Date/Time: Wed, 28 Oct 2026 20:37:06 +0000
Sierra chart and TWS (IB) via API
View Count: 1048
| [2016-04-12 17:11:55] |
| User850017 - Posts: 41 |
Hello there, I am trading forex (EUR.USD). I did connection between Sierra and TWS via API. Everything is going right. I used dom for order. ETF markets are view in TWS like limit order but FX order no. Where is a problem. What should I do? IB support told that problem is sierra side. Thank a lot about help |
| [2016-04-12 17:34:06] |
Most likely you are not using the correct symbols. Refer to this section here: Interactive Brokers Symbols: Forex Symbols For Trading Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
