Date/Time: Wed, 28 Oct 2026 20:36:46 +0000
Please allow me to try cqg service
View Count: 1328
| [2016-04-11 07:19:52] |
| User942115 - Posts: 5 |
Hello Your system has found a very old test of your platform Please give me the possibility to try your platform with CQG/AMP Thank You |
| [2016-04-11 08:28:20] |
Your account has been activated and/or reset. A restart is necessary if Sierra Chart is already running. Exit the Sierra Chart charting and trading software by selecting "File >> Exit". Open Sierra Chart through the icon on your desktop or through the desktop Start menu. After your Sierra Chart usage time ends, you need to pay for additional usage time through "Help >> Add Usage Credit". Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-04-12 16:36:08] |
Thank You I am experimenting some big issue with the CQG data feed today The connection at the server is frequently lost and when after some tentatives of reconnecting, when the status of SC is green the feed is almost dead. Only few sporadic data are received Just now, I have no data with the status green of SC |
| [2016-04-12 16:56:55] |
Here's the message log Software version: 1392 | 2016-04-12 16:47:46 Uses New Spreadsheets | 2016-04-12 16:47:46 Usage end date: 2016-04-25 | 2016-04-12 16:47:46 Enabled for: Advanced Features. | 2016-04-12 16:47:46 Enabled for: Advanced Features 2. | 2016-04-12 16:47:46 Enabled for: Sierra Chart Historical Data Service. | 2016-04-12 16:47:46 Allow Support for Sierra Chart Data Feeds is enabled. | 2016-04-12 16:47:46 Current selected Data/Trading service: CQG FIX Trading | 2016-04-12 16:47:46 Chart Update Interval: 10 | 2016-04-12 16:47:46 Time Zone: +00:00:00 (UTC+00) | 2016-04-12 16:47:46 2016-04-12 18:47:49 Local computer time | 2016-04-12 16:47:46 2016-04-12 16:47:49 Local computer time in UTC | 2016-04-12 16:47:46 2016-04-12 16:47:49 Local computer time in SC Time Zone | 2016-04-12 16:47:46 2016-04-12 16:47:49 Server time in UTC | 2016-04-12 16:47:46 Local computer UTC time and Server UTC time difference: 0 seconds. | 2016-04-12 16:47:46 Program path: C:\SierraChartCQG\ | 2016-04-12 16:47:46 Data Files path: C:\SierraChartCQG\Data\ | 2016-04-12 16:47:46 OS Version Number: 6.1 | 2016-04-12 16:47:46 Locale Setting: C | 2016-04-12 16:47:46 Checking for new symbol settings for cqg | 2016-04-12 16:47:46 HTTPS connection to www.sierrachart.com:443 (0) | Resolved address sierrachart.com to IP 5.9.8.236. | 2016-04-12 16:47:46 HTTPS connection to www.sierrachart.com:443 (3) | Connected. | 2016-04-12 16:47:46 HTTPS connection to www.sierrachart.com:443 (3) | Starting TLS 1.2 connection. | 2016-04-12 16:47:46 HTTPS connection to www.sierrachart.com:443 (3) | SSL connection established. | 2016-04-12 16:47:46 Symbol settings are up-to-date for cqg | 2016-04-12 16:47:46 CQG FIX: Not connecting to trading server because Username is not specified. | 2016-04-12 16:47:54 CQG FIX Trading | Connecting to market data server demoapi.cqg.com | 2016-04-12 16:47:54 CQG WebAPI | Connecting to websocket server. | 2016-04-12 16:47:54 CQG WebAPI websocket (0) | Resolved address demoapi.cqg.com to IP 208.48.16.32. | 2016-04-12 16:47:55 HTTPS connection to www.sierrachart.com:443 (3) | SSL connection closed by remote side. | 2016-04-12 16:47:55 HTTPS connection to www.sierrachart.com:443 (3) | Connection gracefully closed by remote side. | 2016-04-12 16:47:55 HTTPS connection to www.sierrachart.com:443 (3) | SSL object has been freed. SSL state is now disconnected. | 2016-04-12 16:47:55 HTTPS connection to www.sierrachart.com:443 (3) | Shutdown and closed. | 2016-04-12 16:47:55 CQG WebAPI websocket (4) | Connected. | 2016-04-12 16:47:58 CQG WebAPI websocket (4) | Starting SSL 3/2 connection. | 2016-04-12 16:47:58 CQG WebAPI websocket (4) | SSL connection established. | 2016-04-12 16:47:59 CQG WebAPI | Opening websocket. | 2016-04-12 16:47:59 CQG WebAPI | Sending websocket handshake. | 2016-04-12 16:47:59 CQG WebAPI | Received websocket handshake acknowledgment. | 2016-04-12 16:47:59 CQG WebAPI | Web socket state is now open. | 2016-04-12 16:47:59 CQG FIX Trading | Websocket connected. | 2016-04-12 16:47:59 CQG FIX Trading | Sending market data logon message. | 2016-04-12 16:47:59 CQG FIX Trading | Logon successful. Session Token = 8CNmdpO9M2XqSXMM+HMuNtQQWNxTrLil9TyGue+Cuuo | 2016-04-12 16:48:00 CQG FIX Trading | Connected to data and trading server. | 2016-04-12 16:48:00 CQG FIX Trading | Using primary service for historical data for ESM6 | 2016-04-12 16:48:07 CQG FIX Trading | Using primary service for historical data for FESXM6 | 2016-04-12 16:48:07 FESXM6 1 Min #6 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChartCQG\Data\FESXM6.scid | 2016-04-12 16:48:07 CQG FIX Trading | Starting real-time market data updates for: ESM6. ID: 1 | 2016-04-12 16:48:07 CQG FIX Trading | Sending symbol resolution request for ESM6. ID: 221756 | 2016-04-12 16:48:07 CQG FIX Trading | Using primary service for historical data for ESM6 | 2016-04-12 16:48:07 Intraday data recording state for symbol ESM6 is set to download 'Pending'. | 2016-04-12 16:48:07 Delaying start of download for ESM6 | 2016-04-12 16:48:07 CQG FIX Trading | Starting real-time market data updates for: F.US.EPM16. ID: 2 | 2016-04-12 16:48:08 CQG FIX Trading | Sending symbol resolution request for F.US.EPM16. ID: 221757 | 2016-04-12 16:48:08 Intraday data recording state for symbol F.US.EPM16 is set to download 'Pending'. | 2016-04-12 16:48:08 Delaying start of download for F.US.EPM16 | 2016-04-12 16:48:08 CQG FIX Trading | Starting real-time market data updates for: F.US.DSXM16. ID: 3 | 2016-04-12 16:48:08 CQG FIX Trading | Sending symbol resolution request for F.US.DSXM16. ID: 221758 | 2016-04-12 16:48:08 Intraday data recording state for symbol F.US.DSXM16 is set to download 'Pending'. | 2016-04-12 16:48:08 CQG FIX Trading | Starting real-time market data updates for: FESXM6. ID: 4 | 2016-04-12 16:48:08 CQG FIX Trading | Sending symbol resolution request for FESXM6. ID: 221759 | 2016-04-12 16:48:08 CQG FIX Trading | Using primary service for historical data for FESXM6 | 2016-04-12 16:48:08 Intraday data recording state for symbol FESXM6 is set to download 'Pending'. | 2016-04-12 16:48:08 Chart #4 has tagged chart #3 for full recalculation. Chartbook: DOMChartbookCQG.cht | 2016-04-12 16:48:08 Chart #4 has tagged chart #5 for full recalculation. Chartbook: DOMChartbookCQG.cht | 2016-04-12 16:48:08 Chart #4 has tagged chart #3 for full recalculation. Chartbook: DOMChartbookCQG.cht | 2016-04-12 16:48:08 Chart #4 has tagged chart #5 for full recalculation. Chartbook: DOMChartbookCQG.cht | 2016-04-12 16:48:08 F.US.EPM16 #3 | Performing a full recalculation because it has been tagged. Chartbook: DOMChartbookCQG.cht | 2016-04-12 16:48:08 F.US.DSXM16 #5 | Performing a full recalculation because it has been tagged. Chartbook: DOMChartbookCQG.cht | 2016-04-12 16:48:08 Symbol Error - ESM6 is unknown, unavailable, or improperly formatted. Exact match not found for symbol ESM6 | 2016-04-12 16:48:09 CQG FIX Trading | Received symbol resolution report for symbol F.US.EPM16. Request ID: 221757. Contract ID: 2. | 2016-04-12 16:48:09 CQG FIX Trading | Requesting market data for F.US.EPM16 | 2016-04-12 16:48:09 CQG FIX Trading | Received symbol resolution report for symbol F.US.DSXM16. Request ID: 221758. Contract ID: 3. | 2016-04-12 16:48:09 CQG FIX Trading | Requesting market data for F.US.DSXM16 | 2016-04-12 16:48:09 Symbol Error - FESXM6 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2016-04-12 16:48:09 Requesting market depth updates for: ESM6 if supported. | 2016-04-12 16:48:09 Requesting market depth updates for: F.US.DSXM16 if supported. | 2016-04-12 16:48:09 CQG FIX Trading | Requesting market data including full depth for F.US.DSXM16 | 2016-04-12 16:48:09 Requesting market depth updates for: F.US.EPM16 if supported. | 2016-04-12 16:48:09 CQG FIX Trading | Requesting market data including full depth for F.US.EPM16 | 2016-04-12 16:48:09 HD Request # 2 | Downloading Intraday chart data for ESM6 to the file ESM6.scid. Service: cqg | 2016-04-12 16:48:10 HD Request # 2 | Download start Date-Time: 2015-10-09 16:48:10.000 | 2016-04-12 16:48:10 HD Request # 2 | Error downloading historical Intraday data for ESM6. The symbol is unknown to the server. | 2016-04-12 16:48:10 HD Request # 2 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESM6 | 2016-04-12 16:48:10 HD Request # 2 | Intraday download COMPLETE for ESM6. Completion time: 0s. Unique request ID: 1 | 2016-04-12 16:48:10 Removed historical data download ID 1 | 2016-04-12 16:48:10 Real-time Intraday chart data file updates started for ESM6 | 2016-04-12 16:48:10 Opened cached Intraday file: C:\SierraChartCQG\Data\ESM6.scid | 2016-04-12 16:48:10 Intraday chart data file opened for ESM6 | 2016-04-12 16:48:10 HD Request # 3 | Downloading Intraday chart data for FESXM6 to the file FESXM6.scid. Service: cqg | 2016-04-12 16:48:10 HD Request # 3 | Download start Date-Time: 2015-10-09 16:48:10.000 | 2016-04-12 16:48:10 HD Request # 3 | Error downloading historical Intraday data for FESXM6. The symbol is unknown to the server. | 2016-04-12 16:48:10 HD Request # 3 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for FESXM6 | 2016-04-12 16:48:10 HD Request # 3 | Intraday download COMPLETE for FESXM6. Completion time: 0s. Unique request ID: 4 | 2016-04-12 16:48:10 Removed historical data download ID 4 | 2016-04-12 16:48:10 Real-time Intraday chart data file updates started for FESXM6 | 2016-04-12 16:48:10 Opened cached Intraday file: C:\SierraChartCQG\Data\FESXM6.scid | 2016-04-12 16:48:10 Intraday chart data file opened for FESXM6 | 2016-04-12 16:48:10 Delaying start of download for F.US.EPM16 | 2016-04-12 16:48:10 HD Request # 4 | Downloading Intraday chart data for F.US.EPM16 to the file F.US.EPM16.scid. Service: cqg | 2016-04-12 