Date/Time: Mon, 29 Apr 2024 11:28:01 +0000
Indicator Settings
View Count: 1520
[2013-07-07 22:12:56] |
User23815 - Posts: 209 |
I have two indicator questions. If you prefer them in separate posts please let me know. For Automatic Trendlines, my charts are only drawing the current lines, so I am not able to review with the trendlines drawn. Is there a way to have prior Automatic Trendlines print? For Volume Value Area Lines, when I add the study it compresses the chart so that all 3 lines are visible, making the candles unreadable. How do I set it to place the lines but not change the visibility area on the chart? Thanks |
[2013-07-07 22:25:26] |
1. No. This is not supported with the Automatic Trendlines study. 2. Set the Scale Range for the Volume Value Area Lines study to "Same As Region". Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
