Date/Time: Wed, 28 Oct 2026 19:59:12 +0000
inconsistent chart data between primary and sub-instances
View Count: 1131
[2016-03-30 00:52:29]
dominikos - Posts: 106
I have exactly the same chart with intraday ZB data that goes back 2200 days. In the primary instance, I can see all data. However, the same chartbook opened in sub-instance shows only a few days going back - roughly a month.
I'm currently on version 1388.
[2016-03-30 00:55:07]
Make sure you are using the Continuous Futures Contract feature and re-download the data if necessary:
Continuous Futures Contract Charts
That page has all of the relevant documentation.
[2016-03-30 01:05:10]
That's what I use, continuous volume based back adjusted contracts. As stated above, it works in the main instance but not in the sub-instance.
[2016-03-30 01:08:02]
This does not make sense. There could not be a problem with this.
Did you follow through the procedure to re-download the data?
Provide a copy of the Message Log by following these instructions:
http://www.sierrachart.com/index.php?l=PostingInformation.php#MessageLog
Date Time Of Last Edit: 2016-03-30 01:08:29
[2016-03-30 01:14:52]
sent
[2016-03-30 01:40:11]
The Message Log you provided is from the Interactive Brokers instance.
Not the Sub Instance.
Restart the sub instance, and open just that one single chart and provide a copy of the Message Log from that instance.
[2016-03-30 01:48:52]
sent
[2016-03-30 02:29:11]
OK, we saw this problem with another user as well but did not think of it in your case.
This is the problem:
ZB-201606-ECBOT [CBV] Renko 12t #2 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2016-03-29 20:48:21
ZB-201606-ECBOT [CBV] Renko 12t #2 | There are no continuous futures contract symbols. Loading data normally. | 2016-03-29 20:48:21
Follow the instructions here to reset the Symbol Settings:
https://www.sierrachart.com/index.php?page=doc/doc_GlobalSymbolSettings.php#FullResetSymbolSettingsSteps
This symbol settings should have been received but maybe there was an error when that was done. The next release, will make sure they are downloaded if necessary.
[2016-03-30 02:46:50]
I did but the problem still persists, even after recalculating chart. I sent another log from sub instances.
[2016-03-30 03:28:12]
We have to think of a solution to this. But we realize the problem is you are using existing charts.
For the time being open new ones.