16:48:13 HD Request # 4 | Download start Date-Time: 2016-04-12 16:37:01.000 | 2016-04-12 16:48:13 HD Request # 4 | Using server: ds3.sierracharts.com port 10149 | 2016-04-12 16:48:13 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164. | 2016-04-12 16:48:13 Socket (5) | Connected. | 2016-04-12 16:48:14 HD Request # 4 | Sending historical data logon request message. | 2016-04-12 16:48:14 HD Request # 4 | Requesting Intraday data. Start Date-Time: 2016-04-12 16:37:01. Record interval: 1. Symbol: F.US.EPM16 | 2016-04-12 16:48:15 HD Request # 4 | Decompressing data. | 2016-04-12 16:48:15 HD Request # 4 | Receiving Intraday data for F.US.EPM16 starting at 2016-04-12 16:37:01 | 2016-04-12 16:48:15 HD Request # 4 | Timestamp of first Intraday data file record written: 2016-04-12 16:37:01 | 2016-04-12 16:48:15 Socket (5) | Shutdown and closed. | 2016-04-12 16:48:17 The network socket for historical data has been closed. | 2016-04-12 16:48:17 HD Request # 4 | Received 463 records from 2016-04-12 16:37:01 to 2016-04-12 16:48:12 (11.2 minutes) and wrote 463 records for F.US.EPM16 | 2016-04-12 16:48:17 Added 1 Time and Sales records to Intraday data file for F.US.EPM16 after download. | 2016-04-12 16:48:17 HD Request # 4 | Intraday download COMPLETE for F.US.EPM16. Completion time: 4s. Unique request ID: 2 | 2016-04-12 16:48:17 Removed historical data download ID 2 | 2016-04-12 16:48:17 Real-time Intraday chart data file updates started for F.US.EPM16 | 2016-04-12 16:48:17 Opened cached Intraday file: C:\SierraChartCQG\Data\F.US.EPM16.scid | 2016-04-12 16:48:17 Intraday chart data file opened for F.US.EPM16 | 2016-04-12 16:48:17 HD Request # 5 | Downloading Intraday chart data for F.US.DSXM16 to the file F.US.DSXM16.scid. Service: cqg | 2016-04-12 16:48:17 HD Request # 5 | Download start Date-Time: 2016-04-12 16:37:03.000 | 2016-04-12 16:48:17 HD Request # 5 | Using server: ds5.sierracharts.com port 10149 | 2016-04-12 16:48:17 Chart #4 has tagged chart #3 for full recalculation. Chartbook: DOMChartbookCQG.cht | 2016-04-12 16:48:17 Chart #4 has tagged chart #5 for full recalculation. Chartbook: DOMChartbookCQG.cht | 2016-04-12 16:48:17 F.US.DSXM16 #5 | Performing a full recalculation because it has been tagged. Chartbook: DOMChartbookCQG.cht | 2016-04-12 16:48:17 F.US.EPM16 #3 | Performing a full recalculation because it has been tagged. Chartbook: DOMChartbookCQG.cht | 2016-04-12 16:48:17 Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106. | 2016-04-12 16:48:17 Socket (6) | Connected. | 2016-04-12 16:48:17 HD Request # 5 | Sending historical data logon request message. | 2016-04-12 16:48:17 HD Request # 5 | Requesting Intraday data. Start Date-Time: 2016-04-12 16:37:03. Record interval: 1. Symbol: F.US.DSXM16 | 2016-04-12 16:48:17 HD Request # 5 | Decompressing data. | 2016-04-12 16:48:18 HD Request # 5 | Receiving Intraday data for F.US.DSXM16 starting at 2016-04-12 16:37:03 | 2016-04-12 16:48:18 HD Request # 5 | Timestamp of first Intraday data file record written: 2016-04-12 16:37:03 | 2016-04-12 16:48:18 Socket (6) | Shutdown and closed. | 2016-04-12 16:48:18 The network socket for historical data has been closed. | 2016-04-12 16:48:18 HD Request # 5 | Received 127 records from 2016-04-12 16:37:03 to 2016-04-12 16:48:12 (11.1 minutes) and wrote 127 records for F.US.DSXM16 | 2016-04-12 16:48:18 HD Request # 5 | Intraday download COMPLETE for F.US.DSXM16. Completion time: 1s. Unique request ID: 3 | 2016-04-12 16:48:18 Removed historical data download ID 3 | 2016-04-12 16:48:18 Real-time Intraday chart data file updates started for F.US.DSXM16 | 2016-04-12 16:48:18 Opened cached Intraday file: C:\SierraChartCQG\Data\F.US.DSXM16.scid | 2016-04-12 16:48:18 Intraday chart data file opened for F.US.DSXM16 | 2016-04-12 16:48:18 CQG WebAPI websocket (4) | Closed. Windows error code 10053: Connessione interrotta dal software del computer host. | 2016-04-12 16:49:21 CQG WebAPI websocket (4) | SSL shutdown indicates not able to send 'close notify'. | 2016-04-12 16:49:21 CQG WebAPI websocket (4) | SSL has been shut down. | 2016-04-12 16:49:21 CQG WebAPI websocket (4) | SSL object has been freed. SSL state is now disconnected. | 2016-04-12 16:49:21 CQG WebAPI websocket (4) | Shutdown and closed. | 2016-04-12 16:49:21 CQG WebAPI | Network socket for websocket has been closed by remote side. | 2016-04-12 16:49:21 CQG FIX Trading | Websocket closed. | 2016-04-12 16:49:21 Connection to the external service has been lost. | 2016-04-12 16:49:21 CQG FIX Trading | Disconnected. | 2016-04-12 16:49:21 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-04-12 16:49:21 CQG FIX: Not connecting to trading server because Username is not specified. | 2016-04-12 16:49:24 CQG FIX Trading | Connecting to market data server demoapi.cqg.com | 2016-04-12 16:49:24 CQG WebAPI | Connecting to websocket server. | 2016-04-12 16:49:24 CQG WebAPI websocket (0) | Resolved address demoapi.cqg.com to IP 208.48.16.32. | 2016-04-12 16:49:24 CQG WebAPI websocket (7) | Connected. | 2016-04-12 16:49:24 CQG WebAPI websocket (7) | Starting SSL 3/2 connection. | 2016-04-12 16:49:24 CQG WebAPI websocket (7) | SSL connection established. | 2016-04-12 16:49:25 CQG WebAPI | Opening websocket. | 2016-04-12 16:49:25 CQG WebAPI | Sending websocket handshake. | 2016-04-12 16:49:25 CQG WebAPI | Received websocket handshake acknowledgment. | 2016-04-12 16:49:25 CQG WebAPI | Web socket state is now open. | 2016-04-12 16:49:25 CQG FIX Trading | Websocket connected. | 2016-04-12 16:49:25 CQG FIX Trading | Sending market data logon message. | 2016-04-12 16:49:25 CQG FIX Trading | Logon successful. Session Token = eFQJfTBqZ7owBi3leWS7KyoVS+M7hZ0bd/Ea7/e/Sjw | 2016-04-12 16:49:26 CQG FIX Trading | Connected to data and trading server. | 2016-04-12 16:49:26 CQG FIX Trading | Starting real-time market data updates for: F.US.EPM16. ID: 1 | 2016-04-12 16:49:26 CQG FIX Trading | Sending symbol resolution request for F.US.EPM16. ID: 221760 | 2016-04-12 16:49:26 Intraday data recording state for symbol F.US.EPM16 is set to download 'Pending'. | 2016-04-12 16:49:26 Delaying start of download for F.US.EPM16 | 2016-04-12 16:49:26 CQG FIX Trading | Starting real-time market data updates for: F.US.DSXM16. ID: 2 | 2016-04-12 16:49:26 CQG FIX Trading | Sending symbol resolution request for F.US.DSXM16. ID: 221761 | 2016-04-12 16:49:26 Intraday data recording state for symbol F.US.DSXM16 is set to download 'Pending'. | 2016-04-12 16:49:26 CQG FIX Trading | Starting real-time market data updates for: FESXM6. ID: 3 | 2016-04-12 16:49:26 CQG FIX Trading | Sending symbol resolution request for FESXM6. ID: 221762 | 2016-04-12 16:49:26 CQG FIX Trading | Using primary service for historical data for FESXM6 | 2016-04-12 16:49:26 Intraday data recording state for symbol FESXM6 is set to download 'Pending'. | 2016-04-12 16:49:26 Delaying start of download for FESXM6 | 2016-04-12 16:49:26 CQG FIX Trading | Starting real-time market data updates for: ESM6. ID: 4 | 2016-04-12 16:49:26 CQG FIX Trading | Sending symbol resolution request for ESM6. ID: 221763 | 2016-04-12 16:49:26 CQG FIX Trading | Using primary service for historical data for ESM6 | 2016-04-12 16:49:26 Intraday data recording state for symbol ESM6 is set to download 'Pending'. | 2016-04-12 16:49:26 CQG FIX Trading | Received symbol resolution report for symbol F.US.EPM16. Request ID: 221760. Contract ID: 1. | 2016-04-12 16:49:28 CQG FIX Trading | Requesting market data including full depth for F.US.EPM16 | 2016-04-12 16:49:28 CQG FIX Trading | Received symbol resolution report for symbol F.US.DSXM16. Request ID: 221761. Contract ID: 2. | 2016-04-12 16:49:28 CQG FIX Trading | Requesting market data including full depth for F.US.DSXM16 | 2016-04-12 16:49:28 Symbol Error - ESM6 is unknown, unavailable, or improperly formatted. Exact match not found for symbol ESM6 | 2016-04-12 16:49:28 Symbol Error - FESXM6 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2016-04-12 16:49:28 HD Request # 6 | Downloading Intraday chart data for FESXM6 to the file FESXM6.scid. Service: cqg | 2016-04-12 16:49:29 HD Request # 6 | Download start Date-Time: 2015-10-09 16:49:29.000 | 2016-04-12 16:49:29 HD Request # 6 | Error downloading historical Intraday data for FESXM6. The symbol is unknown to the server. | 2016-04-12 16:49:29 HD Request # 6 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for FESXM6 | 2016-04-12 16:49:29 HD Request # 6 | Intraday download COMPLETE for FESXM6. Completion time: 0s. Unique request ID: 7 | 2016-04-12 16:49:29 Removed historical data download ID 7 | 2016-04-12 16:49:29 Real-time Intraday chart data file updates started for FESXM6 | 2016-04-12 16:49:29 Opened cached Intraday file: C:\SierraChartCQG\Data\FESXM6.scid | 2016-04-12 16:49:29 Intraday chart data file opened for FESXM6 | 2016-04-12 16:49:29 HD Request # 7 | Downloading Intraday chart data for ESM6 to the file ESM6.scid. Service: cqg | 2016-04-12 16:49:29 HD Request # 7 | Download start Date-Time: 2015-10-09 16:49:29.000 | 2016-04-12 16:49:29 HD Request # 7 | Error downloading historical Intraday data for ESM6. The symbol is unknown to the server. | 2016-04-12 16:49:29 HD Request # 7 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESM6 | 2016-04-12 16:49:29 HD Request # 7 | Intraday download COMPLETE for ESM6. Completion time: 0s. Unique request ID: 8 | 2016-04-12 16:49:29 Removed historical data download ID 8 | 2016-04-12 16:49:29 Real-time Intraday chart data file updates started for ESM6 | 2016-04-12 16:49:29 Opened cached Intraday file: C:\SierraChartCQG\Data\ESM6.scid | 2016-04-12 16:49:29 Intraday chart data file opened for ESM6 | 2016-04-12 16:49:29 Delaying start of download for F.US.EPM16 | 2016-04-12 16:49:29 Requesting market depth updates for: ESM6 if supported. | 2016-04-12 16:49:31 Requesting market depth updates for: