Date/Time: Wed, 28 Oct 2026 22:11:45 +0000
Can't get historical data for AMP/CQG on Version 1400
View Count: 938
[2016-04-25 12:30:50]
User40520 - Posts: 62
Getting data ok but no historical backfill for F.US.MJNKM16 and F.US.ENQM16 and anything else I look at. Started using the feed on Friday and that's as far as my charts can go back to so larger time frames are pretty empty.
[2016-04-25 13:48:40]
SC Developer - David - Posts: 662
Follow the instructions here to re-download the missing data:
[2016-04-25 16:27:39]
The solution is you need to update Sierra Chart to the current version following the instructions here:
https://www.sierrachart.com/index.php?page=doc/download.php#FastUpdate
You are running an older version.
Once that is done, then follow the instructions here:
