Date/Time: Wed, 28 Oct 2026 20:36:40 +0000
Weird KC daily bar
View Count: 1036
| [2016-04-08 19:14:15] |
| i960 - Posts: 360 |
Data has been deleted and redownloaded already. The weird part is that the DLY file does not have a problem, whereas the chart's idea of it does. Here's the last 4 rows of the daily file used: 2016/04/05, 1.2285, 1.2285, 1.2055, 1.209, 26444, 62805 2016/04/06, 1.2145, 1.2215, 1.2, 1.215, 18447, 60456 2016/04/07, 1.2235, 1.226, 1.196, 1.198, 33160, 55222 2016/04/08, 1.198, 1.213, 1.1905, 1.2045, 30661, 0 |
| [2016-04-08 20:57:37] |
This is the result of a data error from Interactive Brokers. Refer to help topic 2.2: Data Errors or Spikes in Charts, Flat or Flat Line Graph, Compressed Graph, Errors with Date/Time Values: 2.2 Historical Charts Unless you have the Multiplier settings not set to 1 in Chart >> Chart Settings >> Advance Settings 2. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-04-08 20:57:55
