Date/Time: Sun, 05 May 2024 15:53:12 +0000
Adding "Support Left Click to Select Chart Drawings" to the Tool Bars or to the Shortcut Menu.
View Count: 1487
[2013-07-04 13:40:08] |
Zosimus - Posts: 345 |
I know that your hands are full right now so this is for the long run. It would be great if you could add the "Support Left Click to Select Chart Drawings" to the lists of orders that can be added to the ToolbBars and to the Shortcut (rightclick) Menu. Thanks. |
[2013-07-06 01:17:12] |
We will see about this.
