Date/Time: Wed, 28 Oct 2026 20:36:43 +0000
draw market profile not enabled
View Count: 1022
[2016-04-12 20:28:10]
User402693 - Posts: 2
Tools has an option for drawing market profiles but it is not highlighted and I cannot use it. What needs to be done to enable this item
[2016-04-12 21:15:46]
This is part of Sierra Chart service package 5. So you will need to have your service package changed to 5.
We do not provide support for your particular question for users who have accounts provided by a Sierra Chart reseller or affiliate. You will need to contact the reseller or affiliate for help with this particular question.
If you want to rely upon Sierra Chart support, we require that you have your own separate Sierra Chart account, which you may already have. If you want to use Sierra Chart, you will need to pay for usage time on that account.
If you do not already have your own direct Sierra Chart account, simply follow through the step by step instructions here:
http://www.sierrachart.com/index.php?l=doc/doc_DirectAccount.html
To log into Sierra Chart with your own account if you are not using that one already, then follow these instructions:
http://www.sierrachart.com/index.php?page=doc/LoginInstructions.php#DifferentAccountName
