-05-18 | 2016-05-20 06:14:18 HD Request # 5 | Writing historical Daily data to the file CLN16.dly | 2016-05-20 06:14:18 HD Request # 5 | Received 4 records from 2016-05-18 00:00:00 to 2016-05-20 00:00:00 (3.0 days) and wrote 3 records for CLN16 | 2016-05-20 06:14:18 HD Request # 5 | Daily download COMPLETE for CLN16. Completion time: 1s. Unique request ID: 3 | 2016-05-20 06:14:18 Removed historical data download ID 3 | 2016-05-20 06:14:18 HD Request # 7 | Downloading Historical Daily chart data for ZSN16. Starting date: 2016-05-18. Service: rim | 2016-05-20 06:14:18 HD Request # 7 | Requesting historical Daily data for ZSN16 starting at 2016-05-17 | 2016-05-20 06:14:18 ESM6-CME [CB] 60 Min #2 | Download is complete for all contract months in chart. Proceeding with data load. | 2016-05-20 06:14:18 ESM6-CME [CB] 60 Min #2 | Reloading chart. | 2016-05-20 06:14:18 Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106. | 2016-05-20 06:14:18 Socket (6) | Connected. | 2016-05-20 06:14:18 HD Request # 6 | Sending historical data logon request message. | 2016-05-20 06:14:18 HD Request # 6 | Requesting Intraday data. Start Date-Time: 2016-05-19 13:05:00. Record interval: 0. Symbol: TICK-NYSE | 2016-05-20 06:14:18 HD Request # 6 | Decompressing data. | 2016-05-20 06:14:18 HD Request # 6 | Receiving Intraday data for TICK-NYSE starting at 2016-05-19 13:05:00 | 2016-05-20 06:14:18 Socket (6) | Shutdown and closed. | 2016-05-20 06:14:18 The network socket for historical data has been closed. | 2016-05-20 06:14:18 HD Request # 7 | Receiving historical Daily data for ZSN16 starting at 2016-05-18 | 2016-05-20 06:14:18 HD Request # 7 | Writing historical Daily data to the file ZSN16.dly | 2016-05-20 06:14:18 HD Request # 7 | Received 4 records from 2016-05-18 00:00:00 to 2016-05-20 00:00:00 (3.0 days) and wrote 3 records for ZSN16 | 2016-05-20 06:14:18 HD Request # 7 | Daily download COMPLETE for ZSN16. Completion time: 0s. Unique request ID: 4 | 2016-05-20 06:14:18 Removed historical data download ID 4 | 2016-05-20 06:14:18 HD Request # 6 | Historical data for TICK-NYSE is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2016-05-20 06:14:18 HD Request # 6 | Received 1 record from 2016-05-19 13:05:00 to 2016-05-19 13:05:00 (0.0 seconds) and wrote 0 records for TICK-NYSE | 2016-05-20 06:14:18 HD Request # 6 | Intraday download COMPLETE for TICK-NYSE. Completion time: 2s. Unique request ID: 6 | 2016-05-20 06:14:18 Removed historical data download ID 6 | 2016-05-20 06:14:18 HD Request # 8 | Downloading Historical Daily chart data for ESM6-CME. Starting date: 2016-05-19. Service: rim | 2016-05-20 06:14:18 HD Request # 8 | Requesting historical Daily data for ESM16 starting at 2016-05-18 | 2016-05-20 06:14:18 HD Request # 9 | Downloading Intraday chart data for NISS-NYSE to the file NISS-NYSE.scid. Service: statscalc | 2016-05-20 06:14:18 HD Request # 9 | Download start Date-Time: 2016-05-19 17:58:02.000 | 2016-05-20 06:14:18 HD Request # 9 | Using server: ds3.sierracharts.com port 10149 | 2016-05-20 06:14:18 ESM6-CME [CB] 1 Day #1 | Download is complete for all contract months in chart. Proceeding with data load. | 2016-05-20 06:14:18 ESM6-CME [CB] 1 Day #1 | Reloading chart. | 2016-05-20 06:14:18 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164. | 2016-05-20 06:14:18 Socket (7) | Connected. | 2016-05-20 06:14:18 HD Request # 9 | Sending historical data logon request message. | 2016-05-20 06:14:18 HD Request # 9 | Requesting Intraday data. Start Date-Time: 2016-05-19 17:58:02. Record interval: 0. Symbol: NISS-NYSE | 2016-05-20 06:14:18 HD Request # 9 | Decompressing data. | 2016-05-20 06:14:18 HD Request # 9 | Receiving Intraday data for NISS-NYSE starting at 2016-05-19 17:58:02 | 2016-05-20 06:14:18 HD Request # 9 | Timestamp of first Intraday data file record written: 2016-05-20 01:00:01 | 2016-05-20 06:14:18 Socket (7) | Shutdown and closed. | 2016-05-20 06:14:18 The network socket for historical data has been closed. | 2016-05-20 06:14:18 HD Request # 8 | Receiving historical Daily data for ESM6-CME starting at 2016-05-19 | 2016-05-20 06:14:18 HD Request # 8 | Writing historical Daily data to the file ESM6-CME.dly | 2016-05-20 06:14:18 HD Request # 8 | Received 3 records from 2016-05-19 00:00:00 to 2016-05-20 00:00:00 (2.0 days) and wrote 2 records for ESM6-CME | 2016-05-20 06:14:18 HD Request # 8 | Daily download COMPLETE for ESM6-CME. Completion time: 0s. Unique request ID: 8 | 2016-05-20 06:14:18 Removed historical data download ID 8 | 2016-05-20 06:14:18 HD Request # 9 | Historical data for NISS-NYSE is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2016-05-20 06:14:18 HD Request # 9 | Received 6245 records from 2016-05-19 17:58:02 to 2016-05-20 06:14:20 (12.3 hours) and wrote 6244 records for NISS-NYSE | 2016-05-20 06:14:18 HD Request # 9 | Intraday download COMPLETE for NISS-NYSE. Completion time: 0s. Unique request ID: 7 | 2016-05-20 06:14:18 Removed historical data download ID 7 | 2016-05-20 06:14:18 ESM6-CME [CB] 60 Min #1 | Download is complete for all contract months in chart. Proceeding with data load. | 2016-05-20 06:14:18 ESM6-CME [CB] 60 Min #1 | Reloading chart. | 2016-05-20 06:14:18 ESM6-CME [CB] Daily #1 | Reloading chart. | 2016-05-20 06:14:18 ESM6-CME [CB] Daily #1 | Reloading chart. | 2016-05-20 06:14:18 NKDM6-CME [CB] 60 Min #1 | Download is complete for all contract months in chart. Proceeding with data load. | 2016-05-20 06:14:18 NKDM6-CME [CB] 60 Min #1 | Reloading chart. | 2016-05-20 06:14:18 Intraday data recording state for symbol NKDM6-CME is set to download 'Pending'. | 2016-05-20 06:14:18 HD Request # 10 | Downloading Intraday chart data for NKDM6-CME to the file NKDM6-CME.scid. Service: rim | 2016-05-20 06:14:18 HD Request # 10 | Download start Date-Time: 2016-05-19 21:37:25.000 | 2016-05-20 06:14:18 HD Request # 10 | Using server: ds4.sierracharts.com port 10149 | 2016-05-20 06:14:18 CLN6-NYMEX [CB] 60 Min #2 | Download is complete for all contract months in chart. Proceeding with data load. | 2016-05-20 06:14:18 CLN6-NYMEX [CB] 60 Min #2 | Reloading chart. | 2016-05-20 06:14:18 Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26. | 2016-05-20 06:14:18 Socket (8) | Connected. | 2016-05-20 06:14:18 HD Request # 10 | Sending historical data logon request message. | 2016-05-20 06:14:18 Intraday data recording state for symbol CLM6-NYMEX is set to download 'Pending'. | 2016-05-20 06:14:25 ZSN6-CBOT [CB] 60 Min #1 | Download is complete for all