F.US.DSXM16 if supported. | 2016-04-12 16:49:31 CQG FIX Trading | Requesting market data including full depth for F.US.DSXM16 | 2016-04-12 16:49:31 Requesting market depth updates for: F.US.EPM16 if supported. | 2016-04-12 16:49:31 CQG FIX Trading | Requesting market data including full depth for F.US.EPM16 | 2016-04-12 16:49:31 HD Request # 8 | Downloading Intraday chart data for F.US.EPM16 to the file F.US.EPM16.scid. Service: cqg | 2016-04-12 16:49:31 HD Request # 8 | Download start Date-Time: 2016-04-12 16:48:21.000 | 2016-04-12 16:49:31 HD Request # 8 | Using server: ds4.sierracharts.com port 10149 | 2016-04-12 16:49:31 Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26. | 2016-04-12 16:49:31 Socket (8) | Connected. | 2016-04-12 16:49:31 HD Request # 8 | Sending historical data logon request message. | 2016-04-12 16:49:31 HD Request # 8 | Requesting Intraday data. Start Date-Time: 2016-04-12 16:48:21. Record interval: 1. Symbol: F.US.EPM16 | 2016-04-12 16:49:32 HD Request # 8 | Decompressing data. | 2016-04-12 16:49:33 HD Request # 8 | Receiving Intraday data for F.US.EPM16 starting at 2016-04-12 16:48:21 | 2016-04-12 16:49:33 HD Request # 8 | Timestamp of first Intraday data file record written: 2016-04-12 16:48:21 | 2016-04-12 16:49:33 Socket (8) | Shutdown and closed. | 2016-04-12 16:49:33 The network socket for historical data has been closed. | 2016-04-12 16:49:33 HD Request # 8 | Received 47 records from 2016-04-12 16:48:21 to 2016-04-12 16:49:30 (69.0 seconds) and wrote 47 records for F.US.EPM16 | 2016-04-12 16:49:33 HD Request # 8 | Intraday download COMPLETE for F.US.EPM16. Completion time: 2s. Unique request ID: 5 | 2016-04-12 16:49:33 Removed historical data download ID 5 | 2016-04-12 16:49:33 Real-time Intraday chart data file updates started for F.US.EPM16 | 2016-04-12 16:49:33 Opened cached Intraday file: C:\SierraChartCQG\Data\F.US.EPM16.scid | 2016-04-12 16:49:33 Intraday chart data file opened for F.US.EPM16 | 2016-04-12 16:49:33 HD Request # 9 | Downloading Intraday chart data for F.US.DSXM16 to the file F.US.DSXM16.scid. Service: cqg | 2016-04-12 16:49:33 HD Request # 9 | Download start Date-Time: 2016-04-12 16:48:12.000 | 2016-04-12 16:49:33 HD Request # 9 | Using server: ds3.sierracharts.com port 10149 | 2016-04-12 16:49:33 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164. | 2016-04-12 16:49:33 Chart #4 has tagged chart #3 for full recalculation. Chartbook: DOMChartbookCQG.cht | 2016-04-12 16:49:33 Chart #4 has tagged chart #5 for full recalculation. Chartbook: DOMChartbookCQG.cht | 2016-04-12 16:49:33 F.US.DSXM16 #5 | Performing a full recalculation because it has been tagged. Chartbook: DOMChartbookCQG.cht | 2016-04-12 16:49:33 F.US.EPM16 #3 | Performing a full recalculation because it has been tagged. Chartbook: DOMChartbookCQG.cht | 2016-04-12 16:49:33 Socket (9) | Connected. | 2016-04-12 16:49:36 HD Request # 9 | Sending historical data logon request message. | 2016-04-12 16:49:36 HD Request # 9 | Requesting Intraday data. Start Date-Time: 2016-04-12 16:48:12. Record interval: 1. Symbol: F.US.DSXM16 | 2016-04-12 16:49:36 HD Request # 9 | Decompressing data. | 2016-04-12 16:49:37 HD Request # 9 | Receiving Intraday data for F.US.DSXM16 starting at 2016-04-12 16:48:12 | 2016-04-12 16:49:37 HD Request # 9 | Timestamp of first Intraday data file record written: 2016-04-12 16:48:12 | 2016-04-12 16:49:37 Socket (9) | Shutdown and closed. | 2016-04-12 16:49:37 The network socket for historical data has been closed. | 2016-04-12 16:49:37 HD Request # 9 | Received 12 records from 2016-04-12 16:48:12 to 2016-04-12 16:49:33 (81.0 seconds) and wrote 12 records for F.US.DSXM16 | 2016-04-12 16:49:37 HD Request # 9 | Intraday download COMPLETE for F.US.DSXM16. Completion time: 3s. Unique request ID: 6 | 2016-04-12 16:49:37 Removed historical data download ID 6 | 2016-04-12 16:49:37 Real-time Intraday chart data file updates started for F.US.DSXM16 | 2016-04-12 16:49:37 Opened cached Intraday file: C:\SierraChartCQG\Data\F.US.DSXM16.scid | 2016-04-12 16:49:37 Intraday chart data file opened for F.US.DSXM16 | 2016-04-12 16:49:37 CQG WebAPI websocket (7) | Closed. Windows error code 10053: Connessione interrotta dal software del computer host. | 2016-04-12 16:51:06 CQG WebAPI websocket (7) | SSL shutdown indicates not able to send 'close notify'. | 2016-04-12 16:51:06 CQG WebAPI websocket (7) | SSL has been shut down. | 2016-04-12 16:51:06 CQG WebAPI websocket (7) | SSL object has been freed. SSL state is now disconnected. | 2016-04-12 16:51:06 CQG WebAPI websocket (7) | Shutdown and closed. | 2016-04-12 16:51:06 CQG WebAPI | Network socket for websocket has been closed by remote side. | 2016-04-12 16:51:06 CQG FIX Trading | Websocket closed. | 2016-04-12 16:51:06 Connection to the external service has been lost. | 2016-04-12 16:51:06 CQG FIX Trading | Disconnected. | 2016-04-12 16:51:06 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-04-12 16:51:06 CQG FIX: Not connecting to trading server because Username is not specified. | 2016-04-12 16:51:09 CQG FIX Trading | Connecting to market data server demoapi.cqg.com | 2016-04-12 16:51:09 CQG WebAPI | Connecting to websocket server. | 2016-04-12 16:51:09 CQG WebAPI websocket (0) | Resolved address demoapi.cqg.com to IP 208.48.16.32. | 2016-04-12 16:51:09 CQG WebAPI websocket (11) | Connected. | 2016-04-12 16:51:09 CQG WebAPI websocket (11) | Starting SSL 3/2 connection. | 2016-04-12 16:51:09 CQG WebAPI websocket (11) | SSL connection established. | 2016-04-12 16:51:11 CQG WebAPI | Opening websocket. | 2016-04-12 16:51:11 CQG WebAPI | Sending websocket handshake. | 2016-04-12 16:51:11 CQG WebAPI | Received websocket handshake acknowledgment. | 2016-04-12 16:51:11 CQG WebAPI | Web socket state is now open. | 2016-04-12 16:51:11 CQG FIX Trading | Websocket connected. | 2016-04-12 16:51:11 CQG FIX Trading | Sending market data logon message. | 2016-04-12 16:51:11 CQG FIX Trading | Logon successful. Session Token = 4ILRwzlxMLqc64PLy786F/c8tMtOYtsUOxPJhO8xeKM | 2016-04-12 16:51:11 CQG FIX Trading | Connected to data and trading server. | 2016-04-12 16:51:11 CQG FIX Trading | Starting real-time market data updates for: F.US.EPM16. ID: 1 | 2016-04-12 16:51:11 CQG FIX Trading | Sending symbol resolution request for F.US.EPM16. ID: 221764 | 2016-04-12 16:51:11 Intraday data recording state for symbol F.US.EPM16 is set to download 'Pending'. | 2016-04-12 16:51:11 Delaying start of download for F.US.EPM16 | 2016-04-12 16:51:11 CQG FIX Trading | Starting real-time market data updates for: F.US.DSXM16. ID: 2 | 2016-04-12 16:51:11 CQG FIX Trading | Sending symbol resolution request for F.US.DSXM16. ID: 221765 | 2016-04-12 16:51:11 Intraday data recording state for symbol F.US.DSXM16 is set to download 'Pending'. | 2016-04-12 16:51:11 CQG FIX Trading | Starting real-time market data updates for: FESXM6. ID: 3 | 2016-04-12 16:51:11 CQG FIX Trading | Sending symbol resolution request for FESXM6. ID: 221766 | 2016-04-12 16:51:11 CQG FIX Trading | Using primary service for historical data for FESXM6 | 2016-04-12 16:51:11 Intraday data recording state for symbol FESXM6 is set to download 'Pending'. | 2016-04-12 16:51:11 Delaying start of download for FESXM6 | 2016-04-12 16:51:11 CQG FIX Trading | Starting real-time market data updates for: ESM6. ID: 4 | 2016-04-12 16:51:11 CQG FIX Trading | Sending symbol resolution request for ESM6. ID: 221767 | 2016-04-12 16:51:11 CQG FIX Trading | Using primary service for historical data for ESM6 | 2016-04-12 16:51:11 Intraday data recording state for symbol ESM6 is set to download 'Pending'. | 2016-04-12 16:51:11 CQG FIX Trading | Received symbol resolution report for symbol F.US.EPM16. Request ID: 221764. Contract ID: 1. | 2016-04-12 16:51:12 CQG FIX Trading | Requesting market data including full depth for F.US.EPM16 | 2016-04-12 16:51:12 CQG FIX Trading | Received symbol resolution report for symbol F.US.DSXM16. Request ID: 221765. Contract ID: 2. | 2016-04-12 16:51:14 CQG FIX Trading | Requesting market data including full depth for F.US.DSXM16 | 2016-04-12 16:51:14 Symbol Error - ESM6 is unknown, unavailable, or improperly formatted. Exact match not found for symbol ESM6 | 2016-04-12 16:51:14 Symbol Error - FESXM6 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2016-04-12 16:51:14 Delaying start of download for F.US.EPM16 | 2016-04-12 16:51:14 HD Request # 10 | Downloading Intraday chart data for FESXM6 to the file FESXM6.scid. Service: cqg | 2016-04-12 16:51:14 HD Request # 10 | Download start Date-Time: 2015-10-09 16:51:14.000 | 2016-04-12 16:51:14 HD Request # 10 | Error downloading historical Intraday data for FESXM6. The symbol is unknown to the server. | 2016-04-12 16:51:14 HD Request # 10 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for FESXM6 | 2016-04-12 16:51:14 HD Request # 10 | Intraday download COMPLETE for FESXM6. Completion time: 0s. Unique request ID: 11 | 2016-04-12 16:51:14 Removed historical data download ID 11 | 2016-04-12 16:51:14 Real-time Intraday chart data file updates started for FESXM6 | 2016-04-12 16:51:14 Opened cached Intraday file: C:\SierraChartCQG\Data\FESXM6.scid | 2016-04-12 16:51:14 Intraday chart data file opened for FESXM6 | 2016-04-12 16:51:14 HD Request # 11 | Downloading Intraday chart data for ESM6 to the file ESM6.scid. Service: cqg | 2016-04-12 16:51:14 HD Request # 11 | Download start Date-Time: 2015-10-09 16:51:14.000 | 2016-04-12 16:51:14 HD Request # 11 | Error downloading historical Intraday data for ESM6. The symbol is unknown to the server. | 2016-04-12 16:51:14 HD Request # 11 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESM6 | 2016-04-12 16:51:14 HD Request # 11 | Intraday download COMPLETE for ESM6. Completion time: 0s. Unique request ID: 12 | 2016-04-12 16:51:14 Removed historical data download ID 12 | 2016-04-12 