Date/Time: Sat, 04 May 2024 16:16:35 +0000
Date Marker tool
View Count: 911
[2016-04-13 00:10:07] |
Crtfyd - Posts: 277 |
vs 1379 I've noticed that the "Date marker tool" doesn't work (above) my subgraph line (so, pointing down). In this case its the "Cumulative Sum of Study" (Also "Ave True Range" subgraph line), as it normally does in the main graph. To further explain. The "Date Marker Tool" normally (In the Main graph) when ABOVE a bar/line, will switch to pointing DOWN, and when BELOW a bar/line, will point UP. It will only Point UP when below a bar/line in a subgraph,(at least the two I listed above),but when the curser is ABOVE the bar/graph, nothing appears. Date Time Of Last Edit: 2016-04-13 00:11:21
[2016-04-13 20:07:59] |
We are working on this.
[2016-04-13 22:55:03] |
Al SC Developer - Posts: 434 |
This is addressed in the next version.
[2016-06-02 01:40:22] |
User50629 - Posts: 10 |
Hi, Could you correct date marker tool from 5/31/16 to 6/1/16. Thank You |
[2016-06-02 01:41:51] |
We do not understand what you are trying to say. This does not make sense and is nothing that we would have the ability to correct. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-07-23 18:33:30] |
User676363 - Posts: 62 |
Hello Support, I was looking at how to mark some dates on some charts and my Date Marker lets me select Date & Time, Date, and Time. [Point 1] The person above seems to have a situation with mm/dd/yy and dd/mm/yy. I guess it might be nice to know where we can format the dates. For me, which I like, I have this: On a daily Chart: Date & Time = 2017-03-17 [Note it doesn't show time by default on Daily, which is fine, I think] Date = 2017-03-17 Time = 2017-03-17 00:00 On a 15 min chart: 2020-07-20 02:15 And I can turn on both or show just time or just date. So that's great. [Point 2] However, I can't show day of week, for example Mon or Monday. I really like how the crosshair tool shows the day of the week on this platform. But if I want to print the charts, I have to add it by hand or use an editor like miro.com to annotate the drawings before generating PDFs. Any suggestions? |