contract months in chart. Proceeding with data load. | 2016-05-20 06:14:25 ZSN6-CBOT [CB] 60 Min #1 | Reloading chart. | 2016-05-20 06:14:25 HD Request # 10 | Requesting Intraday data. Start Date-Time: 2016-05-19 21:37:25. Record interval: 0. Symbol: NKDM6-CME | 2016-05-20 06:14:25 Socket (8) | Shutdown and closed. | 2016-05-20 06:14:25 The network socket for historical data has been closed. | 2016-05-20 06:14:25 HD Request # 10 | Historical data for NKDM6-CME is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2016-05-20 06:14:25 HD Request # 10 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for NKDM6-CME | 2016-05-20 06:14:25 HD Request # 10 | Intraday download COMPLETE for NKDM6-CME. Completion time: 1s. Unique request ID: 9 | 2016-05-20 06:14:25 Removed historical data download ID 9 | 2016-05-20 06:14:25 HD Request # 11 | Downloading Intraday chart data for CLM6-NYMEX to the file CLM6-NYMEX.scid. Service: rim | 2016-05-20 06:14:25 HD Request # 11 | Download start Date-Time: 2016-05-19 21:06:03.000 | 2016-05-20 06:14:25 HD Request # 11 | Using server: ds5.sierracharts.com port 10149 | 2016-05-20 06:14:25 Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106. | 2016-05-20 06:14:25 ESM6-CME [CB] 1 Min #1 | Download is complete for all contract months in chart. Proceeding with data load. | 2016-05-20 06:14:25 ESM6-CME [CB] 1 Min #1 | Reloading chart. | 2016-05-20 06:14:25 Socket (9) | Connected. | 2016-05-20 06:14:25 HD Request # 11 | Sending historical data logon request message. | 2016-05-20 06:14:25 HD Request # 11 | Requesting Intraday data. Start Date-Time: 2016-05-19 21:06:03. Record interval: 0. Symbol: CLM6-NYMEX | 2016-05-20 06:14:25 Socket (9) | Shutdown and closed. | 2016-05-20 06:14:25 The network socket for historical data has been closed. | 2016-05-20 06:14:25 HD Request # 11 | Historical data for CLM6-NYMEX is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2016-05-20 06:14:25 HD Request # 11 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for CLM6-NYMEX | 2016-05-20 06:14:25 HD Request # 11 | Intraday download COMPLETE for CLM6-NYMEX. Completion time: 0s. Unique request ID: 10 | 2016-05-20 06:14:25 Removed historical data download ID 10 | 2016-05-20 06:14:25 Intraday data recording state for symbol ZSN6-CBOT is set to download 'Pending'. | 2016-05-20 06:14:25 HD Request # 12 | Downloading Intraday chart data for ZSN6-CBOT to the file ZSN6-CBOT.scid. Service: rim | 2016-05-20 06:14:25 HD Request # 12 | Download start Date-Time: 2016-05-19 20:07:41.000 | 2016-05-20 06:14:25 HD Request # 12 | Using server: ds3.sierracharts.com port 10149 | 2016-05-20 06:14:25 ESM6-CME [CB] #1 | Download is complete for all contract months in chart. Proceeding with data load. | 2016-05-20 06:14:25 ESM6-CME [CB] #1 | Reloading chart. | 2016-05-20 06:14:25 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164. | 2016-05-20 06:14:25 Socket (10) | Connected. | 2016-05-20 06:14:25 HD Request # 12 | Sending historical data logon request message. | 2016-05-20 06:14:25 HD Request # 12 | Requesting Intraday data. Start Date-Time: 2016-05-19 20:07:41. Record interval: 0. Symbol: ZSN6-CBOT | 2016-05-20 06:14:25 Socket (10) | Shutdown and closed. | 2016-05-20 06:14:25 The network socket for historical data has been closed. | 2016-05-20 06:14:25 HD Request # 12 | Historical data for ZSN6-CBOT is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2016-05-20 06:14:25 HD Request # 12 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ZSN6-CBOT | 2016-05-20 06:14:25 HD Request # 12 | Intraday download COMPLETE for ZSN6-CBOT. Completion time: 3s. Unique request ID: 11 | 2016-05-20 06:14:25 Removed historical data download ID 11 | 2016-05-20 06:14:25 ESM6-CME [CB] 5 Min #1 | Download is complete for all contract months in chart. Proceeding with data load. | 2016-05-20 06:14:25 ESM6-CME [CB] 5 Min #1 | Reloading chart. | 2016-05-20 06:14:25 ESM6-CME [CB] Daily #1 | Reloading chart. | 2016-05-20 06:14:25 ESM6-CME [CB] Daily #3 | Reloading chart. | 2016-05-20 06:14:25 Rithmic Trading | Port for executable: 53723 | 2016-05-20 06:14:25 Listening socket (1268), port 53723 | Closed. | 2016-05-20 06:14:25 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2016-05-20 06:14:25 Intraday data recording state for symbol CLN6-NYMEX is set to download 'Pending'. | 2016-05-20 06:14:37 HD Request # 13 | Downloading Intraday chart data for CLN6-NYMEX to the file CLN6-NYMEX.scid. Service: rim | 2016-05-20 06:14:37 HD Request # 13 | Download start Date-Time: 2016-05-19 21:38:27.000 | 2016-05-20 06:14:37 HD Request # 13 | Using server: ds4.sierracharts.com port 10149 | 2016-05-20 06:14:37 Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26. | 2016-05-20 06:14:37 Socket (11) | Connected. | 2016-05-20 06:14:37 HD Request # 13 | Sending historical data logon request message. | 2016-05-20 06:14:37 HD Request # 13 | Requesting Intraday data. Start Date-Time: 2016-05-19 21:38:27. Record interval: 0. Symbol: CLN6-NYMEX | 2016-05-20 06:14:37 Socket (11) | Shutdown and closed. | 2016-05-20 06:14:37 The network socket for historical data has been closed. | 2016-05-20 06:14:37 HD Request # 13 | Historical data for CLN6-NYMEX is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2016-05-20 06:14:37 HD Request # 13 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for CLN6-NYMEX | 2016-05-20 06:14:37 HD Request # 13 | Intraday download COMPLETE for CLN6-NYMEX. Completion time: 0s. Unique request ID: 12 | 2016-05-20 06:14:37 Removed historical data download ID 12 | 2016-05-20 06:14:37 Rithmic Trading | Connecting to the server 127.0.0.1. Port 53723 | 2016-05-20 06:14:38 Socket (12) | Connected. | 2016-05-20 06:14:38 Rithmic Trading | Connected to server. | 2016-05-20 06:14:38 Rithmic Trading | Sending Encoding Request to server | 2016-05-20 06:14:38 Rithmic Trading | Setting DTC Encoding to Binary | 2016-05-20 06:14:39 Rithmic Trading | Sending logon request message. | 2016-05-20 06:14:39 Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2016-05-20 06:14:39 Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2016-05-20 06:14:39 Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2016-05-20 06:14:39 Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2016-05-20 06:14:41 Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Complete. Result text: "ok" | 2016-05-20 06:14:42 Rithmic Trading | Message from server: Server Alert: Trading System Connection Opened | 2016-05-20 06:14:43 Rithmic Trading | Message