16:51:14 Real-time Intraday chart data file updates started for ESM6 | 2016-04-12 16:51:14 Opened cached Intraday file: C:\SierraChartCQG\Data\ESM6.scid | 2016-04-12 16:51:14 Intraday chart data file opened for ESM6 | 2016-04-12 16:51:14 Requesting market depth updates for: ESM6 if supported. | 2016-04-12 16:51:16 Requesting market depth updates for: F.US.DSXM16 if supported. | 2016-04-12 16:51:16 CQG FIX Trading | Requesting market data including full depth for F.US.DSXM16 | 2016-04-12 16:51:16 Requesting market depth updates for: F.US.EPM16 if supported. | 2016-04-12 16:51:16 CQG FIX Trading | Requesting market data including full depth for F.US.EPM16 | 2016-04-12 16:51:16 HD Request # 12 | Downloading Intraday chart data for F.US.EPM16 to the file F.US.EPM16.scid. Service: cqg | 2016-04-12 16:51:16 HD Request # 12 | Download start Date-Time: 2016-04-12 16:49:50.000 | 2016-04-12 16:51:16 HD Request # 12 | Using server: ds5.sierracharts.com port 10149 | 2016-04-12 16:51:16 Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106. | 2016-04-12 16:51:16 Socket (12) | Connected. | 2016-04-12 16:51:20 HD Request # 12 | Sending historical data logon request message. | 2016-04-12 16:51:20 HD Request # 12 | Requesting Intraday data. Start Date-Time: 2016-04-12 16:49:50. Record interval: 1. Symbol: F.US.EPM16 | 2016-04-12 16:51:23 HD Request # 12 | Decompressing data. | 2016-04-12 16:51:23 HD Request # 12 | Receiving Intraday data for F.US.EPM16 starting at 2016-04-12 16:49:50 | 2016-04-12 16:51:23 HD Request # 12 | Timestamp of first Intraday data file record written: 2016-04-12 16:49:50 | 2016-04-12 16:51:23 Socket (12) | Shutdown and closed. | 2016-04-12 16:51:23 The network socket for historical data has been closed. | 2016-04-12 16:51:23 HD Request # 12 | Received 49 records from 2016-04-12 16:49:50 to 2016-04-12 16:51:21 (91.0 seconds) and wrote 49 records for F.US.EPM16 | 2016-04-12 16:51:23 HD Request # 12 | Intraday download COMPLETE for F.US.EPM16. Completion time: 7s. Unique request ID: 9 | 2016-04-12 16:51:23 Removed historical data download ID 9 | 2016-04-12 16:51:23 Real-time Intraday chart data file updates started for F.US.EPM16 | 2016-04-12 16:51:23 Opened cached Intraday file: C:\SierraChartCQG\Data\F.US.EPM16.scid | 2016-04-12 16:51:23 Intraday chart data file opened for F.US.EPM16 | 2016-04-12 16:51:23 Delaying start of download for F.US.DSXM16 | 2016-04-12 16:51:23 Chart #4 has tagged chart #3 for full recalculation. Chartbook: DOMChartbookCQG.cht | 2016-04-12 16:51:23 Chart #4 has tagged chart #5 for full recalculation. Chartbook: DOMChartbookCQG.cht | 2016-04-12 16:51:23 F.US.DSXM16 #5 | Performing a full recalculation because it has been tagged. Chartbook: DOMChartbookCQG.cht | 2016-04-12 16:51:23 F.US.EPM16 #3 | Performing a full recalculation because it has been tagged. Chartbook: DOMChartbookCQG.cht | 2016-04-12 16:51:23 HD Request # 13 | Downloading Intraday chart data for F.US.DSXM16 to the file F.US.DSXM16.scid. Service: cqg | 2016-04-12 16:51:28 HD Request # 13 | Download start Date-Time: 2016-04-12 16:49:52.000 | 2016-04-12 16:51:28 HD Request # 13 | Using server: ds4.sierracharts.com port 10149 | 2016-04-12 16:51:28 Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26. | 2016-04-12 16:51:28 Socket (13) | Connected. | 2016-04-12 16:51:28 HD Request # 13 | Sending historical data logon request message. | 2016-04-12 16:51:28 HD Request # 13 | Requesting Intraday data. Start Date-Time: 2016-04-12 16:49:52. Record interval: 1. Symbol: F.US.DSXM16 | 2016-04-12 16:51:28 HD Request # 13 | Decompressing data. | 2016-04-12 16:51:29 HD Request # 13 | Receiving Intraday data for F.US.DSXM16 starting at 2016-04-12 16:49:52 | 2016-04-12 16:51:29 HD Request # 13 | Timestamp of first Intraday data file record written: 2016-04-12 16:49:52 | 2016-04-12 16:51:29 Socket (13) | Shutdown and closed. | 2016-04-12 16:51:29 The network socket for historical data has been closed. | 2016-04-12 16:51:29 HD Request # 13 | Received 7 records from 2016-04-12 16:49:52 to 2016-04-12 16:50:59 (67.0 seconds) and wrote 7 records for F.US.DSXM16 | 2016-04-12 16:51:29 HD Request # 13 | Intraday download COMPLETE for F.US.DSXM16. Completion time: 0s. Unique request ID: 10 | 2016-04-12 16:51:29 Removed historical data download ID 10 | 2016-04-12 16:51:29 Real-time Intraday chart data file updates started for F.US.DSXM16 | 2016-04-12 16:51:29 Opened cached Intraday file: C:\SierraChartCQG\Data\F.US.DSXM16.scid | 2016-04-12 16:51:29 Intraday chart data file opened for F.US.DSXM16 | 2016-04-12 16:51:29 CQG WebAPI websocket (11) | Closed. Windows error code 10053: Connessione interrotta dal software del computer host. | 2016-04-12 16:52:14 CQG WebAPI websocket (11) | SSL shutdown indicates not able to send 'close notify'. | 2016-04-12 16:52:14 CQG WebAPI websocket (11) | SSL has been shut down. | 2016-04-12 16:52:14 CQG WebAPI websocket (11) | SSL object has been freed. SSL state is now disconnected. | 2016-04-12 16:52:14 CQG WebAPI websocket (11) | Shutdown and closed. | 2016-04-12 16:52:14 CQG WebAPI | Network socket for websocket has been closed by remote side. | 2016-04-12 16:52:14 CQG FIX Trading | Websocket closed. | 2016-04-12 16:52:14 Connection to the external service has been lost. | 2016-04-12 16:52:14 CQG FIX Trading | Disconnected. | 2016-04-12 16:52:14 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-04-12 16:52:14 CQG FIX: Not connecting to trading server because Username is not specified. | 2016-04-12 16:52:17 CQG FIX Trading | Connecting to market data server demoapi.cqg.com | 2016-04-12 16:52:17 CQG WebAPI | Connecting to websocket server. | 2016-04-12 16:52:17 CQG WebAPI websocket (0) | Resolved address demoapi.cqg.com to IP 208.48.16.32. | 2016-04-12 16:52:17 CQG WebAPI websocket (15) | Connected. | 2016-04-12 16:52:17 CQG WebAPI websocket (15) | Starting SSL 3/2 connection. | 2016-04-12 16:52:17 CQG WebAPI websocket (15) | SSL connection established. | 2016-04-12 16:52:18 CQG WebAPI | Opening websocket. | 2016-04-12 16:52:18 CQG WebAPI | Sending websocket handshake. | 2016-04-12 16:52:18 CQG WebAPI | Received websocket handshake acknowledgment. | 2016-04-12 16:52:18 CQG WebAPI | Web socket state is now open. | 2016-04-12 16:52:18 CQG FIX Trading | Websocket connected. | 2016-04-12 16:52:18 CQG FIX Trading | Sending market data logon message. | 2016-04-12 16:52:18 CQG FIX Trading | Logon successful. Session Token = S8VCFo/8cM5xB+PpEjCF3pyoY3hvMsbSV3NT4kwZ8CY | 2016-04-12 16:52:19 CQG FIX Trading | Connected to data and trading server. | 2016-04-12 16:52:19 CQG FIX Trading | Starting real-time market data updates for: F.US.EPM16. ID: 1 | 2016-04-12 16:52:19 CQG FIX Trading | Sending symbol resolution request for F.US.EPM16. ID: 221768 | 2016-04-12 16:52:19 Intraday data recording state for symbol F.US.EPM16 is set to download 'Pending'. | 2016-04-12 16:52:19 Delaying start of download for F.US.EPM16 | 2016-04-12 16:52:19 CQG FIX Trading | Starting real-time market data updates for: FESXM6. ID: 2 | 2016-04-12 16:52:19 CQG FIX Trading | Sending symbol resolution request for FESXM6. ID: 221769 | 2016-04-12 16:52:19 CQG FIX Trading | Using primary service for historical data for FESXM6 | 2016-04-12 16:52:19 Intraday data recording state for symbol FESXM6 is set to download 'Pending'. | 2016-04-12 16:52:19 Delaying start of download for FESXM6 | 2016-04-12 16:52:19 CQG FIX Trading | Starting real-time market data updates for: ESM6. ID: 3 | 2016-04-12 16:52:19 CQG FIX Trading | Sending symbol resolution request for ESM6. ID: 221770 | 2016-04-12 16:52:19 CQG FIX Trading | Using primary service for historical data for ESM6 | 2016-04-12 16:52:19 Intraday data recording state for symbol ESM6 is set to download 'Pending'. | 2016-04-12 16:52:19 CQG FIX Trading | Starting real-time market data updates for: F.US.DSXM16. ID: 4 | 2016-04-12 16:52:19 CQG FIX Trading | Sending symbol resolution request for F.US.DSXM16. ID: 221771 | 2016-04-12 16:52:19 Intraday data recording state for symbol F.US.DSXM16 is set to download 'Pending'. | 2016-04-12 16:52:19 CQG FIX Trading | Received symbol resolution report for symbol F.US.EPM16. Request ID: 221768. Contract ID: 1. | 2016-04-12 16:52:21 CQG FIX Trading | Requesting market data including full depth for F.US.EPM16 | 2016-04-12 16:52:21 CQG FIX Trading | Received symbol resolution report for symbol F.US.DSXM16. Request ID: 221771. Contract ID: 2. | 2016-04-12 16:52:21 CQG FIX Trading | Requesting market data including full depth for F.US.DSXM16 | 2016-04-12 16:52:21 Symbol Error - ESM6 is unknown, unavailable, or improperly formatted. Exact match not found for symbol ESM6 | 2016-04-12 16:52:21 Symbol Error - FESXM6 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2016-04-12 16:52:21 HD Request # 14 | Downloading Intraday chart data for FESXM6 to the file FESXM6.scid. Service: cqg | 2016-04-12 16:52:22 HD Request # 14 | Download start Date-Time: 2015-10-09 16:52:22.000 | 2016-04-12 16:52:22 HD Request # 14 | Error downloading historical Intraday data for FESXM6. The symbol is unknown to the server. | 2016-04-12 16:52:22 HD Request # 14 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for FESXM6 | 2016-04-12 16:52:22 HD Request # 14 | Intraday download COMPLETE for FESXM6. Completion time: 0s. Unique request ID: 14 | 2016-04-12 16:52:22 Removed historical data download ID 14 | 2016-04-12 16:52:22 Real-time Intraday chart data file updates started for FESXM6 | 2016-04-12 16:52:22 Opened cached Intraday file: C:\SierraChartCQG\Data\FESXM6.scid | 2016-04-12 16:52:22 Intraday chart data file opened for FESXM6 | 2016-04-12 16:52:22 HD Request # 15 | Downloading Intraday chart data for ESM6 to the file ESM6.scid. Service: cqg | 2016-04-12 16:52:22 HD Request # 15 | Download start Date-Time: 2015-10-09 16:52:22.000 | 2016-04-12 16:52:22 HD Request # 15 | Error downloading historical Intraday data for ESM6. The symbol is unknown to the server. | 2016-04-12 16:52:22 HD Request # 15 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESM6 | 2016-04-12 16:52:22 HD Request # 15 | Intraday download COMPLETE for ESM6. Completion time: 0s. Unique request ID: 15 | 2016-04-12 16:52:22 Removed historical data download ID 15 | 2016-04-12 16:52:22 Real-time Intraday chart data file updates started for ESM6 | 2016-04-12 16:52:22 Opened cached Intraday file: C:\SierraChartCQG\Data\ESM6.scid | 2016-04-12 16:52:22 Intraday chart data file opened for ESM6 | 2016-04-12 16:52:22 Delaying start of download for F.US.EPM16 | 2016-04-12 16:52:22 Requesting market depth updates for: ESM6 if supported. | 2016-04-12 16:52:24 Requesting market depth updates for: F.US.DSXM16 if supported. | 2016-04-12 16:52:24 CQG FIX Trading | Requesting market data including full depth for F.US.DSXM16 | 2016-04-12 16:52:24 Requesting market depth updates for: F.US.EPM16 if supported. | 2016-04-12 16:52:24 CQG FIX Trading | Requesting market data including full depth for F.US.EPM16 | 2016-04-12 16:52:24 HD Request # 16 | Downloading Intraday chart data for F.US.EPM16 to the file F.US.EPM16.scid. Service: cqg | 2016-04-12 16:52:24 HD Request # 16 | Download start Date-Time: 2016-04-12 16:51:16.000 | 2016-04-12 16:52:24 HD Request # 16 | Using server: ds3.sierracharts.com port 10149 | 2016-04-12 16:52:24 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164. | 2016-04-12 16:52:24 Socket (16) | Connected. | 2016-04-12 16:52:27 HD Request # 16 | Sending historical data logon request message. | 2016-04-12 16:52:27 HD Request # 16 | Requesting Intraday data. Start Date-Time: 2016-04-12 16:51:16. Record interval: 1. Symbol: F.US.EPM16 | 2016-04-12 16:52:27 HD Request # 16 | Decompressing data. | 2016-04-12 16:52:27 HD Request # 16 | Receiving Intraday data for F.US.EPM16 starting at 2016-04-12 16:51:16 | 2016-04-12 16:52:27 HD Request # 16 | Timestamp of first Intraday data file record written: 2016-04-12 16:51:16 | 2016-04-12 16:52:27 Socket (16) | Shutdown and closed. | 2016-04-12 16:52:27 The network socket for historical data has been closed. | 2016-04-12 16:52:27 HD Request # 16 | Received 43 records from 2016-04-12 16:51:16 to 2016-04-12 16:52:22 (66.0 seconds) and wrote 43 records for F.US.EPM16 | 2016-04-12 16:52:27 Added 2 Time and Sales records to Intraday data file for F.US.EPM16 after download. | 2016-04-12 16:52:27 HD Request # 16 | Intraday download COMPLETE for F.US.EPM16. Completion time: 3s. Unique request ID: 13 | 2016-04-12 16:52:27 Removed historical data download ID 13 | 2016-04-12 16:52:27 Real-time Intraday chart data file updates started for F.US.EPM16 | 2016-04-12 16:52:27 Opened cached Intraday file: C:\SierraChartCQG\Data\F.US.EPM16.scid | 2016-04-12 16:52:27 Intraday chart data file opened for F.US.EPM16 | 2016-04-12 16:52:27 HD Request # 17 | Downloading Intraday chart data for F.US.DSXM16 to the file F.US.DSXM16.scid. Service: cqg | 2016-04-12 16:52:27 HD Request # 17 | Download start Date-Time: 2016-04-12 16:50:59.000 | 2016-04-12 16:52:27 HD Request # 17 | Using server: ds5.sierracharts.com port 10149 | 2016-04-12 16:52:27 Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106. | 2016-04-12 16:52:27 Chart #4 has tagged chart #3 for full recalculation. Chartbook: DOMChartbookCQG.cht | 2016-04-12 16:52:27 Chart #4 has tagged chart #5 for full recalculation. Chartbook: DOMChartbookCQG.cht | 2016-04-12 16:52:27 F.US.DSXM16 #5 | Performing a full recalculation because it has been tagged. Chartbook: DOMChartbookCQG.cht | 2016-04-12 16:52:27 F.US.EPM16 #3 | Performing a full recalculation because it has been tagged. Chartbook: DOMChartbookCQG.cht | 2016-04-12 16:52:28 Socket (17) | Connected. | 2016-04-12 16:52:31 HD Request # 17 | Sending historical data logon request message. | 2016-04-12 16:52:31 HD Request # 17 | Requesting Intraday data. Start Date-Time: 2016-04-12 16:50:59. Record interval: 1. Symbol: F.US.DSXM16 | 2016-04-12 16:52:40 HD Request # 17 | Decompressing data. | 2016-04-12 16:52:40 HD Request # 17 | Receiving Intraday data for F.US.DSXM16 starting at 2016-04-12 16:50:59 | 2016-04-12 16:52:40 HD Request # 17 | Timestamp of first Intraday data file record written: 2016-04-12 16:50:59 | 2016-04-12 16:52:40 Socket (17) | Shutdown and closed. | 2016-04-12 16:52:40 The network socket for historical data has been closed. | 2016-04-12 16:52:40 HD Request # 17 | Received 10 records from 2016-04-12 16:50:59 to 2016-04-12 16:52:11 (72.0 seconds) and wrote 10 records for F.US.DSXM16 | 2016-04-12 16:52:40 HD Request # 17 | Intraday download COMPLETE for F.US.DSXM16. Completion time: 13s. Unique request ID: 16 | 2016-04-12 16:52:40 Removed historical data download ID 16 | 2016-04-12 16:52:40 Real-time Intraday chart data file updates started for F.US.DSXM16 | 2016-04-12 16:52:40 Opened cached Intraday file: C:\SierraChartCQG\Data\F.US.DSXM16.scid | 2016-04-12 16:52:40 Intraday chart data file opened for F.US.DSXM16 | 2016-04-12 16:52:40 CQG WebAPI websocket (15) | Closed. Windows error code 10053: Connessione interrotta dal software del computer host. | 2016-04-12 16:53:39 CQG WebAPI websocket (15) | SSL shutdown indicates not able to send 'close notify'. | 2016-04-12 16:53:39 CQG WebAPI websocket (15) | SSL has been shut down. | 2016-04-12 16:53:39 CQG WebAPI websocket (15) | SSL object has been freed. SSL state is now disconnected. | 2016-04-12 16:53:39 CQG WebAPI websocket (15) | Shutdown and closed. | 2016-04-12 16:53:39 CQG WebAPI | Network socket for websocket has been closed by remote side. | 2016-04-12 16:53:39 CQG FIX Trading | Websocket closed. | 2016-04-12 16:53:39 Connection to the external service has been lost. | 2016-04-12 16:53:39 CQG FIX Trading | Disconnected. | 2016-04-12 16:53:39 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-04-12 16:53:39 CQG FIX: Not connecting to trading server because Username is not specified. | 2016-04-12 16:53:43 CQG FIX Trading | Connecting to market data server demoapi.cqg.com | 2016-04-12 16:53:43 CQG WebAPI | Connecting to websocket server. | 2016-04-12 16:53:43 CQG WebAPI websocket (0) | Resolved address demoapi.cqg.com to IP 208.48.16.32. | 2016-04-12 16:53:43 CQG WebAPI websocket (18) | Connected. | 2016-04-12 16:53:46 CQG WebAPI websocket (18) | Starting SSL 3/2 connection. | 2016-04-12 16:53:46 CQG WebAPI websocket (18) | SSL connection established. | 2016-04-12 16:53:50 CQG WebAPI | Opening websocket. | 2016-04-12 16:53:50 CQG WebAPI | Sending websocket handshake. | 2016-04-12 16:53:50 CQG WebAPI | Received websocket handshake acknowledgment. | 2016-04-12 16:53:50 CQG WebAPI | Web socket state is now open. | 2016-04-12 16:53:50 CQG FIX Trading | Websocket connected. | 2016-04-12 16:53:50 CQG FIX Trading | Sending market data logon message. | 2016-04-12 16:53:50 CQG FIX Trading | Logon successful. Session Token = +OGGgQX4Vho8PpLhZIOUgZd1+brGSt6jIGK6hW8xbl8 | 2016-04-12 16:53:50 CQG FIX Trading | Connected to data and trading server. | 2016-04-12 16:53:50 CQG FIX Trading | Starting real-time market data updates for: F.US.EPM16. ID: 1 | 2016-04-12 16:53:50 CQG FIX Trading | Sending symbol resolution request for F.US.EPM16. ID: 221772 | 2016-04-12 16:53:50 Intraday data recording state for symbol F.US.EPM16 is set to download 'Pending'. | 2016-04-12 16:53:50 Delaying start of download for F.US.EPM16 | 2016-04-12 16:53:50 CQG FIX Trading | Starting real-time market data updates for: FESXM6. ID: 2 | 2016-04-12 16:53:50 CQG FIX Trading | Sending symbol resolution request for FESXM6. ID: 221773 | 2016-04-12 16:53:50 CQG FIX Trading | Using primary service for historical data for FESXM6 | 2016-04-12 16:53:50 Intraday data recording state for symbol FESXM6 is set to download 'Pending'. | 2016-04-12 16:53:50 Delaying start of download for FESXM6 | 2016-04-12 16:53:50 CQG FIX Trading | Starting real-time market data updates for: ESM6. ID: 3 | 2016-04-12 16:53:50 CQG FIX Trading | Sending symbol resolution request for ESM6. ID: 221774 | 2016-04-12 16:53:50 CQG FIX Trading | Using primary service for historical data for ESM6 | 2016-04-12 16:53:50 Intraday data recording state for symbol ESM6 is set to download 'Pending'. | 2016-04-12 16:53:50 CQG FIX Trading | Starting real-time market data updates for: F.US.DSXM16. ID: 4 | 2016-04-12 16:53:50 CQG FIX Trading | Sending symbol resolution request for F.US.DSXM16. ID: 221775 | 2016-04-12 16:53:50 Intraday data recording state for symbol F.US.DSXM16 is set to download 'Pending'. | 2016-04-12 16:53:50 CQG FIX Trading | Received symbol resolution report for symbol F.US.EPM16. Request ID: 221772. Contract ID: 1. | 2016-04-12 16:53:50 CQG FIX Trading | Requesting market data including full depth for F.US.EPM16 | 2016-04-12 16:53:50 CQG FIX Trading | Received symbol resolution report for symbol F.US.DSXM16. Request ID: 221775. Contract ID: 2. | 2016-04-12 16:53:50 CQG FIX Trading | Requesting market data including full depth for F.US.DSXM16 | 2016-04-12 16:53:50 Symbol Error - ESM6 is unknown, unavailable, or improperly formatted. Exact match not found for symbol ESM6 | 2016-04-12 16:53:51 Symbol Error - FESXM6 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2016-04-12 16:53:51 HD Request # 18 | Downloading Intraday chart data for FESXM6 to the file FESXM6.scid. Service: cqg | 2016-04-12 16:53:51 HD Request # 18 | Download start Date-Time: 2015-10-09 16:53:51.000 | 2016-04-12 16:53:51 HD Request # 18 | Error downloading historical Intraday data for FESXM6. The symbol is unknown to the server. | 2016-04-12 16:53:51 HD Request # 18 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for FESXM6 | 2016-04-12 16:53:51 HD Request # 18 | Intraday download COMPLETE for FESXM6. Completion time: 0s. Unique request ID: 18 | 2016-04-12 16:53:51 Removed historical data