Date/Time: Mon, 06 May 2024 20:15:24 +0000
Chart value window
View Count: 1710
[2013-07-08 06:37:59] |
Yetlee - Posts: 12 |
If I scrowl the cursor over a chart window the values in the chart value window suddenly doesnt change anymore. How can I let the chart value window values synchronize dynamically with the scrolling of a undelying chart?
[2013-07-08 07:53:06] |
Make sure you use Window >> Tool Values Window. The Chart Values window will only show the data for the last displayed bar. Not the bar being pointed to with your Pointer. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-07-18 05:27:53] |
How can I see all the data the pointer is is pointed to?
Date Time Of Last Edit: 2013-07-18 05:28:32
[2013-07-18 07:30:40] |
All of the chart data will be shown in the Tool Values Window unless it has been hidden. Refer to: http://www.sierrachart.com/index.php?l=doc/helpdetails67.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-07-18 07:30:51
