Date/Time: Wed, 28 Oct 2026 20:36:37 +0000
connectivity
View Count: 1013
[2016-04-06 21:00:54]
User848740 - Posts: 12
I trade e mini futures with AMP. Data is CQG FIX Trading
I Use a Count Down Timer study.
Many times it freezes"0"AND THE CHART AND DOM remain frozen.
The Green connection bar has not indicated a disconnect and is still Green.
Some times I have to disconnect and then reconnect to bring the data flow awake. Sometimes I have to delete data and reload.
Annoying at the least but could cause incorrect entries.
Is this an AMP problem?
Fred
[2016-04-06 22:45:36]
When you notice this problem, refer to help topic 3.4 to determine if there is no data being received from the data feed:
https://www.sierrachart.com/index.php?l=doc/helpdetails3.html#h3.4
If there is no data being received, then at that time before reconnecting to the data feed provide a copy of the Message Log following these instructions:
We will ask CQG about this.
Date Time Of Last Edit: 2016-04-06 22:46:14