download ID 18 | 2016-04-12 16:53:51 Real-time Intraday chart data file updates started for FESXM6 | 2016-04-12 16:53:51 Opened cached Intraday file: C:\SierraChartCQG\Data\FESXM6.scid | 2016-04-12 16:53:51 Intraday chart data file opened for FESXM6 | 2016-04-12 16:53:51 HD Request # 19 | Downloading Intraday chart data for ESM6 to the file ESM6.scid. Service: cqg | 2016-04-12 16:53:51 HD Request # 19 | Download start Date-Time: 2015-10-09 16:53:51.000 | 2016-04-12 16:53:51 HD Request # 19 | Error downloading historical Intraday data for ESM6. The symbol is unknown to the server. | 2016-04-12 16:53:51 HD Request # 19 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESM6 | 2016-04-12 16:53:51 HD Request # 19 | Intraday download COMPLETE for ESM6. Completion time: 0s. Unique request ID: 19 | 2016-04-12 16:53:51 Removed historical data download ID 19 | 2016-04-12 16:53:51 Real-time Intraday chart data file updates started for ESM6 | 2016-04-12 16:53:51 Opened cached Intraday file: C:\SierraChartCQG\Data\ESM6.scid | 2016-04-12 16:53:51 Intraday chart data file opened for ESM6 | 2016-04-12 16:53:51 Delaying start of download for F.US.EPM16 | 2016-04-12 16:53:51 Requesting market depth updates for: ESM6 if supported. | 2016-04-12 16:53:55 Requesting market depth updates for: F.US.DSXM16 if supported. | 2016-04-12 16:53:55 CQG FIX Trading | Requesting market data including full depth for F.US.DSXM16 | 2016-04-12 16:53:55 Requesting market depth updates for: F.US.EPM16 if supported. | 2016-04-12 16:53:55 CQG FIX Trading | Requesting market data including full depth for F.US.EPM16 | 2016-04-12 16:53:55 HD Request # 20 | Downloading Intraday chart data for F.US.EPM16 to the file F.US.EPM16.scid. Service: cqg | 2016-04-12 16:53:55 HD Request # 20 | Download start Date-Time: 2016-04-12 16:52:22.000 | 2016-04-12 16:53:55 HD Request # 20 | Using server: ds4.sierracharts.com port 10149 | 2016-04-12 16:53:55 Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26. | 2016-04-12 16:53:55 Socket (20) | Connected. | 2016-04-12 16:53:55 HD Request # 20 | Sending historical data logon request message. | 2016-04-12 16:53:55 HD Request # 20 | Requesting Intraday data. Start Date-Time: 2016-04-12 16:52:22. Record interval: 1. Symbol: F.US.EPM16 | 2016-04-12 16:53:55 HD Request # 20 | Decompressing data. | 2016-04-12 16:53:56 HD Request # 20 | Receiving Intraday data for F.US.EPM16 starting at 2016-04-12 16:52:22 | 2016-04-12 16:53:56 HD Request # 20 | Timestamp of first Intraday data file record written: 2016-04-12 16:52:22 | 2016-04-12 16:53:56 Socket (20) | Shutdown and closed. | 2016-04-12 16:53:56 The network socket for historical data has been closed. | 2016-04-12 16:53:56 HD Request # 20 | Received 77 records from 2016-04-12 16:52:22 to 2016-04-12 16:53:54 (92.0 seconds) and wrote 77 records for F.US.EPM16 | 2016-04-12 16:53:56 HD Request # 20 | Intraday download COMPLETE for F.US.EPM16. Completion time: 0s. Unique request ID: 17 | 2016-04-12 16:53:56 Removed historical data download ID 17 | 2016-04-12 16:53:56 Real-time Intraday chart data file updates started for F.US.EPM16 | 2016-04-12 16:53:56 Opened cached Intraday file: C:\SierraChartCQG\Data\F.US.EPM16.scid | 2016-04-12 16:53:56 Intraday chart data file opened for F.US.EPM16 | 2016-04-12 16:53:56 HD Request # 21 | Downloading Intraday chart data for F.US.DSXM16 to the file F.US.DSXM16.scid. Service: cqg | 2016-04-12 16:53:56 HD Request # 21 | Download start Date-Time: 2016-04-12 16:52:11.000 | 2016-04-12 16:53:56 HD Request # 21 | Using server: ds3.sierracharts.com port 10149 | 2016-04-12 16:53:56 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164. | 2016-04-12 16:53:56 Chart #4 has tagged chart #3 for full recalculation. Chartbook: DOMChartbookCQG.cht | 2016-04-12 16:53:56 Chart #4 has tagged chart #5 for full recalculation. Chartbook: DOMChartbookCQG.cht | 2016-04-12 16:53:56 F.US.DSXM16 #5 | Performing a full recalculation because it has been tagged. Chartbook: DOMChartbookCQG.cht | 2016-04-12 16:53:56 F.US.EPM16 #3 | Performing a full recalculation because it has been tagged. Chartbook: DOMChartbookCQG.cht | 2016-04-12 16:53:56 Socket (21) | Connected. | 2016-04-12 16:53:56 HD Request # 21 | Sending historical data logon request message. | 2016-04-12 16:53:56 HD Request # 21 | Requesting Intraday data. Start Date-Time: 2016-04-12 16:52:11. Record interval: 1. Symbol: F.US.DSXM16 | 2016-04-12 16:53:57 HD Request # 21 | Decompressing data. | 2016-04-12 16:54:06 HD Request # 21 | Receiving Intraday data for F.US.DSXM16 starting at 2016-04-12 16:52:11 | 2016-04-12 16:54:06 HD Request # 21 | Timestamp of first Intraday data file record written: 2016-04-12 16:52:11 | 2016-04-12 16:54:06 Socket (21) | Shutdown and closed. | 2016-04-12 16:54:06 The network socket for historical data has been closed. | 2016-04-12 16:54:06 HD Request # 21 | Received 19 records from 2016-04-12 16:52:11 to 2016-04-12 16:53:55 (104.0 seconds) and wrote 19 records for F.US.DSXM16 | 2016-04-12 16:54:06 HD Request # 21 | Intraday download COMPLETE for F.US.DSXM16. Completion time: 11s. Unique request ID: 20 | 2016-04-12 16:54:06 Removed historical data download ID 20 | 2016-04-12 16:54:06 Real-time Intraday chart data file updates started for F.US.DSXM16 | 2016-04-12 16:54:06 Opened cached Intraday file: C:\SierraChartCQG\Data\F.US.DSXM16.scid | 2016-04-12 16:54:06 Intraday chart data file opened for F.US.DSXM16 | 2016-04-12 16:54:06 The data feed was lost. There was no activity for at least 60.0 seconds. | 2016-04-12 16:55:27 Connection to the external service has been lost. | 2016-04-12 16:55:27 CQG FIX Trading | Sending Web API Logoff message. | 2016-04-12 16:55:27 CQG WebAPI websocket (18) | SSL shutdown indicates not able to send 'close notify'. | 2016-04-12 16:55:27 CQG WebAPI websocket (18) | SSL has been shut down. | 2016-04-12 16:55:27 CQG WebAPI websocket (18) | SSL object has been freed. SSL state is now disconnected. | 2016-04-12 16:55:27 CQG WebAPI websocket (18) | Shutdown and closed. | 2016-04-12 16:55:27 CQG WebAPI | Websocket closed. | 2016-04-12 16:55:27 CQG FIX Trading | Websocket closed. | 2016-04-12 16:55:27 CQG FIX Trading | Disconnected. | 2016-04-12 16:55:27 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-04-12 16:55:27 CQG FIX: Not connecting to trading server because Username is not specified. | 2016-04-12 16:55:31 CQG FIX Trading | Connecting to market data server demoapi.cqg.com | 2016-04-12 16:55:31 CQG WebAPI | Connecting to websocket server. | 2016-04-12 16:55:31 CQG WebAPI websocket (0) | Resolved address demoapi.cqg.com to IP 208.48.16.32. | 2016-04-12 16:55:31 CQG WebAPI websocket (22) | Connected. | 2016-04-12 16:55:40 CQG WebAPI websocket (22) | Starting SSL 3/2 connection. | 2016-04-12 16:55:40 CQG WebAPI websocket (22) | SSL connection established. | 2016-04-12 16:55:40 CQG WebAPI | Opening websocket. | 2016-04-12 16:55:40 CQG WebAPI | Sending websocket handshake. | 2016-04-12 16:55:40 CQG WebAPI | Received websocket handshake acknowledgment. | 2016-04-12 16:55:40 CQG WebAPI | Web socket state is now open. | 2016-04-12 16:55:40 CQG FIX Trading | Websocket connected. | 2016-04-12 16:55:40 CQG FIX Trading | Sending market data logon message. | 2016-04-12 16:55:40 CQG FIX Trading | Logon successful. Session Token = qNI2bsHxBKhkWuEbRJBEST/9Nyr08QRtiErpvRDkeW0 | 2016-04-12 16:55:40 CQG FIX Trading | Connected to data and trading server. | 2016-04-12 16:55:40 CQG FIX Trading | Starting real-time market data updates for: F.US.EPM16. ID: 1 | 2016-04-12 16:55:40 CQG FIX Trading | Sending symbol resolution request for F.US.EPM16. ID: 221776 | 2016-04-12 16:55:40 Intraday data recording state for symbol F.US.EPM16 is set to download 'Pending'. | 2016-04-12 16:55:40 Delaying start of download for F.US.EPM16 | 2016-04-12 16:55:40 CQG FIX Trading | Starting real-time market data updates for: F.US.DSXM16. ID: 2 | 2016-04-12 16:55:40 CQG FIX Trading | Sending symbol resolution request for F.US.DSXM16. ID: 221777 | 2016-04-12 16:55:40 Intraday data recording state for symbol F.US.DSXM16 is set to download 'Pending'. | 2016-04-12 16:55:40 CQG FIX Trading | Starting real-time market data updates for: FESXM6. ID: 3 | 2016-04-12 16:55:40 CQG FIX Trading | Sending symbol resolution request for FESXM6. ID: 221778 | 2016-04-12 16:55:40 CQG FIX Trading | Using primary service for historical data for FESXM6 | 2016-04-12 16:55:40 Intraday data recording state for symbol FESXM6 is set to download 'Pending'. | 2016-04-12 16:55:40 Delaying start of download for FESXM6 | 2016-04-12 16:55:40 CQG FIX Trading | Starting real-time market data updates for: ESM6. ID: 4 | 2016-04-12 16:55:40 CQG FIX Trading | Sending symbol resolution request for ESM6. ID: 221779 | 2016-04-12 16:55:40 CQG FIX Trading | Using primary service for historical data for ESM6 | 2016-04-12 16:55:40 Intraday data recording state for symbol ESM6 is set to download 'Pending'. | 2016-04-12 16:55:40 CQG FIX Trading | Received symbol resolution report for symbol F.US.EPM16. Request ID: 221776. Contract ID: 1. | 2016-04-12 16:55:41 CQG FIX Trading | Requesting market data including full depth for F.US.EPM16 | 2016-04-12 16:55:41 CQG FIX Trading | Received symbol resolution report for symbol F.US.DSXM16. Request ID: 221777. Contract ID: 2. | 2016-04-12 16:55:41 CQG FIX Trading | Requesting market data including full depth for F.US.DSXM16 | 2016-04-12 16:55:41 Symbol Error - ESM6 is unknown, unavailable, or improperly formatted. Exact match not found for symbol ESM6 | 2016-04-12 16:55:41 Symbol Error - FESXM6 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2016-04-12 16:55:41 Delaying start of download for F.US.EPM16 | 2016-04-12 16:55:41 HD Request # 22 | Downloading Intraday chart data for FESXM6 to the file FESXM6.scid. Service: cqg | 2016-04-12 16:55:41 HD Request # 22 | Download start