Date/Time: Mon, 06 May 2024 17:25:24 +0000
[User Discussion] - Range Bar Alert Formula Needed???
View Count: 1863
[2013-07-07 22:56:34] |
User20200 - Posts: 38 |
Hello Guys, I use Range Bars and want an Email Alert Formula when a Price BAR CLOSES the other way! (Range Bars only close up (High) or down (Low)... Example: You have Price Bars going UP (Long) say 4 in a row, then the 5th Price Bar Closes Down (Short)... I only want an alert on that bar that closes the opposite way, so I am Alerted that the direction has changed. Thank you, Team One |
[2013-07-08 15:21:41] |
Sawtooth - Posts: 3993 |
Try this: =OR(AND(C[-4]=L[-4],C[-3]=L[-3],C[-2]=L[-2],C[-1]=L[-1],C=H),AND(C[-4]=H[-4],C[-3]=H[-3],C[-2]=H[-2],C[-1]=H[-1],C=L)) |
[2013-07-08 16:47:44] |
Not working properly... If there is only 1 Price Bar and it flips or reverses the other way, I want to be alerted! Need an alert for every Price Bar that closes opposite of the previous Price Bar... Thank you, Team One |
[2013-07-08 16:56:24] |
Sierra Chart - Max - Posts: 5605 |
Try the following formula: =OR(AND(C[-1]=L[-1],C=H),AND(C[-1]=H[-1],C=L)) Sierra Chart Support Date Time Of Last Edit: 2013-07-08 16:57:15
