Date/Time: Thu, 02 May 2024 09:13:10 +0000
days back in chart
View Count: 1319
[2013-07-07 00:15:18] |
User28682 - Posts: 233 |
In "chart settings" you can see at the top it says 6-25-2012 as the start date. I want to go back further than this. No matter how many days backs I put in, or what manual start date I put in, it only starts at 6-25-2012. How can I go back further? Tom Date Time Of Last Edit: 2013-07-07 00:15:49
CL_days_back.png / V - Attached On 2013-07-07 00:13:01 UTC - Size: 64.44 KB - 474 views |
[2013-07-07 03:47:05] |
Refer to help topic 42.1 here: http://www.sierrachart.com/index.php?l=doc/helpdetails42.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-07-07 04:18:31] |
I guess I am missing something. I have already done what you are telling me here. I am using a continuous futures contract, have tried to load more days back, but it keeps stopping at 6-25-2012, the beginning date in the Settings > Date Range in File. I use DTN/IQ, do you know if that is as far back as I can go with them? Thanks |
[2013-07-07 04:58:37] |
Did you follow the step where it says to go to Edit >>Delete All Data and Download. Please go through each step again. You must have missed a step. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-07-07 04:59:08
