Date/Time: Sat, 18 May 2024 22:45:37 +0000
Fill or Kill
View Count: 1545
[2016-04-07 14:46:25] |
User713273 - Posts: 409 |
I understand IB has a fill or kill application when looking at limit sell/target orders. Can this method be applied to our orders in SC using ACSIL? Basically setting FOK as the time in force dictates that the entire order must execute immediately or be canceled. Thx |
[2016-04-07 17:40:37] |
This will be added to the next release as a supported Time in Force type for ACSIL: SCT_TIF_FILL_OR_KILL Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-04-08 13:39:06] |
Great when does this release come out?
[2016-04-08 18:01:28] |
Sometime next week.
[2016-05-19 19:55:27] |
Has this been added?
[2016-05-19 20:01:21] |
Yes it has been. This was done some time ago.
[2016-05-19 20:04:18] |
Great is there documentation for ACSIL for this?
[2016-05-19 20:07:41] |
There is no documentation even needed. But the answer to it is yes. A programmer will know exactly what to do with this without even asking. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-02-06 13:42:32] |
ILIM KIRGIZ - Posts: 187 |
I would like to cancel unfilled parent order of mine automatically when the market moves ahead. Example: market price is @ 1.10. There is a buy limit order of mine @ 1.05 price level with a quantity of 100. When price touches 1.05 level but partial fill occurs then price moves above 1.05 level, I need to rest of the parent order to be canceled. As I use LMAX, I do my trade management via Sierra chart (locally). Is there a way to do so such as using TimeInForce options? Thanks. |
[2019-02-06 16:48:43] |
No. Never rely on those time in force settings. You must be in control of this yourself and cancel the order when you need to cancel it.