Date-Time: 2015-10-09 16:55:41.000 | 2016-04-12 16:55:41 HD Request # 22 | Error downloading historical Intraday data for FESXM6. The symbol is unknown to the server. | 2016-04-12 16:55:41 HD Request # 22 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for FESXM6 | 2016-04-12 16:55:41 HD Request # 22 | Intraday download COMPLETE for FESXM6. Completion time: 0s. Unique request ID: 23 | 2016-04-12 16:55:41 Removed historical data download ID 23 | 2016-04-12 16:55:41 Real-time Intraday chart data file updates started for FESXM6 | 2016-04-12 16:55:41 Opened cached Intraday file: C:\SierraChartCQG\Data\FESXM6.scid | 2016-04-12 16:55:41 Intraday chart data file opened for FESXM6 | 2016-04-12 16:55:41 HD Request # 23 | Downloading Intraday chart data for ESM6 to the file ESM6.scid. Service: cqg | 2016-04-12 16:55:41 HD Request # 23 | Download start Date-Time: 2015-10-09 16:55:41.000 | 2016-04-12 16:55:41 HD Request # 23 | Error downloading historical Intraday data for ESM6. The symbol is unknown to the server. | 2016-04-12 16:55:41 HD Request # 23 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESM6 | 2016-04-12 16:55:41 HD Request # 23 | Intraday download COMPLETE for ESM6. Completion time: 0s. Unique request ID: 24 | 2016-04-12 16:55:41 Removed historical data download ID 24 | 2016-04-12 16:55:41 Real-time Intraday chart data file updates started for ESM6 | 2016-04-12 16:55:41 Opened cached Intraday file: C:\SierraChartCQG\Data\ESM6.scid | 2016-04-12 16:55:41 Intraday chart data file opened for ESM6 | 2016-04-12 16:55:41 Requesting market depth updates for: ESM6 if supported. | 2016-04-12 16:55:45 Requesting market depth updates for: F.US.DSXM16 if supported. | 2016-04-12 16:55:45 CQG FIX Trading | Requesting market data including full depth for F.US.DSXM16 | 2016-04-12 16:55:45 Requesting market depth updates for: F.US.EPM16 if supported. | 2016-04-12 16:55:45 CQG FIX Trading | Requesting market data including full depth for F.US.EPM16 | 2016-04-12 16:55:45 HD Request # 24 | Downloading Intraday chart data for F.US.EPM16 to the file F.US.EPM16.scid. Service: cqg | 2016-04-12 16:55:45 HD Request # 24 | Download start Date-Time: 2016-04-12 16:54:10.000 | 2016-04-12 16:55:45 HD Request # 24 | Using server: ds5.sierracharts.com port 10149 | 2016-04-12 16:55:45 Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106. | 2016-04-12 16:55:45 Socket (23) | Shutdown and closed. | 2016-04-12 16:56:06 HD Request # 24 | Error downloading historical Intraday data for F.US.EPM16. The network socket has been closed. Retrying download. | 2016-04-12 16:56:06 HD Request # 24 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for F.US.EPM16 | 2016-04-12 16:56:06 HD Request # 25 | Downloading Intraday chart data for F.US.EPM16 to the file F.US.EPM16.scid. Service: cqg | 2016-04-12 16:56:06 HD Request # 25 | Download start Date-Time: 2016-04-12 16:54:10.000 | 2016-04-12 16:56:06 HD Request # 25 | Using server: ds4.sierracharts.com port 10149 | 2016-04-12 16:56:06 Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26. | 2016-04-12 16:56:06 Socket (25) | Connected. | 2016-04-12 16:56:06 HD Request # 25 | Sending historical data logon request message. | 2016-04-12 16:56:06 HD Request # 25 | Requesting Intraday data. Start Date-Time: 2016-04-12 16:54:10. Record interval: 1. Symbol: F.US.EPM16 | 2016-04-12 16:56:06 HD Request # 25 | Decompressing data. | 2016-04-12 16:56:06 HD Request # 25 | Receiving Intraday data for F.US.EPM16 starting at 2016-04-12 16:54:10 | 2016-04-12 16:56:06 HD Request # 25 | Timestamp of first Intraday data file record written: 2016-04-12 16:54:10 | 2016-04-12 16:56:06 Socket (25) | Shutdown and closed. | 2016-04-12 16:56:06 The network socket for historical data has been closed. | 2016-04-12 16:56:06 HD Request # 25 | Received 84 records from 2016-04-12 16:54:10 to 2016-04-12 16:56:03 (113.0 seconds) and wrote 84 records for F.US.EPM16 | 2016-04-12 16:56:06 HD Request # 25 | Intraday download COMPLETE for F.US.EPM16. Completion time: 1s. Unique request ID: 21 | 2016-04-12 16:56:06 Removed historical data download ID 21 | 2016-04-12 16:56:06 Real-time Intraday chart data file updates started for F.US.EPM16 | 2016-04-12 16:56:06 Opened cached Intraday file: C:\SierraChartCQG\Data\F.US.EPM16.scid | 2016-04-12 16:56:06 Intraday chart data file opened for F.US.EPM16 | 2016-04-12 16:56:06 HD Request # 26 | Downloading Intraday chart data for F.US.DSXM16 to the file F.US.DSXM16.scid. Service: cqg | 2016-04-12 16:56:06 HD Request # 26 | Download start Date-Time: 2016-04-12 16:53:54.000 | 2016-04-12 16:56:06 HD Request # 26 | Using server: ds3.sierracharts.com port 10149 | 2016-04-12 16:56:06 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164. | 2016-04-12 16:56:06 Chart #4 has tagged chart #3 for full recalculation. Chartbook: DOMChartbookCQG.cht | 2016-04-12 16:56:06 Chart #4 has tagged chart #5 for full recalculation. Chartbook: DOMChartbookCQG.cht | 2016-04-12 16:56:06 F.US.DSXM16 #5 | Performing a full recalculation because it has been tagged. Chartbook: DOMChartbookCQG.cht | 2016-04-12 16:56:06 F.US.EPM16 #3 | Performing a full recalculation because it has been tagged. Chartbook: DOMChartbookCQG.cht | 2016-04-12 16:56:06 Socket (26) | Connected. | 2016-04-12 16:56:06 HD Request # 26 | Sending historical data logon request message. | 2016-04-12 16:56:06 HD Request # 26 | Requesting Intraday data. Start Date-Time: 2016-04-12 16:53:54. Record interval: 1. Symbol: F.US.DSXM16 | 2016-04-12 16:56:10 HD Request # 26 | Decompressing data. | 2016-04-12 16:56:10 HD Request # 26 | Receiving Intraday data for F.US.DSXM16 starting at 2016-04-12 16:53:54 | 2016-04-12 16:56:10 HD Request # 26 | Timestamp of first Intraday data file record written: 2016-04-12 16:53:54 | 2016-04-12 16:56:10 Socket (26) | Shutdown and closed. | 2016-04-12 16:56:10 The network socket for historical data has been closed. | 2016-04-12 16:56:10 HD Request # 26 | Received 20 records from 2016-04-12 16:53:54 to 2016-04-12 16:56:07 (2.2 minutes) and wrote 20 records for F.US.DSXM16 | 2016-04-12 16:56:10 HD Request # 26 | Intraday download COMPLETE for F.US.DSXM16. Completion time: 4s. Unique request ID: 22 | 2016-04-12 16:56:10 Removed historical data download ID 22 | 2016-04-12 16:56:10 Real-time Intraday chart data file updates started for F.US.DSXM16 | 2016-04-12 16:56:10 Opened cached Intraday file: C:\SierraChartCQG\Data\F.US.DSXM16.scid | 2016-04-12 16:56:10 Intraday chart data file opened for F.US.DSXM16 | 2016-04-12 16:56:10 CQG WebAPI websocket (22) | Closed. Windows error code 10053: Connessione interrotta dal software del computer host. | 2016-04-12 16:57:01 CQG WebAPI websocket (22) | SSL shutdown indicates not able to send 'close notify'. | 2016-04-12 16:57:01 CQG WebAPI websocket (22) | SSL has been shut down. | 2016-04-12 16:57:01 CQG WebAPI websocket (22) | SSL object has been freed. SSL state is now disconnected. | 2016-04-12 16:57:01 CQG WebAPI websocket (22) | Shutdown and closed. | 2016-04-12 16:57:01 CQG WebAPI | Network socket for websocket has been closed by remote side. | 2016-04-12 16:57:01 CQG FIX Trading | Websocket closed. | 2016-04-12 16:57:01 Connection to the external service has been lost. | 2016-04-12 16:57:01 CQG FIX Trading | Disconnected. | 2016-04-12 16:57:01 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-04-12 16:57:01 CQG FIX: Not connecting to trading server because Username is not specified. | 2016-04-12 16:57:04 CQG FIX Trading | Connecting to market data server demoapi.cqg.com | 2016-04-12 16:57:04 CQG WebAPI | Connecting to websocket server. | 2016-04-12 16:57:04 CQG WebAPI websocket (0) | Resolved address demoapi.cqg.com to IP 208.48.16.32. | 2016-04-12 16:57:04 CQG WebAPI websocket (27) | Connected. | 2016-04-12 16:57:07 CQG WebAPI websocket (27) | Starting SSL 3/2 connection. | 2016-04-12 16:57:07 CQG WebAPI websocket (27) | SSL connection timed out. | 2016-04-12 16:57:18 * CQG WebAPI websocket (27) | SSL connection failed. | 2016-04-12 16:57:18 CQG WebAPI websocket (27) | SSL object has been freed. SSL state is now disconnected. | 2016-04-12 16:57:18 CQG WebAPI websocket (27) | Shutdown and closed. | 2016-04-12 16:57:18 CQG WebAPI | Websocket closed. | 2016-04-12 16:57:18 CQG FIX Trading | Websocket closed. | 2016-04-12 16:57:18 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-04-12 16:57:18 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-04-12 16:57:18 CQG FIX Trading | Disconnected. | 2016-04-12 16:57:18 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-04-12 16:57:18 CQG FIX: Not connecting to trading server because Username is not specified. | 2016-04-12 16:57:21 CQG FIX Trading | Connecting to market data server demoapi.cqg.com | 2016-04-12 16:57:21 CQG WebAPI | Connecting to websocket server. | 2016-04-12 16:57:21 CQG WebAPI websocket (0) | Resolved address demoapi.cqg.com to IP 208.48.16.32. | 2016-04-12 16:57:21 CQG WebAPI websocket (28) | Connected. | 2016-04-12 16:57:21 CQG WebAPI websocket (28) | Starting SSL 3/2 connection. | 2016-04-12 16:57:21 CQG WebAPI websocket (28) | SSL connection established. | 2016-04-12 16:57:23 CQG WebAPI | Opening websocket. | 2016-04-12 16:57:23 CQG WebAPI | Sending websocket handshake. | 2016-04-12 16:57:23 CQG WebAPI | Received websocket handshake acknowledgment. | 2016-04-12 16:57:27 CQG WebAPI | Web socket state is now open. | 2016-04-12 16:57:27 CQG FIX Trading | Websocket connected. | 2016-04-12 16:57:27 CQG FIX Trading | Sending market data logon message. | 2016-04-12 16:57:27 CQG FIX Trading | Logon successful. Session Token = K83qUXq9c49oi25Ugcme1MGHTr+oReNmzD13hlaXWLc | 2016-04-12 16:57:27 CQG FIX Trading | Connected to data and trading server. | 2016-04-12 16:57:27 CQG FIX Trading | Starting real-time market data updates for: FESXM6. ID: 1 | 2016-04-12 16:57:27 CQG FIX Trading | Sending symbol