from server: Server Alert: Trading System Connection Login Complete. Result text: "ok" | 2016-05-20 06:14:43 Rithmic Trading | Message from server: Server Alert: PnL Connection Opened | 2016-05-20 06:14:44 Rithmic Trading | Message from server: Server Alert: PnL Connection Login Complete. Result text: "ok" | 2016-05-20 06:14:44 Rithmic Trading | Message from server: Server Alert: Intraday History Connection Opened | 2016-05-20 06:14:45 Rithmic Trading | Message from server: Server Alert: Intraday History Connection Login Complete. Result text: "ok" | 2016-05-20 06:14:45 Rithmic Trading | Received logon response. | 2016-05-20 06:14:45 Rithmic Trading | Server Name: SC DTC Bridge. | 2016-05-20 06:14:45 Rithmic Trading | Server protocol version: 7. Client protocol version: 7 | 2016-05-20 06:14:45 Rithmic Trading | Successfully connected. IB='OptimusFutures'. | 2016-05-20 06:14:45 Rithmic Trading | Trading is supported. | 2016-05-20 06:14:45 Rithmic Trading | Order cancel and replace is supported. | 2016-05-20 06:14:45 Rithmic Trading | Connected to data and trading server. | 2016-05-20 06:14:45 Rithmic Trading | OCO Orders supported. | 2016-05-20 06:14:45 SC DTC Data | Starting real-time market data updates for: NISS-NYSE. ID: 1 | 2016-05-20 06:14:45 SC DTC Data | Connecting to the server ds5.sierracharts.com. Port 443 | 2016-05-20 06:14:45 Intraday data recording state for symbol NISS-NYSE is set to download 'Pending'. | 2016-05-20 06:14:45 Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106. | 2016-05-20 06:14:45 Delaying start of download for NISS-NYSE | 2016-05-20 06:14:45 SC DTC Data | Starting real-time market data updates for: TICK-NYSE. ID: 2 | 2016-05-20 06:14:45 Intraday data recording state for symbol TICK-NYSE is set to download 'Pending'. | 2016-05-20 06:14:45 Rithmic Trading | Starting real-time market data updates for: ESM6-CME. ID: 3 | 2016-05-20 06:14:45 Intraday data recording state for symbol ESM6-CME is set to download 'Pending'. | 2016-05-20 06:14:45 Socket (13) | Connected. | 2016-05-20 06:14:45 SC DTC Data | Connected to server. | 2016-05-20 06:14:45 SC DTC Data | Sending Encoding Request to server | 2016-05-20 06:14:45 Rithmic Trading | Starting real-time market data updates for: ZSN6-CBOT. ID: 4 | 2016-05-20 06:14:45 Intraday data recording state for symbol ZSN6-CBOT is set to download 'Pending'. | 2016-05-20 06:14:45 Rithmic Trading | Starting real-time market data updates for: NKDM6-CME. ID: 5 | 2016-05-20 06:14:46 Intraday data recording state for symbol NKDM6-CME is set to download 'Pending'. | 2016-05-20 06:14:46 Rithmic Trading | Starting real-time market data updates for: CLN6-NYMEX. ID: 6 | 2016-05-20 06:14:46 Intraday data recording state for symbol CLN6-NYMEX is set to download 'Pending'. | 2016-05-20 06:14:46 Rithmic Trading | Starting real-time market data updates for: CLM6-NYMEX. ID: 7 | 2016-05-20 06:14:46 Intraday data recording state for symbol CLM6-NYMEX is set to download 'Pending'. | 2016-05-20 06:14:46 SC DTC Data | Setting DTC Encoding to Binary VLS | 2016-05-20 06:14:46 SC DTC Data | Sending logon request message. | 2016-05-20 06:14:46 Rithmic Trading | Message from server: Server Alert: mrv error : 13. Result text: "permission denied" | 2016-05-20 06:14:46 SC DTC Data | Received logon response. | 2016-05-20 06:14:47 SC DTC Data | Server Name: SC Realtime Server. | 2016-05-20 06:14:47 SC DTC Data | Server protocol version: 7. Client protocol version: 7 | 2016-05-20 06:14:47 SC DTC Data | Successfully connected. | 2016-05-20 06:14:47 SC DTC Data | Restarting real-time data updates for symbol: NISS-NYSE | 2016-05-20 06:14:47 SC DTC Data | Restarting real-time data updates for symbol: TICK-NYSE | 2016-05-20 06:14:47 Delaying start of download for NISS-NYSE | 2016-05-20 06:14:47 ESM6-CME [CB] Daily #1 | Reloading chart. | 2016-05-20 06:14:47 ESM6-CME [CB] Daily #3 | Reloading chart. | 2016-05-20 06:14:47 ESM6-CME [CB] Daily #1 | Reloading chart. | 2016-05-20 06:14:47 ESM6-CME [CB] Daily #1 | Reloading chart. | 2016-05-20 06:14:47 Requesting market depth updates for: CLM6-NYMEX if supported. | 2016-05-20 06:14:51 Requesting market depth updates for: ESM6-CME if supported. | 2016-05-20 06:14:51 Requesting market depth updates for: NKDM6-CME if supported. | 2016-05-20 06:14:51 Requesting market depth updates for: ZSN6-CBOT if supported. | 2016-05-20 06:14:51 Rithmic Trading | Message from server: Server Alert: mrv error : 13. Result text: "permission denied" | 2016-05-20 06:14:51 Rithmic Trading | Message from server: Server Alert: get_order_book error : 13. Result text: "permission denied" | 2016-05-20 06:14:51 HD Request # 14 | Downloading Intraday chart data for NISS-NYSE to the file NISS-NYSE.scid. Service: statscalc | 2016-05-20 06:14:52 HD Request # 14 | Download start Date-Time: 2016-05-20 06:14:20.000 | 2016-05-20 06:14:52 HD Request # 14 | Using server: ds3.sierracharts.com port 10149 | 2016-05-20 06:14:52 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164. | 2016-05-20 06:14:52 Socket (14) | Connected. | 2016-05-20 06:14:52 HD Request # 14 | Sending historical data logon request message. | 2016-05-20 06:14:52 HD Request # 14 | Requesting Intraday data. Start Date-Time: 2016-05-20 06:14:20. Record interval: 0. Symbol: NISS-NYSE | 2016-05-20 06:14:52 HD Request # 14 | Decompressing data. | 2016-05-20 06:14:52 HD Request # 14 | Receiving Intraday data for NISS-NYSE starting at 2016-05-20 06:14:20 | 2016-05-20 06:14:52 HD Request # 14 | Timestamp of first Intraday data file record written: 2016-05-20 06:14:22 | 2016-05-20 06:14:52 Socket (14) | Shutdown and closed. | 2016-05-20 06:14:52 The network socket for historical data has been closed. | 2016-05-20 06:14:52 HD Request # 14 | Received 32 records from 2016-05-20 06:14:20 to 2016-05-20 06:14:52 (32.0 seconds) and wrote 31 records for NISS-NYSE | 2016-05-20 06:14:52 Added 9 Time and Sales records to Intraday data file for NISS-NYSE after download. | 2016-05-20 06:14:52 HD Request # 14 | Intraday download COMPLETE for NISS-NYSE. Completion time: 0s. Unique request ID: 13 | 2016-05-20 06:14:52 Removed historical data download ID 13 | 2016-05-20 06:14:52 Real-time Intraday chart data file updates started for NISS-NYSE | 2016-05-20 06:14:52 Opened cached Intraday file: C:\SierraChart\Data\NISS-NYSE.scid | 2016-05-20 06:14:52 Intraday chart data file opened for NISS-NYSE | 2016-05-20 06:14:52 Delaying start of download for TICK-NYSE | 2016-05-20 06:14:52 Chart #3 has tagged