Date/Time: Wed, 08 May 2024 23:38:39 +0000
User Email Questions - Different Chartbooks on Different Screens
View Count: 1794
[2013-07-03 16:53:19] |
Sierra Chart - Max - Posts: 5608 |
I have build two chartbooks of Crude Oil and ES.
in each chart books I have five charts viewing different things. My trading computer has three screens. How do I show BOTH chartbooks (ES & CL) on my screens? do you have a video tutorial on this? or is there a youtube video on this? thanks Sierra Chart Support Date Time Of Last Edit: 2013-07-03 16:53:30
[2013-07-03 16:57:43] |
To view both Chartbooks, you will need to install another copy of Sierra Chart on your computer, and view each Chartbook in its own copy on each screen. We do not have a video of the process. Please refer to the documentation here on how to setup multiple copies of Sierra Chart on the same computer: https://www.sierrachart.com/index.php?l=doc/MultipleServices.html It is also possible to detach a chart from the main window and place them on other monitors. See: https://www.sierrachart.com/index.php?l=doc/doc_DetachingandAttachingChartWindows.html Sierra Chart Support Date Time Of Last Edit: 2013-07-03 19:00:24
[2013-07-26 15:43:34] |
andrewijaya - Posts: 6 |
Hello Max, I have a question. I am currently using Vol by Price study, and it is quite unfortunate that there are many blank space wasted between the chart and the volume on the right most side. Can you please help me how do I set this up so that I can drag the VBP chart closer to the right edge of the chart, as well as locking it so that it will default like that? Thanks |
[2013-07-26 15:57:32] |
First please follow the instructions here: http://www.sierrachart.com/index.php?l=doc/doc_VolumeByPrice.html#RightAligning If you still need help, we need to see an image of what you already have. Please post an image of the chart, following these steps: https://www.sierrachart.com/index.php?l=PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-07-30 13:12:32] |
Hello, Yes I still need help with my question above. I am currently using Vol by Price study, and it is quite unfortunate that there are many blank space wasted between the chart and the volume on the right most side. Can you please help me how do I set this up so that I can drag the VBP chart closer to the right edge of the chart, as well as locking it so that it will default like that? |
Attachment Deleted. 7-26-2013 11-30-28 AM.png / V - Attached On 2013-07-30 13:12:05 UTC - Size: 103.86 KB - 501 views Attachment Deleted. |
[2013-07-30 17:06:26] |
1. You need to reduce the fill space on the right side of the chart. To do this you just need to unlock it and click on the left arrow on the scroll bar at the bottom of the chart. This is documented here: https://www.sierrachart.com/index.php?l=doc/doc_WorkingWithCharts.html#ScrollingTheChart 2. To reduce the height of the table at the bottom, refer to this section about adjusting the height of chart regions: https://www.sierrachart.com/index.php?l=doc/doc_WorkingWithCharts.html#ChartWindowandRegions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-08-04 03:45:52] |
Date Time Of Last Edit: 2013-08-04 04:30:48
[2013-08-04 04:50:01] |
Yes. See: http://www.sierrachart.com/index.php?l=doc/doc_TPOVolProfileCharts.html#VolumeProfiles Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