resolution request for FESXM6. ID: 221780 | 2016-04-12 16:57:27 CQG FIX Trading | Using primary service for historical data for FESXM6 | 2016-04-12 16:57:27 Intraday data recording state for symbol FESXM6 is set to download 'Pending'. | 2016-04-12 16:57:27 Delaying start of download for FESXM6 | 2016-04-12 16:57:27 CQG FIX Trading | Starting real-time market data updates for: ESM6. ID: 2 | 2016-04-12 16:57:27 CQG FIX Trading | Sending symbol resolution request for ESM6. ID: 221781 | 2016-04-12 16:57:27 CQG FIX Trading | Using primary service for historical data for ESM6 | 2016-04-12 16:57:27 Intraday data recording state for symbol ESM6 is set to download 'Pending'. | 2016-04-12 16:57:27 CQG FIX Trading | Starting real-time market data updates for: F.US.EPM16. ID: 3 | 2016-04-12 16:57:27 CQG FIX Trading | Sending symbol resolution request for F.US.EPM16. ID: 221782 | 2016-04-12 16:57:27 Intraday data recording state for symbol F.US.EPM16 is set to download 'Pending'. | 2016-04-12 16:57:27 Delaying start of download for F.US.EPM16 | 2016-04-12 16:57:27 CQG FIX Trading | Starting real-time market data updates for: F.US.DSXM16. ID: 4 | 2016-04-12 16:57:27 CQG FIX Trading | Sending symbol resolution request for F.US.DSXM16. ID: 221783 | 2016-04-12 16:57:27 Intraday data recording state for symbol F.US.DSXM16 is set to download 'Pending'. | 2016-04-12 16:57:27 Symbol Error - FESXM6 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2016-04-12 16:57:28 CQG FIX Trading | Received symbol resolution report for symbol F.US.EPM16. Request ID: 221782. Contract ID: 1. | 2016-04-12 16:57:28 CQG FIX Trading | Requesting market data including full depth for F.US.EPM16 | 2016-04-12 16:57:28 CQG FIX Trading | Received symbol resolution report for symbol F.US.DSXM16. Request ID: 221783. Contract ID: 2. | 2016-04-12 16:57:28 CQG FIX Trading | Requesting market data including full depth for F.US.DSXM16 | 2016-04-12 16:57:28 Symbol Error - ESM6 is unknown, unavailable, or improperly formatted. Exact match not found for symbol ESM6 | 2016-04-12 16:57:28 HD Request # 27 | Downloading Intraday chart data for FESXM6 to the file FESXM6.scid. Service: cqg | 2016-04-12 16:57:28 HD Request # 27 | Download start Date-Time: 2015-10-09 16:57:28.000 | 2016-04-12 16:57:28 HD Request # 27 | Error downloading historical Intraday data for FESXM6. The symbol is unknown to the server. | 2016-04-12 16:57:28 HD Request # 27 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for FESXM6 | 2016-04-12 16:57:28 HD Request # 27 | Intraday download COMPLETE for FESXM6. Completion time: 0s. Unique request ID: 25 | 2016-04-12 16:57:28 Removed historical data download ID 25 | 2016-04-12 16:57:28 Real-time Intraday chart data file updates started for FESXM6 | 2016-04-12 16:57:28 Opened cached Intraday file: C:\SierraChartCQG\Data\FESXM6.scid | 2016-04-12 16:57:28 Intraday chart data file opened for FESXM6 | 2016-04-12 16:57:28 HD Request # 28 | Downloading Intraday chart data for ESM6 to the file ESM6.scid. Service: cqg | 2016-04-12 16:57:28 HD Request # 28 | Download start Date-Time: 2015-10-09 16:57:28.000 | 2016-04-12 16:57:28 HD Request # 28 | Error downloading historical Intraday data for ESM6. The symbol is unknown to the server. | 2016-04-12 16:57:28 HD Request # 28 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESM6 | 2016-04-12 16:57:28 HD Request # 28 | Intraday download COMPLETE for ESM6. Completion time: 0s. Unique request ID: 26 | 2016-04-12 16:57:28 Removed historical data download ID 26 | 2016-04-12 16:57:28 Real-time Intraday chart data file updates started for ESM6 | 2016-04-12 16:57:28 Opened cached Intraday file: C:\SierraChartCQG\Data\ESM6.scid | 2016-04-12 16:57:28 Intraday chart data file opened for ESM6 | 2016-04-12 16:57:28 Delaying start of download for F.US.EPM16 | 2016-04-12 16:57:28 Requesting market depth updates for: ESM6 if supported. | 2016-04-12 16:57:32 Requesting market depth updates for: F.US.DSXM16 if supported. | 2016-04-12 16:57:32 CQG FIX Trading | Requesting market data including full depth for F.US.DSXM16 | 2016-04-12 16:57:32 Requesting market depth updates for: F.US.EPM16 if supported. | 2016-04-12 16:57:32 CQG FIX Trading | Requesting market data including full depth for F.US.EPM16 | 2016-04-12 16:57:32 HD Request # 29 | Downloading Intraday chart data for F.US.EPM16 to the file F.US.EPM16.scid. Service: cqg | 2016-04-12 16:57:32 HD Request # 29 | Download start Date-Time: 2016-04-12 16:55:58.000 | 2016-04-12 16:57:32 HD Request # 29 | Using server: ds5.sierracharts.com port 10149 | 2016-04-12 16:57:32 Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106. | 2016-04-12 16:57:32 Socket (29) | Connected. | 2016-04-12 16:57:32 HD Request # 29 | Sending historical data logon request message. | 2016-04-12 16:57:32 HD Request # 29 | Requesting Intraday data. Start Date-Time: 2016-04-12 16:55:58. Record interval: 1. Symbol: F.US.EPM16 | 2016-04-12 16:57:39 HD Request # 29 | Decompressing data. | 2016-04-12 16:57:39 HD Request # 29 | Receiving Intraday data for F.US.EPM16 starting at 2016-04-12 16:55:58 | 2016-04-12 16:57:39 HD Request # 29 | Timestamp of first Intraday data file record written: 2016-04-12 16:55:58 | 2016-04-12 16:57:39 Socket (29) | Shutdown and closed. | 2016-04-12 16:57:39 The network socket for historical data has been closed. | 2016-04-12 16:57:39 HD Request # 29 | Received 65 records from 2016-04-12 16:55:58 to 2016-04-12 16:57:37 (99.0 seconds) and wrote 65 records for F.US.EPM16 | 2016-04-12 16:57:39 Added 33 Time and Sales records to Intraday data file for F.US.EPM16 after download. | 2016-04-12 16:57:39 HD Request # 29 | Intraday download COMPLETE for F.US.EPM16. Completion time: 7s. Unique request ID: 27 | 2016-04-12 16:57:39 Removed historical data download ID 27 | 2016-04-12 16:57:39 Real-time Intraday chart data file updates started for F.US.EPM16 | 2016-04-12 16:57:39 Opened cached Intraday file: C:\SierraChartCQG\Data\F.US.EPM16.scid | 2016-04-12 16:57:39 Intraday chart data file opened for F.US.EPM16 | 2016-04-12 16:57:39 HD Request # 30 | Downloading Intraday chart data for F.US.DSXM16 to the file F.US.DSXM16.scid. Service: cqg | 2016-04-12 16:57:39 HD Request # 30 | Download start Date-Time: 2016-04-12 16:55:54.000 | 2016-04-12 16:57:39 HD Request # 30 | Using server: ds4.sierracharts.com port 10149 | 2016-04-12 16:57:39 Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26. | 2016-04-12 16:57:39 Chart #4 has tagged chart #3 for full recalculation. Chartbook: DOMChartbookCQG.cht | 2016-04-12 16:57:39 Chart #4 has tagged chart #5 for full recalculation. Chartbook: DOMChartbookCQG.cht | 2016-04-12 16:57:39 F.US.DSXM16 #5 | Performing a full recalculation because it has been tagged. Chartbook: DOMChartbookCQG.cht | 2016-04-12 16:57:39 F.US.EPM16 #3 | Performing a full recalculation because it has been tagged. Chartbook: DOMChartbookCQG.cht | 2016-04-12 16:57:39 Socket (30) | Connected. | 2016-04-12 16:57:39 HD Request # 30 | Sending historical data logon request message. | 2016-04-12 16:57:39 HD Request # 30 | Requesting Intraday data. Start Date-Time: 2016-04-12 16:55:54. Record interval: 1. Symbol: F.US.DSXM16 | 2016-04-12 16:57:40 HD Request # 30 | Decompressing data. | 2016-04-12 16:57:40 HD Request # 30 | Receiving Intraday data for F.US.DSXM16 starting at 2016-04-12 16:55:54 | 2016-04-12 16:57:40 HD Request # 30 | Timestamp of first Intraday data file record written: 2016-04-12 16:55:54 | 2016-04-12 16:57:40 Socket (30) | Shutdown and closed. | 2016-04-12 16:57:40 The network socket for historical data has been closed. | 2016-04-12 16:57:40 HD Request # 30 | Received 16 records from 2016-04-12 16:55:54 to 2016-04-12 16:57:34 (100.0 seconds) and wrote 16 records for F.US.DSXM16 | 2016-04-12 16:57:40 HD Request # 30 | Intraday download COMPLETE for F.US.DSXM16. Completion time: 1s. Unique request ID: 28 | 2016-04-12 16:57:40 Removed historical data download ID 28 | 2016-04-12 16:57:40 Real-time Intraday chart data file updates started for F.US.DSXM16 | 2016-04-12 16:57:40 Opened cached Intraday file: C:\SierraChartCQG\Data\F.US.DSXM16.scid | 2016-04-12 16:57:40 Intraday chart data file opened for F.US.DSXM16 | 2016-04-12 16:57:40 Date Time Of Last Edit: 2016-04-12 16:58:04
| [2016-04-12 17:28:23] |
We see you are using some invalid symbols. You need to use the symbols in File >> Find Symbol. This is an example of one of the correct symbols: F.US.EPM16 To change the symbol of the charts, refer to: Changing the Symbol of a Chart: Changing the Symbol of a Chart or Trade DOM Through Chart Settings Below are some of the relevant error messages. There is a connectivity problem between your computer and the CQG server. CQG WebAPI websocket (22) | Closed. Windows error code 10053: Connessione interrotta dal software del computer host. | 2016-04-12 16:57:01 CQG FIX Trading | Connecting to market data server demoapi.cqg.com | 2016-04-12 16:57:04 CQG WebAPI | Connecting to websocket server. | 2016-04-12 16:57:04 CQG WebAPI websocket (0) | Resolved address demoapi.cqg.com to IP 208.48.16.32. | 2016-04-12 16:57:04 CQG WebAPI websocket (27) | Connected. | 2016-04-12 16:57:07 CQG WebAPI websocket (27) | Starting SSL 3/2 connection. | 2016-04-12 16:57:07 CQG WebAPI websocket (27) | SSL connection timed out. | 2016-04-12 16:57:18 * Refer to help topic 1.2: https://www.sierrachart.com/index.php?page=doc/helpdetails1.php#h1.2 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-04-12 17:29:39
| [2016-04-12 17:43:29] |
| User942115 - Posts: 5 |
Yes, I changed the symbol but there is a problem of connectivity Is this kind of problem so common with CQG? |
| [2016-04-12 18:01:19] |
It does seem to occur more when using CQG based upon user reports. Consider using the Sierra Chart Exchange Data Feed: Sierra Chart Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-04-12 18:02:13