chart #1 for full recalculation. Chartbook: TICK&NISS.cht | 2016-05-20 06:14:52 ESM6-CME [CB] 1 Min #1 | Performing a full recalculation because it has been tagged. Chartbook: TICK&NISS.cht | 2016-05-20 06:14:52 HD Request # 15 | Downloading Intraday chart data for TICK-NYSE to the file TICK-NYSE.scid. Service: statscalc | 2016-05-20 06:14:53 HD Request # 15 | Download start Date-Time: 2016-05-19 13:05:00.000 | 2016-05-20 06:14:53 HD Request # 15 | Using server: ds4.sierracharts.com port 10149 | 2016-05-20 06:14:53 Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26. | 2016-05-20 06:14:53 Socket (15) | Connected. | 2016-05-20 06:14:53 HD Request # 15 | Sending historical data logon request message. | 2016-05-20 06:14:53 HD Request # 15 | Requesting Intraday data. Start Date-Time: 2016-05-19 13:05:00. Record interval: 0. Symbol: TICK-NYSE | 2016-05-20 06:14:53 HD Request # 15 | Decompressing data. | 2016-05-20 06:14:53 HD Request # 15 | Receiving Intraday data for TICK-NYSE starting at 2016-05-19 13:05:00 | 2016-05-20 06:14:53 Socket (15) | Shutdown and closed. | 2016-05-20 06:14:53 The network socket for historical data has been closed. | 2016-05-20 06:14:53 HD Request # 15 | Received 1 record from 2016-05-19 13:05:00 to 2016-05-19 13:05:00 (0.0 seconds) and wrote 0 records for TICK-NYSE | 2016-05-20 06:14:53 HD Request # 15 | Intraday download COMPLETE for TICK-NYSE. Completion time: 0s. Unique request ID: 14 | 2016-05-20 06:14:53 Removed historical data download ID 14 | 2016-05-20 06:14:53 Real-time Intraday chart data file updates started for TICK-NYSE | 2016-05-20 06:14:53 Opened cached Intraday file: C:\SierraChart\Data\TICK-NYSE.scid | 2016-05-20 06:14:53 Intraday chart data file opened for TICK-NYSE | 2016-05-20 06:14:53 HD Request # 16 | Downloading Intraday chart data for ESM6-CME to the file ESM6-CME.scid. Service: rim | 2016-05-20 06:14:53 HD Request # 16 | Download start Date-Time: 2016-05-19 21:38:28.000 | 2016-05-20 06:14:53 HD Request # 16 | Using server: ds5.sierracharts.com port 10149 | 2016-05-20 06:14:53 Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106. | 2016-05-20 06:14:53 Chart #2 has tagged chart #1 for full recalculation. Chartbook: primary 5m.cht | 2016-05-20 06:14:53 Socket (16) | Connected. | 2016-05-20 06:14:53 HD Request # 16 | Sending historical data logon request message. | 2016-05-20 06:14:53 Chart #2 has tagged chart #1 for full recalculation. Chartbook: TICK&NISS.cht | 2016-05-20 06:14:53 ESM6-CME [CB] 5 Min #1 | Performing a full recalculation because it has been tagged. Chartbook: primary 5m.cht | 2016-05-20 06:14:53 ESM6-CME [CB] 1 Min #1 | Performing a full recalculation because it has been tagged. Chartbook: TICK&NISS.cht | 2016-05-20 06:14:53 HD Request # 16 | Requesting Intraday data. Start Date-Time: 2016-05-19 21:38:28. Record interval: 0. Symbol: ESM6-CME | 2016-05-20 06:14:53 HD Request # 16 | Decompressing data. | 2016-05-20 06:14:53 HD Request # 16 | Receiving Intraday data for ESM6-CME starting at 2016-05-19 21:38:28 | 2016-05-20 06:14:53 HD Request # 16 | Timestamp of first Intraday data file record written: 2016-05-19 21:38:46 | 2016-05-20 06:14:53 Socket (16) | Shutdown and closed. | 2016-05-20 06:14:54 The network socket for historical data has been closed. | 2016-05-20 06:14:54 HD Request # 16 | Received 69537 records from 2016-05-19 21:38:28 to 2016-05-20 06:14:51 (8.6 hours) and wrote 69536 records for ESM6-CME | 2016-05-20 06:14:54 HD Request # 16 | Intraday download COMPLETE for ESM6-CME. Completion time: 1s. Unique request ID: 15 | 2016-05-20 06:14:54 Removed historical data download ID 15 | 2016-05-20 06:14:54 Real-time Intraday chart data file updates started for ESM6-CME | 2016-05-20 06:14:54 Opened cached Intraday file: C:\SierraChart\Data\ESM6-CME.scid | 2016-05-20 06:14:54 Intraday chart data file opened for ESM6-CME | 2016-05-20 06:14:54 Delaying start of download for ZSN6-CBOT | 2016-05-20 06:14:54 Chart #2 has tagged chart #1 for full recalculation. Chartbook: YHLC.cht | 2016-05-20 06:14:56 Chart #2 has tagged chart #1 for full recalculation. Chartbook: YHLC.cht | 2016-05-20 06:14:56 Chart #2 has tagged chart #1 for full recalculation. Chartbook: YHLC.cht | 2016-05-20 06:14:56 ESM6-CME [CB] 60 Min #1 | Performing a full recalculation because it has been tagged. Chartbook: YHLC.cht | 2016-05-20 06:14:56 HD Request # 17 | Downloading Intraday chart data for ZSN6-CBOT to the file ZSN6-CBOT.scid. Service: rim | 2016-05-20 06:15:05 HD Request # 17 | Download start Date-Time: 2016-05-19 20:07:41.000 | 2016-05-20 06:15:05 HD Request # 17 | Using server: ds3.sierracharts.com port 10149 | 2016-05-20 06:15:05 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164. | 2016-05-20 06:15:05 Socket (17) | Connected. | 2016-05-20 06:15:05 HD Request # 17 | Sending historical data logon request message. | 2016-05-20 06:15:05 HD Request # 17 | Requesting Intraday data. Start Date-Time: 2016-05-19 20:07:41. Record interval: 0. Symbol: ZSN6-CBOT | 2016-05-20 06:15:06 HD Request # 17 | Decompressing data. | 2016-05-20 06:15:06 HD Request # 17 | Receiving Intraday data for ZSN6-CBOT starting at 2016-05-19 20:07:41 | 2016-05-20 06:15:06 HD Request # 17 | Timestamp of first Intraday data file record written: 2016-05-19 20:09:09 | 2016-05-20 06:15:06 Socket (17) | Shutdown and closed. | 2016-05-20 06:15:06 The network socket for historical data has been closed. | 2016-05-20 06:15:06 HD Request # 17 | Received 9368 records from 2016-05-19 20:07:41 to 2016-05-20 05:44:56 (9.6 hours) and wrote 9367 records for ZSN6-CBOT | 2016-05-20 06:15:06 HD Request # 17 | Intraday download COMPLETE for ZSN6-CBOT. Completion time: 0s. Unique request ID: 16 | 2016-05-20 06:15:06 Removed historical data download ID 16 | 2016-05-20 06:15:06 Real-time Intraday chart data file updates started for ZSN6-CBOT | 2016-05-20 06:15:06 Opened cached Intraday file: C:\SierraChart\Data\ZSN6-CBOT.scid | 2016-05-20 06:15:06 Intraday chart data file opened for ZSN6-CBOT | 2016-05-20 06:15:06 HD Request # 18 | Downloading Intraday chart data for NKDM6-CME to the file NKDM6-CME.scid. Service: rim | 2016-05-20 06:15:06 HD Request # 18 | Download start Date-Time: 2016-05-19 21:37:25.000 | 2016-05-20 06:15:06 HD Request # 18 | Using server: ds4.sierracharts.com port 10149 | 2016-05-20 06:15:06 Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26. | 2016-05-20 06:15:06 Socket (18) | Connected. | 2016-05-20 06:15:06 HD Request # 18 | Sending historical data logon