Date/Time: Tue, 07 May 2024 02:20:30 +0000
Detach/Attach Chartbook
View Count: 1369
[2016-04-22 16:45:45] |
User985778 - Posts: 16 |
Hi All, I was looking for the function to attach/detach a chartbook, like it is possible for a window.. I guess it is not possible? If it is not possible this would be a nice feature for a future release.. Thanks a lot for your feedback! |
[2016-04-22 18:05:23] |
This is not possible but you can run a new instance of Sierra Chart to see 2 Chartbooks at a time: https://www.sierrachart.com/index.php?page=doc/doc_DTCServer.php#UsingDTCServerForDataAndTradingInAnotherSCInstance This is not planned for a future release. It cannot be supported. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-04-23 10:44:01] |
Ok I understand, thanks a lot! And is it possible to use the same datafeed for those instances? |
[2016-04-23 10:48:33] |
Yes this happens by default. There is nothing special to do. The data feed is being shared and you can also perform trading in the sub instance if connected to a trading service of the main instance. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-04-25 12:58:50] |
Okay thats great! Thanks a lot for your help!
[2019-02-04 19:23:15] |
User132871 - Posts: 14 |
any update on this? I would like to put different markets on different monitors.
[2019-02-04 19:37:36] |
Any update on what? To do what you want, refer to: Detaching and Attaching Chart Windows Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-02-13 14:05:35] |
Is it possible to have 2 chartbooks open? I'm looking to put charts on different monitors so I can look at different markets at once. Currently, when I detach a chart from the chartbook whenever I select a different market the chart goes away. Please advise.
[2019-02-13 21:06:03] |
They cannot be both visible at the same time. But you can use multiple instances of Sierra Chart as a way to accomplish this. Refer to: Using DTC Server for Data and Trading in Another Sierra Chart Instance Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