request message. | 2016-05-20 06:15:06 HD Request # 18 | Requesting Intraday data. Start Date-Time: 2016-05-19 21:37:25. Record interval: 0. Symbol: NKDM6-CME | 2016-05-20 06:15:06 HD Request # 18 | Decompressing data. | 2016-05-20 06:15:07 HD Request # 18 | Receiving Intraday data for NKDM6-CME starting at 2016-05-19 21:37:26 | 2016-05-20 06:15:07 HD Request # 18 | Timestamp of first Intraday data file record written: 2016-05-19 21:37:26 | 2016-05-20 06:15:07 Socket (18) | Shutdown and closed. | 2016-05-20 06:15:07 The network socket for historical data has been closed. | 2016-05-20 06:15:07 HD Request # 18 | Received 2579 records from 2016-05-19 21:37:26 to 2016-05-20 06:13:10 (8.6 hours) and wrote 2579 records for NKDM6-CME | 2016-05-20 06:15:07 HD Request # 18 | Intraday download COMPLETE for NKDM6-CME. Completion time: 1s. Unique request ID: 17 | 2016-05-20 06:15:07 Removed historical data download ID 17 | 2016-05-20 06:15:07 Real-time Intraday chart data file updates started for NKDM6-CME | 2016-05-20 06:15:07 Opened cached Intraday file: C:\SierraChart\Data\NKDM6-CME.scid | 2016-05-20 06:15:07 Intraday chart data file opened for NKDM6-CME | 2016-05-20 06:15:07 HD Request # 19 | Downloading Intraday chart data for CLN6-NYMEX to the file CLN6-NYMEX.scid. Service: rim | 2016-05-20 06:15:07 HD Request # 19 | Download start Date-Time: 2016-05-19 21:38:27.000 | 2016-05-20 06:15:07 HD Request # 19 | Using server: ds5.sierracharts.com port 10149 | 2016-05-20 06:15:07 Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106. | 2016-05-20 06:15:07 Socket (19) | Connected. | 2016-05-20 06:15:07 HD Request # 19 | Sending historical data logon request message. | 2016-05-20 06:15:07 HD Request # 19 | Requesting Intraday data. Start Date-Time: 2016-05-19 21:38:27. Record interval: 0. Symbol: CLN6-NYMEX | 2016-05-20 06:15:07 HD Request # 19 | Decompressing data. | 2016-05-20 06:15:08 HD Request # 19 | Receiving Intraday data for CLN6-NYMEX starting at 2016-05-19 21:38:27 | 2016-05-20 06:15:08 HD Request # 19 | Timestamp of first Intraday data file record written: 2016-05-19 21:38:44 | 2016-05-20 06:15:08 Socket (19) | Shutdown and closed. | 2016-05-20 06:15:08 The network socket for historical data has been closed. | 2016-05-20 06:15:08 HD Request # 19 | Received 82829 records from 2016-05-19 21:38:27 to 2016-05-20 06:15:08 (8.6 hours) and wrote 82828 records for CLN6-NYMEX | 2016-05-20 06:15:08 Added 3 Time and Sales records to Intraday data file for CLN6-NYMEX after download. | 2016-05-20 06:15:08 HD Request # 19 | Intraday download COMPLETE for CLN6-NYMEX. Completion time: 1s. Unique request ID: 18 | 2016-05-20 06:15:08 Removed historical data download ID 18 | 2016-05-20 06:15:08 Real-time Intraday chart data file updates started for CLN6-NYMEX | 2016-05-20 06:15:08 Opened cached Intraday file: C:\SierraChart\Data\CLN6-NYMEX.scid | 2016-05-20 06:15:08 Intraday chart data file opened for CLN6-NYMEX | 2016-05-20 06:15:08 HD Request # 20 | Downloading Intraday chart data for CLM6-NYMEX to the file CLM6-NYMEX.scid. Service: rim | 2016-05-20 06:15:08 HD Request # 20 | Download start Date-Time: 2016-05-19 21:06:03.000 | 2016-05-20 06:15:08 HD Request # 20 | Using server: ds3.sierracharts.com port 10149 | 2016-05-20 06:15:08 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164. | 2016-05-20 06:15:08 Socket (20) | Connected. | 2016-05-20 06:15:09 HD Request # 20 | Sending historical data logon request message. | 2016-05-20 06:15:09 HD Request # 20 | Requesting Intraday data. Start Date-Time: 2016-05-19 21:06:03. Record interval: 0. Symbol: CLM6-NYMEX | 2016-05-20 06:15:09 HD Request # 20 | Decompressing data. | 2016-05-20 06:15:09 HD Request # 20 | Receiving Intraday data for CLM6-NYMEX starting at 2016-05-19 21:06:03 | 2016-05-20 06:15:09 HD Request # 20 | Timestamp of first Intraday data file record written: 2016-05-19 21:47:10 | 2016-05-20 06:15:09 Socket (20) | Shutdown and closed. | 2016-05-20 06:15:09 The network socket for historical data has been closed. | 2016-05-20 06:15:09 HD Request # 20 | Received 506 records from 2016-05-19 21:06:03 to 2016-05-20 06:14:56 (9.1 hours) and wrote 505 records for CLM6-NYMEX | 2016-05-20 06:15:09 HD Request # 20 | Intraday download COMPLETE for CLM6-NYMEX. Completion time: 0s. Unique request ID: 19 | 2016-05-20 06:15:09 Removed historical data download ID 19 | 2016-05-20 06:15:09 Real-time Intraday chart data file updates started for CLM6-NYMEX | 2016-05-20 06:15:09 Opened cached Intraday file: C:\SierraChart\Data\CLM6-NYMEX.scid | 2016-05-20 06:15:09 Intraday chart data file opened for CLM6-NYMEX | 2016-05-20 06:15:09 HTTP connection to ds01.ddfplus.com:80 (4) | Closed. No error. | 2016-05-20 06:15:26 HTTP connection to ds01.ddfplus.com:80 (4) | Shutdown and closed. | 2016-05-20 06:15:26 Uploaded an image to the server. Request ID: 1 | 2016-05-20 06:32:22 HTTP connection to www.sierrachart.com:80 (0) | Resolved address sierrachart.com to IP 5.9.8.236. | 2016-05-20 06:32:22 HTTP connection to www.sierrachart.com:80 (30) | Connected. | 2016-05-20 06:32:22 HTTP connection to www.sierrachart.com:80 (30) | Closed. No error. | 2016-05-20 06:32:28 HTTP connection to www.sierrachart.com:80 (30) | Shutdown and closed. | 2016-05-20 06:32:28 Uploaded an image to the server. Request ID: 2 | 2016-05-20 06:32:52 HTTP connection to www.sierrachart.com:80 (0) | Resolved address sierrachart.com to IP 5.9.8.236. | 2016-05-20 06:32:52 HTTP connection to www.sierrachart.com:80 (31) | Connected. | 2016-05-20 06:32:52 HTTP connection to www.sierrachart.com:80 (31) | Closed. No error. | 2016-05-20 06:32:57 HTTP connection to www.sierrachart.com:80 (31) | Shutdown and closed. | 2016-05-20 06:32:57 Notice: Detected that the system has resumed from a low-power state. | 2016-05-20 10:36:38 Re-connecting to the Data/Trading service. | 2016-05-20 10:36:38 Socket (12) | Shutdown and closed. | 2016-05-20 10:36:38 Socket (13) | Shutdown and closed. | 2016-05-20 10:36:38 SC DTC Data | Disconnected from the server. | 2016-05-20 10:36:38 Rithmic Trading | Disconnected. | 2016-05-20 10:36:38 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-05-20 10:36:38 Rithmic Trading | Port for executable: 56393 | 2016-05-20 10:36:40 Listening socket (588), port 56393 | Closed. | 2016-05-20 10:36:40 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2016-05-20 10:36:40 Rithmic Trading | Connecting to the server 127.0.0.1. Port 56393 | 2016-05-20 10:36:47 Socket (103) | Connected. | 2016-05-20 10:36:48 Rithmic Trading | Connected to server. | 2016-05-20 10:36:48 Rithmic Trading | Sending Encoding Request to server | 2016-05-20 10:36:48 Rithmic Trading | Setting DTC Encoding to Binary | 2016-05-20 10:36:48 Rithmic Trading | Sending logon request message. | 2016-05-20 10:36:48 Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2016-05-20 10:36:48 Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2016-05-20 10:36:48 Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2016-05-20 10:36:48 Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2016-05-20 10:36:50 Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Complete. Result text: "ok" | 2016-05-20 10:36:50 Rithmic Trading | Message from server: Server Alert: Trading System Connection Opened | 2016-05-20 10:36:50 Rithmic Trading | Message from server: Server Alert: Trading System Connection Login Complete. Result text: "ok" | 2016-05-20 10:36:51 Rithmic Trading | Message from server: Server Alert: PnL Connection Opened | 2016-05-20 10:36:51 Rithmic Trading | Message from server: Server Alert: PnL Connection Login Complete. Result text: "ok" | 2016-05-20 10:36:51 Rithmic Trading | Message from server: Server Alert: Intraday History Connection Opened | 2016-05-20 10:36:52 Rithmic Trading | Message from server: Server Alert: Intraday History Connection Login Complete. Result text: "ok" | 2016-05-20 10:36:52 Rithmic Trading | Received logon response. | 2016-05-20 10:36:53 Rithmic Trading | Server Name: SC DTC Bridge. | 2016-05-20 10:36:53 Rithmic Trading | Server protocol version: 7. Client protocol version: 7 | 2016-05-20 10:36:53 Rithmic Trading | Successfully connected. IB='OptimusFutures'. | 2016-05-20 10:36:53 Rithmic Trading | Trading is supported. | 2016-05-20 10:36:53 Rithmic Trading | Order cancel and replace is supported. | 2016-05-20 10:36:53 Rithmic Trading | Connected to data and trading server. | 2016-05-20 10:36:53 Rithmic Trading | OCO Orders supported. | 2016-05-20 10:36:53 Rithmic Trading | Starting real-time market data updates for: ESM6-CME. ID: 1 | 2016-05-20 10:36:53 Intraday data recording state for symbol ESM6-CME is set to download 'Pending'. | 2016-05-20 10:36:53 Delaying start of download for ESM6-CME | 2016-05-20 10:36:53 Rithmic Trading | Starting real-time market data updates for: ZSN6-CBOT. ID: 2 | 2016-05-20 10:36:53 Intraday data recording state for symbol ZSN6-CBOT is set to download 'Pending'. | 2016-05-20 10:36:53 Rithmic Trading | Starting real-time market data updates for: NKDM6-CME. ID: 3 | 2016-05-20 10:36:53 Intraday data recording state for symbol NKDM6-CME is set to download 'Pending'. | 2016-05-20 10:36:53 SC DTC Data | Starting real-time market data updates for: NISS-NYSE. ID: 4 | 2016-05-20 10:36:53 SC DTC Data | Connecting to the server ds4.sierracharts.com. Port 10048 | 2016-05-20 10:36:53 Intraday data recording state for symbol NISS-NYSE is set to download 'Pending'. | 2016-05-20 10:36:53 SC DTC Data | Starting real-time market data updates for: TICK-NYSE. ID: 5 | 2016-05-20 10:36:53 Intraday data recording state for symbol TICK-NYSE is set to download 'Pending'. | 2016-05-20 10:36:53 Rithmic Trading | Starting real-time market data updates for: CLN6-NYMEX. ID: 6 | 2016-05-20 10:36:53 Intraday data recording state for symbol CLN6-NYMEX is set to download 'Pending'. | 2016-05-20 10:36:53 Rithmic Trading | Starting real-time market data updates for: CLM6-NYMEX. ID: 7 | 2016-05-20 10:36:53 Intraday data recording state for symbol CLM6-NYMEX is set to download 'Pending'. | 2016-05-20 10:36:53 Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26. | 2016-05-20 10:36:53 Socket (104) | Connected. | 2016-05-20 10:36:53 SC DTC Data | Connected to server. | 2016-05-20 10:36:53 SC DTC Data | Sending Encoding Request to server | 2016-05-20 10:36:53 Rithmic Trading | Message from server: Server Alert: mrv error : 13. Result text: "permission denied" | 2016-05-20 10:36:53 SC DTC Data | Setting DTC Encoding to Binary VLS | 2016-05-20 10:36:53 SC DTC Data | Sending logon request message. | 2016-05-20 10:36:53 ESM6-CME [CB] Daily #1 | Reloading chart. | 2016-05-20 10:36:54 SC DTC Data | Received logon response. | 2016-05-20 10:36:54 SC DTC Data | Server Name: SC Realtime Server. | 2016-05-20 10:36:54 SC DTC Data | Server protocol version: 7. Client protocol version: 7 | 2016-05-20 10:36:54 SC DTC Data | Successfully connected. | 2016-05-20 10:36:54 SC DTC Data | Restarting real-time data updates for symbol: NISS-NYSE | 2016-05-20 10:36:54 SC DTC Data | Restarting real-time data updates for symbol: TICK-NYSE | 2016-05-20 10:36:54 ESM6-CME [CB] Daily #1 | Reloading chart. | 2016-05-20 10:36:54 ESM6-CME [CB] Daily #3 | Reloading chart. | 2016-05-20 10:36:54 ESM6-CME [CB] Daily #1 | Reloading chart. | 2016-05-20 10:36:54 Delaying start of download for ESM6-CME | 2016-05-20 10:36:54 Requesting market depth updates for: CLM6-NYMEX if supported. | 2016-05-20 10:36:58 Requesting market depth updates for: ESM6-CME if supported. | 2016-05-20 10:36:58 Requesting market depth updates for: NKDM6-CME if supported. | 2016-05-20 10:36:58 Requesting market depth updates for: ZSN6-CBOT if supported. | 2016-05-20 10:36:58 Rithmic Trading | Message from server: Server Alert: mrv error : 13. Result text: "permission denied" | 2016-05-20 10:36:58 Rithmic Trading | Message from server: Server Alert: get_order_book error : 13. Result text: "permission denied" | 2016-05-20 10:36:58 HD Request # 21 | Downloading Intraday chart data for ESM6-CME to the file ESM6-CME.scid. Service: rim | 2016-05-20 10:36:59 HD Request # 21 | Download start Date-Time: 2016-05-20 08:49:01.000 | 2016-05-20 10:36:59 HD Request # 21 | Using server: ds5.sierracharts.com port 10149 | 2016-05-20 10:36:59 Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106. | 2016-05-20 10:36:59 Socket (105) | Connected. | 2016-05-20 10:36:59 HD Request # 21 | Sending historical data logon request message. | 2016-05-20 10:36:59 HD Request # 21 | Requesting Intraday data. Start Date-Time: 2016-05-20 08:49:01. Record interval: 0. Symbol: ESM6-CME | 2016-05-20 10:37:00 HD Request # 21 | Decompressing data. | 2016-05-20 10:37:00 HD Request # 21 | Receiving Intraday data for ESM6-CME starting at 2016-05-20 08:49:01 | 2016-05-20 10:37:00 HD Request # 21 | Timestamp of first Intraday data file record written: 2016-05-20 08:49:01 | 2016-05-20 10:37:00 Socket (105) | Shutdown and closed. | 2016-05-20 10:37:00 The network socket for historical data has been closed. | 2016-05-20 10:37:00 HD Request # 21 | Received 63342 records from 2016-05-20 08:49:01 to 2016-05-20 10:36:59 (108.0 minutes) and wrote 63340 records for ESM6-CME | 2016-05-20 10:37:00 Added 2 Time and Sales records to Intraday data file for ESM6-CME after download. | 2016-05-20 10:37:00 HD Request # 21 | Intraday download COMPLETE for ESM6-CME. Completion time: 2s. Unique request ID: 20 | 2016-05-20 10:37:00 Removed historical data download ID 20 | 2016-05-20 10:37:00 Real-time Intraday chart data file updates started for ESM6-CME | 2016-05-20 10:37:00 Opened cached Intraday file: C:\SierraChart\Data\ESM6-CME.scid | 2016-05-20 10:37:00 Intraday chart data file opened for ESM6-CME | 2016-05-20 10:37:00 Delaying start of download for ZSN6-CBOT | 2016-05-20 10:37:00 Chart #2 has tagged chart #1 for full recalculation. Chartbook: YHLC.cht | 2016-05-20 10:37:01 ESM6-CME [CB] 60 Min #1 | Performing a full recalculation because it has been tagged. Chartbook: YHLC.cht | 2016-05-20 10:37:01 HD Request # 22 | Downloading Intraday chart data for ZSN6-CBOT to the file ZSN6-CBOT.scid. Service: rim | 2016-05-20 10:37:11 HD Request # 22 | Download start Date-Time: 2016-05-20 05:44:56.000 | 2016-05-20 10:37:11 HD Request # 22 | Using server: ds3.sierracharts.com port 10149 | 2016-05-20 10:37:11 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164. | 2016-05-20 10:37:11 Socket (106) | Connected. | 2016-05-20 10:37:11 HD Request # 22 | Sending historical data logon request message. | 2016-05-20 10:37:11 HD Request # 22 | Requesting Intraday data. Start Date-Time: 2016-05-20 05:44:56. Record interval: 0. Symbol: ZSN6-CBOT | 2016-05-20 10:37:11 HD Request # 22 | Decompressing data. | 2016-05-20 10:37:11 HD Request # 22 | Receiving Intraday data for ZSN6-CBOT starting at 2016-05-20 05:44:56 | 2016-05-20 10:37:11 HD Request # 22 | Timestamp of first Intraday data file record written: 2016-05-20 06:30:00 | 2016-05-20 10:37:11 Socket (106) | Shutdown and closed. | 2016-05-20 10:37:11 The network socket for historical data has been closed. | 2016-05-20 10:37:11 HD Request # 22 | Received 55626 records from 2016-05-20 05:44:56 to 2016-05-20 10:37:09 (4.9 hours) and wrote 55615 records for ZSN6-CBOT | 2016-05-20 10:37:11 HD Request # 22 | Intraday download COMPLETE for ZSN6-CBOT. Completion time: 1s. Unique request ID: 21 | 2016-05-20 10:37:11 Removed historical data download ID 21 | 2016-05-20 10:37:11 Real-time Intraday chart data file updates started for ZSN6-CBOT | 2016-05-20 10:37:11 Opened cached Intraday file: C:\SierraChart\Data\ZSN6-CBOT.scid | 2016-05-20 10:37:11 Intraday chart data file opened for ZSN6-CBOT | 2016-05-20 10:37:11 HD Request # 23 | Downloading Intraday chart data for NKDM6-CME to the file NKDM6-CME.scid. Service: rim | 2016-05-20 10:37:11 HD Request # 23 | Download start Date-Time: 2016-05-20 08:48:59.000 | 2016-05-20 10:37:11 HD Request # 23 | Using server: ds4.sierracharts.com port 10149 | 2016-05-20 10:37:11 Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26. | 2016-05-20 10:37:11 Socket (107) | Connected. | 2016-05-20 10:37:11 HD Request # 23 | Sending historical data logon request message. | 2016-05-20 10:37:11 HD Request # 23 | Requesting Intraday data. Start Date-Time: 2016-05-20 08:48:59. Record interval: 0. Symbol: NKDM6-CME | 2016-05-20 10:37:12 HD Request # 23 | Decompressing data. | 2016-05-20 10:37:12 HD Request # 23 | Receiving Intraday data for NKDM6-CME starting at 2016-05-20 08:48:59 | 2016-05-20 10:37:12 HD Request # 23 | Timestamp of first Intraday data file record written: 2016-05-20 08:48:59 | 2016-05-20 10:37:12 Socket (107) | Shutdown and closed. | 2016-05-20 10:37:12 The network socket for historical data has been closed. | 2016-05-20 10:37:12 HD Request # 23 | Received 758 records from 2016-05-20 08:48:59 to 2016-05-20 10:36:59 (108.0 minutes) and wrote 756 records for NKDM6-CME | 2016-05-20 10:37:12 HD Request # 23 | Intraday download COMPLETE for NKDM6-CME. Completion time: 1s. Unique request ID: 22 | 2016-05-20 10:37:12 Removed historical data download ID 22 | 2016-05-20 10:37:12 Real-time Intraday chart data file updates started for NKDM6-CME | 2016-05-20 10:37:12 Opened cached Intraday file: C:\SierraChart\Data\NKDM6-CME.scid | 2016-05-20 10:37:12 Intraday chart data file opened for NKDM6-CME | 2016-05-20 10:37:12 HD Request # 24 | Downloading Intraday chart data for NISS-NYSE to the file NISS-NYSE.scid. Service: statscalc | 2016-05-20 10:37:12 HD Request # 24 | Download start Date-Time: 2016-05-20 08:49:02.000 | 2016-05-20 10:37:12 HD Request # 24 | Using server: ds5.sierracharts.com port 10149 | 2016-05-20 10:37:12 Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106. | 2016-05-20 10:37:12 Socket (108) | Connected. | 2016-05-20 10:37:12 HD Request # 24 | Sending historical data logon request message. | 2016-05-20 10:37:12 HD Request # 24 | Requesting Intraday data. Start Date-Time: 2016-05-20 08:49:02. Record interval: 0. Symbol: NISS-NYSE | 2016-05-20 10:37:13 HD Request # 24 | Decompressing data. | 2016-05-20 10:37:13 HD Request # 24 | Receiving Intraday data for NISS-NYSE starting at 2016-05-20 08:49:02 | 2016-05-20 10:37:13 HD Request # 24 | Timestamp of first Intraday data file record written: 2016-05-20 08:49:03 | 2016-05-20 10:37:13 Socket (108) | Shutdown and closed. | 2016-05-20 10:37:13 The network socket for historical data has been closed. | 2016-05-20 10:37:13 HD Request # 24 | Received 6491 records from 2016-05-20 08:49:02 to 2016-05-20 10:37:12 (108.2 minutes) and wrote 6490 records for NISS-NYSE | 2016-05-20 10:37:13 Added 3 Time and Sales records to Intraday data file for NISS-NYSE after download. | 2016-05-20 10:37:13 HD Request # 24 | Intraday download COMPLETE for NISS-NYSE. Completion time: 0s. Unique request ID: 23 | 2016-05-20 10:37:13 Removed historical data download ID 23 | 2016-05-20 10:37:13 Real-time Intraday chart data file updates started for NISS-NYSE | 2016-05-20 10:37:13 Opened cached Intraday file: C:\SierraChart\Data\NISS-NYSE.scid | 2016-05-20 10:37:13 Intraday chart data file opened for NISS-NYSE | 2016-05-20 10:37:13 HD Request # 25 | Downloading Intraday chart data for TICK-NYSE to the file TICK-NYSE.scid. Service: statscalc | 2016-05-20 10:37:13 HD Request # 25 | Download start Date-Time: 2016-05-20 08:49:02.000 | 2016-05-20 10:37:13 HD Request # 25 | Using server: ds3.sierracharts.com port 10149 | 2016-05-20 10:37:13 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164. | 2016-05-20 10:37:13 Chart #4 has tagged chart #1 for full recalculation. Chartbook: primary 5m.cht | 2016-05-20 10:37:13 Socket (109) | Connected. | 2016-05-20 10:37:13 HD Request # 25 | Sending historical data logon request message. | 2016-05-20 10:37:13 HD Request # 25 | Requesting Intraday data. Start Date-Time: 2016-05-20 08:49:02. Record interval: 0. Symbol: TICK-NYSE | 2016-05-20 10:37:14 HD Request # 25 | Decompressing data. | 2016-05-20 10:37:14 HD Request # 25 | Receiving Intraday data for TICK-NYSE starting at 2016-05-20 08:49:02 | 2016-05-20 10:37:14 HD Request # 25 | Timestamp of first Intraday data file record written: 2016-05-20 08:49:03 | 2016-05-20 10:37:14 Chart #3 has tagged chart #1 for full recalculation. Chartbook: TICK&NISS.cht | 2016-05-20 10:37:14 ESM6-CME [CB] 1 Min #1 | Performing a full recalculation because it has been tagged. Chartbook: TICK&NISS.cht | 2016-05-20 10:37:14 ESM6-CME [CB] 5 Min #1 | Performing a full recalculation because it has been tagged. Chartbook: primary 5m.cht | 2016-05-20 10:37:14 Socket (109) | Shutdown and closed. | 2016-05-20 10:37:14 The network socket for historical data has been closed. | 2016-05-20 10:37:14 HD Request # 25 | Received 6491 records from 2016-05-20 08:49:02 to 2016-05-20 10:37:12 (108.2 minutes) and wrote 6490 records for TICK-NYSE | 2016-05-20 10:37:14 Added 6 Time and Sales records to Intraday data file for TICK-NYSE after download. | 2016-05-20 10:37:14 HD Request # 25 | Intraday download COMPLETE for TICK-NYSE. Completion time: 1s. Unique request ID: 24 | 2016-05-20 10:37:14 Removed historical data download ID 24 | 2016-05-20 10:37:14 Real-time Intraday chart data file updates started for TICK-NYSE | 2016-05-20 10:37:14 Opened cached Intraday file: C:\SierraChart\Data\TICK-NYSE.scid | 2016-05-20 10:37:14 Intraday chart data file opened for TICK-NYSE | 2016-05-20 10:37:14 HD Request # 26 | Downloading Intraday chart data for CLN6-NYMEX to the file CLN6-NYMEX.scid. Service: rim | 2016-05-20 10:37:14 HD Request # 26 | Download start Date-Time: 2016-05-20 08:49:02.000 | 2016-05-20 10:37:14 HD Request # 26 | Using server: ds4.sierracharts.com port 10149 | 2016-05-20 10:37:14 Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26. | 2016-05-20 10:37:14 Chart #2 has tagged chart #1 for full recalculation. Chartbook: primary 5m.cht | 2016-05-20 10:37:14 Socket (110) | Connected. | 2016-05-20 10:37:14 HD Request # 26 | Sending historical data logon request message. | 2016-05-20 10:37:14 Chart #2 has tagged chart #1 for full recalculation. Chartbook: TICK&NISS.cht | 2016-05-20 10:37:14 ESM6-CME [CB] 1 Min #1 | Performing a full recalculation because it has been tagged. Chartbook: TICK&NISS.cht | 2016-05-20 10:37:14 HD Request # 26 | Requesting Intraday data. Start Date-Time: 2016-05-20 08:49:02. Record interval: 0. Symbol: CLN6-NYMEX | 2016-05-20 10:37:14 ESM6-CME [CB] 5 Min #1 | Performing a full recalculation because it has been tagged. Chartbook: primary 5m.cht | 2016-05-20 10:37:14 HD Request # 26 | Decompressing data. | 2016-05-20 10:37:14 HD Request # 26 | Receiving Intraday data for CLN6-NYMEX starting at 2016-05-20 08:49:02 | 2016-05-20 10:37:14 HD Request # 26 | Timestamp of first Intraday data file record written: 2016-05-20 08:49:02 | 2016-05-20 10:37:14 Socket (110) | Shutdown and closed. | 2016-05-20 10:37:15 The network socket for historical data has been closed. | 2016-05-20 10:37:15 HD Request # 26 | Received 41377 records from 2016-05-20 08:49:02 to 2016-05-20 10:37:12 (108.2 minutes) and wrote 41376 records for CLN6-NYMEX | 2016-05-20 10:37:15 HD Request # 26 | Intraday download COMPLETE for CLN6-NYMEX. Completion time: 1s. Unique request ID: 25 | 2016-05-20 10:37:15 Removed historical data download ID 25 | 2016-05-20 10:37:15 Real-time Intraday chart data file updates started for CLN6-NYMEX | 2016-05-20 10:37:15 Opened cached Intraday file: C:\SierraChart\Data\CLN6-NYMEX.scid | 2016-05-20 10:37:15 Intraday chart data file opened for CLN6-NYMEX | 2016-05-20 10:37:15 HD Request # 27 | Downloading Intraday chart data for CLM6-NYMEX to the file CLM6-NYMEX.scid. Service: rim | 2016-05-20 10:37:15 HD Request # 27 | Download start Date-Time: 2016-05-20 08:48:55.000 | 2016-05-20 10:37:15 HD Request # 27 | Using server: ds5.sierracharts.com port 10149 | 2016-05-20 10:37:15 Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106. | 2016-05-20 10:37:15 Socket (111) | Connected. | 2016-05-20 10:37:15 HD Request # 27 | Sending historical data logon request message. | 2016-05-20 10:37:15 HD Request # 27 | Requesting Intraday data. Start Date-Time: 2016-05-20 08:48:55. Record interval: 0. Symbol: CLM6-NYMEX | 2016-05-20 10:37:16 HD Request # 27 | Decompressing data. | 2016-05-20 10:37:16 HD Request # 27 | Receiving Intraday data for CLM6-NYMEX starting at 2016-05-20 08:48:55 | 2016-05-20 10:37:16 HD Request # 27 | Timestamp of first Intraday data file record written: 2016-05-20 08:48:55 | 2016-05-20 10:37:16 Socket (111) | Shutdown and closed. | 2016-05-20 10:37:16 The network socket for historical data has been closed. | 2016-05-20 10:37:16 HD Request # 27 | Received 196 records from 2016-05-20 08:48:55 to 2016-05-20 10:11:42 (82.8 minutes) and wrote 194 records for CLM6-NYMEX | 2016-05-20 10:37:16 HD Request # 27 | Intraday download COMPLETE for CLM6-NYMEX. Completion time: 0s. Unique request ID: 26 | 2016-05-20 10:37:16 Removed historical data download ID 26 | 2016-05-20 10:37:16 Real-time Intraday chart data file updates started for CLM6-NYMEX | 2016-05-20 10:37:16 Opened cached Intraday file: C:\SierraChart\Data\CLM6-NYMEX.scid | 2016-05-20 10:37:16 Intraday chart data file opened for CLM6-NYMEX | 2016-05-20 10:37:16 |
| [2016-05-20 17:49:44] |
The reason for the problem is very apparent. Requesting market depth updates for: CLM6-NYMEX if supported. | 2016-05-20 10:36:58 Requesting market depth updates for: ESM6-CME if supported. | 2016-05-20 10:36:58 Requesting market depth updates for: NKDM6-CME if supported. | 2016-05-20 10:36:58 Requesting market depth updates for: ZSN6-CBOT if supported. | 2016-05-20 10:36:58 Rithmic Trading | Message from server: Server Alert: mrv error : 13. Result text: "permission denied" | 2016-05-20 10:36:58 Rithmic Trading | Message from server: Server Alert: get_order_book error : 13. Result text: "permission denied" | 2016-05-20 10:36:58 Your Rithmic account is not authorized for market depth data. Contact your broker about this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
